Question about Vehicle Parts & Accessories
04 Colorado leak under hood PASSENGERSIDE
Thick black and lots of it
    Habit-Forming:
    Scholar:
  • 60 Answers
Sounds like an very bad oil leak. If there is so much that you can't readily determine where it comes from, first you need to shampoo the engine. This is a procedure I do not recommend a "back yard" mechanic do. On a 04 Colorado there are a tremendous amount of electrical systems that can be destroyed if it is not done properly. I suggest getting a licensed garage to do the engine shampoo then run the vehicle checking for the leak. Most licensed garages will also determine where the leak is coming from at no extra charge (just ask). You do not have to let the garage fix the leak if you do not want them to but you should make it clear to them first that you do not want anything fixed just the leak found. You can then proceed from there. I think there are "over the counter" engine cleaners that can be purchased and used if you are not willing to pay for a garage to do this for you but again I caution you with these products and damaging electrical components, follow the directions precisely.
Posted on Mar 24, 2014
04 LINCOLN NAVIGATOR AIR RIDE COMPRESSOR HAS NO VOLTAGE
Somewhere, ahead of the compressor, are relays and a fuse or two. Your Lincoln dealer should be able to tell you where to look, if you do not wish to take it to them.
I think under the hood is the first place to look, as that circuit is requiring a lot of current.
You have a black plastic cover over a black plastic box with fuses and circuit breakers in it under the hood, and you might find the air ride system named in that box with a corresponding fuse.
God bless your efforts.
Oct 24, 2016 | 2004 Lincoln Navigator
Condensation in engine oil 2006 chevy colorado
Depends on the problem. It could be coolant leaking into the engine oil, or a vent problem, or the engine may not be reaching normal operating temp and getting rid of the moisture inside the engine.
Feb 23, 2014 | 2006 Chevrolet Colorado
How do I clear a code P0506 on Chevy Colorado 04'? Not fix, but simply clear to see if it returns.
did you try disconnecting the battery and then reconnect battery, it works a lot like a hard boot on a PC in fact that is what your doing to your cars computer
Dec 02, 2011 | GMC Canyon Cars & Trucks
Relay location ABS pump
look for a black box under your hood,may be on drivers side fenderwell.if not,look on passengerside under hood. lift the cover off. the main relays and fuses are located there. you will be lookind for a bad relay if your abs lights on. or you have a bad abs sensor on one of your wheels. you can try to reset the light by removing the positive cable on your battery for 10minutes,but if the light comes back on after that,you have a abs problem. please repost your problem to fixya.com
Jan 22, 2011 | 2006 Chevrolet Cobalt
I HAVE A 204 CHEVROLET COLORADO AND THE HEATER FAN WILL NOT COME ON ON ANY SPEED
This same thing just happened to my 04 colorado. the problem is in the wiring harness or the resistor for the blower motor. I found my problem in the harness. Take the few screws out of the glove box hinge and the cover under the glove box and the motor will be exposed. disconnect the large white coupling and look to see if the pins or holes are black, like they had been burned. If they are, you may be able to clean them and put them back together. If they look normal, the small black box that is bolted to the plenum has gone bad, this is the resistor. The entire harness, with resistor can be purchased on gmpartsdirect.com
Jun 30, 2010 | 2004 Chevrolet Colorado
Water leaking from under glove compartment in
Is it all the time, it could be the heater core. if it's only when you run your a/c it's a plugged drain tube. it's located under the hood, by where the a/c goes into the fire wall. it's a black, soft rubber tube
Jun 16, 2010 | 2006 Toyota Matrix
1997 Buick Park Avenue
the blower motor is located either under the dash on the passengerside or under the hood on the passengerside
Aug 28, 2008 | 1997 Buick Park Avenue
Wet floorboard
Any idea what the liquid is?
Jun 15, 2008 | 2003 Dodge Caravan
1991 LeSabre cabin blower fan ( heater/cooling )
A\C control module located in the heater box under the hood two plugs single red wire on the passengerside purple wire and two black one has a stripe i think $90 (autozone) to $185 napa my best guess
Jun 13, 2008 | 1991 Buick LeSabre
Vehicle Parts & Accessories Logo
27 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
