Question about Hobart HL600 Legacy Stand Mixer
Hook straggles to turn when dough in bowel
Mixer straggles to turn that is in 1/2/3 gears so if you could help.
    New Friend:
    Problem Solver:
  • 7 Answers
The Legacy is an electronic mixer and the transmission does not have any gear, and it frequency convertor that works in phases 2 and 3. If the hook struggling when turns, check the transmission belt locasted at the top of the mixer, remove the cover first.
If the belt is loose, tense it with the screw on the base of the motor or replace the belt. If you can not fix it, let me know and I'll try something else.
Posted on Mar 24, 2014
bigg t
  • 640 Answers
SOURCE: hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
Posted on Jan 28, 2008
  • 68 Answers
SOURCE: Help with removal of Dough Hook on A200.
Force and a torch is your path.
First cut a block of wood that is of a length that is long enough to go from the column to the attachment portion of the planetary. (The block protects the gears from the force.)
Look at the rotation of the hook, you're going to twist it the opposite direction. Above the hook, loop a strand of a wet towel. While keeping the towel damp, not wet, torch the **** out of the hook. I recommend "mapp" gas. Heat it for about 90 seconds to to 2 minutes. The old dough stuck inside will burn off. You should get some black smoke. Use the block of wood, between the attachment portion of the planetary and the column, to resist the twist of the hook. If the wood is properly placed to absorb the load --- dampen towel, torch, block, TWIST. If you use a wrench -- be cautious. Good luck -- Mike
Posted on Jun 28, 2008
bigg t
  • 640 Answers
SOURCE: Hobart a200 mixer won't mix
The bowl holds 20 quarts--are you overloading the mix?This mixer is not made for medium/heavy pizza dough.Depending on the pounds of dough,water and other ingredients will affect the mixer in some way.
Posted on Nov 15, 2008
bigg t
  • 640 Answers
SOURCE: The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Posted on Jan 14, 2009
bigg t
  • 640 Answers
SOURCE: Dry clumps in pizza dough
Throw a quarter in the bowl,put the hook on and raise the bowl.Turn the mixer on and the hook should just skim and move the quarter.This is to check that the hook clearance to the bowl is right so the dough on the bottom of the bowl rides up the hook.I'm a hobart tech and repair these units often.Let me know.
Posted on Feb 21, 2009
Broken gear
Refer this problem directly to Hamilton Beach as the primary source of the parts.
Dec 12, 2013 | Hamilton Beach Eclectrics All-Metal Stand...
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
Dough hook will not come off
I had the same problem too. There should be maybe 1/4" of loose vertical play of the dough hook (or similar attachment) on the agitator shaft. The hook locks in place rotationally on the shaft until it is pushed up. Before you try to turn the dough hook backwards in an attempt to remove it, push it upwards and hold it up, then rotate.
May 22, 2012 | Hobart A200 Stand Mixer
Hi. You should consider a few things. They type of hook you use, can greatly affect your end result. If you're making a yeasted dough with a high protein percentage 12-13%, you should be using an "ED" hook, this is a spiral hook that has a sharp turn at the tip. You can find them on eBay for a competitive price. I believe that Hobart also sells them, but for a higher price. They are very good for mixing pizza type doughs, they also do an excellent job kneading the dough.
Have you checked the flour for lumps before it goes into the mixer? Have you tried sifting the flour?
Are you adding all the liquid and flour at once? If so try adding flour in stages to all the liquid. If you find that this solution helps you, please rate it. Good luck! ricardok45
Feb 19, 2009 | Hobart D340-6007 Mixer
Jan 13, 2009 | Hobart N50 Stand Mixer
Mixer stopped turning when I was making bread
You probably have stripped the gear in the head section. It can be replaced, but I would consider this a advanced repair since you need to push steel pins out of the shafts to replace the gears. Use google to find a local repair shop, or fix it yourself if your mechanically inclined, parts are available online (and not that expensive).
Sep 26, 2008 | KitchenAid KP2671 Professional 6 Series...
Viking stand mixer dough hook will not come off
Had the same problem with dough hook not coming off. Sent to a Viking dealer in Rockford and was quoted $600. to replace gear box. Took it back without repairs and call Viking listed in manual and sent it to them on a Monday and by Friday had it back fixed and no charge.DM
Feb 18, 2008 | Viking VSM700 Stand Mixer
Blakeslee CC-30 Planetary Mixer & dough hook not mixing correctly
it sounds like you may have a sheared key on one of the shafts.with no product in the mixer will it run in any other speeds?when mixing pizza dough you should only use 1st gear.if it does run in other speeds you have a sheared key or broken shaft,if it doesnt run in any speeds drop the planetary and check the key on that shaft.
Jan 05, 2008 | Food Mixers
Beater jams
You are going to DESTROY YOUR MIXER by kneading dough with the flat beater. Read the directions. They spell it out in big letters. Only use the dough hook for dough; only use speed 2.
If the mixer generated enough torque to knead dough with the flat beater (it doesn't), it would tear up and overwork the dough. As it is, you're lucky you didn't strip a gear.
Dec 23, 2007 | KitchenAid KP2671 Professional 6 Series...
Hobart HL600 Legacy Stand Mixer Logo
89 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
