Question about Brother PT-1750 Personal P-Touch Labeling System Printer
Will not turn on
With batteries or adaptor cannot switch on
  • Brother Master
  • 783 Answers
Welcome to the Community. Press the F2 key at the Dell Logo on startup to load into the Bios, and check what does it say next to AC adapter, if it says unknown, try another working adapter. If the working adapter works then its an issue with your ac adapter, if it says unknown in the BIOS then its a motherboard failure. Still having Problem Then follow Us For
Brother Printer Support
Posted on Mar 24, 2014
Testimonial: "It is a label printer, not a PC printer"
My dell 1010 switches on but screen stays black
Try to take the battery out and turn on with the adaptor alone...
If it works then its a problem with the battery...
Try to turn with the battery alone.. Or try to get a similar battery or adaptor from friends and try.... If everything is not working it could be a faulty motherboard... If u are in warranty call Dell @18006249896.. Out of warranty then contact a local tech....
Sep 03, 2010 | Dell Inspiron Mini 10 Notebook
My HP laptop cannot be switch on problem with virus
do a power drain
1. shut down the comp
2. unplug the ac adaptor
3. take out the battery
4. without any power connect to the comp
    press and hold the power button for 60 seconds
5.after 60 seconds plug the battery
6. plug the ac adaptor
7. turn on the comp
Oct 20, 2009 | HP Pavilion dv6000z Notebook
My dynex portable dvd player 7 inch screen wont turn on!
Tries buy a new litium battery yet?Get a new adaptor charger?Tries it own website for adaptor charger or Amazon.com,Ebay.com many eclectronics parts excessorries.Tries ur local Radio Shack ask the clerk for help to buy litium battery or charger adaptors.
Oct 04, 2009 | Dynex DX-PD510
Aser Aspire 5920 Will Not Switch On
it must b some problem with the RAM......get the ram changed ...den it will work fine
Sep 02, 2009 | Acer Aspire 5920-6727 Notebook
Dell 600m Computer won't power with adaptor connected
Bad motherboard, unfortunately. Seen it before as a Dell tech.
Jun 29, 2009 | Dell Inspiron 600M Notebook
Adaptor light on. Laptop does not start when power button pressed same problem also when try too start from battery power. Son was playing a pc game and just switched off, have waited for hour still n
try to take out both battery and power adaptor. press and hold the power button for ten secods while both are not connected. then connect the power adapter only. try to turn it on. if it still does not turn on then most likely you have a problem with the hardware. you might need to have it checked out with an outside tech already.
May 25, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Compaq Presario 700 Series Laptop wont turn on
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Nov 23, 2008 | Compaq Presario 700 470024-192 Notebook
My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
      Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    Compaq - will not turn on - plugged in?
    Disconnect the AC adaptor, Take the battery out and press and hold the power button about 5 seconds. After that connect the AC adaptor and insert the battery turn it on. If issue persist please inform for further troubleshooting.
    Good Luck
    Mar 01, 2008 | HP Compaq nc6320 Notebook
    Possbile battery
    It could be a battery fault, have you tried it without the battery?
    Sep 07, 2007 | Acer Aspire 3680 Laptop
    116 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
