Question about Rhino Electronics - Others
Under voltage alarm sounds even without a load.
  • James House
    James House Mar 25, 2014
    The inverter was working properly powering a small fraction of its rated load when the undervoltage alarm came on and continued even with no load. It has been normal for the alarm to sound when first plugged in or if the battery was being drawn down. Now it sounds continuously even with a fully charged battery and no load at all. I still supplies power. Perhaps I'll just disconnect the alarm sounder. If it frys it won't be any less usable than it is now. I was looking for a schematic or the name of the manufacturer but a Google search only returns all the entities that want to sell me a new one.
2 Suggested Answers
  • 74 Answers
SOURCE: I ran my Simon 3 without AC for a couple of days,
You need to replace the battery.
Alarmprofessor.com
Posted on Sep 05, 2010
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
Overload alarm on steady and no voltage
What is the engine doing? Is it bogging down like under high load? If so you may have an internal short and reason for no voltage output as well as the overload alarm.
Oct 09, 2015 | Electrical Supplies
GUAGES ARE OFF AND SPEEDOMETER IS JERKY
Check your battery and alternator for proper voltage with and without a load. Batter under a load with vehicle off must not be under 9.6volts. If so battery is bad. With vehicle running under a load at 1500 rpm the voltage should not drop under 13.0 volts. I have seen low voltages trip guages on fords. If the battery and charging system check good suspect bad instrument cluster.
Oct 10, 2010 | 2002 Ford E350
Engine won't start. Dash lights flash rapidly when key turned.
the battery says 12 volts but may be dropping to 4 or 5 under a load...i would suggest jumpstarting the car and see what happens.the battery should read in the high 12 volts and not less than 9.5 under cranking. the dash lights go out on your car when starting,and the alarm will go off ,and disable the ignition if the voltage is too low in cranking the car because the computer will shut it down and activate the anti theft.....check your battery posts are tight. best of luck
Jul 22, 2009 | 2006 Honda Accord
Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Jul 02, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Alarm system malfunction?
Is your battery getting weak by any chance? May be time to have it load tested.Good place to start.
Dec 11, 2008 | 1997 Buick LeSabre
Hard Drive Alarm & Refuses to boot up
Either your OS is corrupted or you have a serious hard drive issue. Not uncommon for the latter to go without any real warning.
Get a hold of the diagnostics software for your drive and run it. Don't be surprised if it fails.
May 05, 2017 | ASUS P4P800E Deluxe (90M8LCW0G0EAY)...
Deck is powering off every 5 seconds
If radio stays on at low or no volume and cuts out when turning up you may have your battery backup voltage (yellow wire) droping below 10v under signal load. There is a circuit called backup check in radio that moniters Voltage It may seem ok when measuring without volume but under load it will fluctuate with the audio. Try hooking up Heavy guage Ground and Backup battery wires to prevent voltage loss across wires under load. Also check for any speaker that may not be producing proper sound when and if you can get radio working Disconnect wires to that speaker to see if radio will stay on. Just a couple of many possibilities.
kstahl65@att.net
Jan 12, 2008 | JVC KD-S890 CD Player
F6C800 no pwer to backup receptacles
that´s pretty strange and i would say that the batteries aren´t properly charged, try to let them charging over night without any load. good luck
Feb 18, 2007 | Belkin (F6C800-UNV-PL) UPS System
Electronics - Others Logo
Top Rhino Electronics - Others Experts
Are you a Rhino Electronics - Other Expert? Answer questions, earn points and help others
