Question about Roper Refrigerators
Roper RT14 series - Ice build-up in freezer compartment
Hi, I have a 7 years old Roper RT14 series appliance, without the ice maker, and I have had to unplug it three times in the last 3 to 4 months or so. It seems that ice builds up behind the panel at the back of the freezer compartment, eventually clogging the ducts that send cool air into the fridge part. It's been a little over a week now since I've done the last thaw and have removed the lower vent-panel and already see a build-up. Also the fan seems to not be working in the freezer compartment. I'll add that there has been 2 or 3 power outages between September and December, in case it could have fried anything.
    Sergeant:
  • 446 Answers
You are having an automatic defrost problem. there are 3 components in that system and it could be any one of the 3 .
There the timer (most common) heater, and the bi metal terminator the heater and bi metal can be tested with an ohm meter and the timer if mechanical can be rotated into a defrost
Posted on Mar 24, 2014
4 Suggested Answers
  • 219 Answers
SOURCE: ice accumilation next to fan in freezer compartment
u have a defrost problem need to replace heater and tstat
Posted on Mar 19, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Freezer cold- Fridge not. Ice build up on freezer
I really believe your adaptive defrost located inside the fresh food compartment and inside the control panel is defective. It puts your refrigerator on a timely defrost and if defective this problem you listed in your post happens. Yes we may need to also check the defrost heater and defrost thermostat but with my experience with that type of Adaptive Defrost Control is famous for its failure.
ADAPTIVE DEFROST CONTROL Part Number 61005988 You can find it located on two of my websites. Some models like yours came with a Defrost Timer. We will need just look inside the control panel and see for sure. Here is a photo of the Adaptive defrost. If you should need to contact me please send an email or try to answer here. Problem is I don't get notifications when someone comments. appliancepartsouteast@live.com
Please rate and ask me as much as you like. Thank You, Sea Breeze
Part 61005988
http://appliancepartseast.blogspot.com/
http://servicepartstec.blogspot.com/
Posted on Aug 10, 2009
  • 1274 Answers
SOURCE: I have a Sub Zero fridge about 15 years old. The
try turning the thermostat down a little,..........don,t know what you got it set on ........but water freezes 32 degrees
Posted on Feb 16, 2010
1 month old Samsung RF28HFEDTSR. No ice in upper ice compartment. All Ice drops to bucket in freezer section. I press reset button it dings and soon one group of ice falls in upper bucket.
I believe something's wrong with your new ice maker. Are you sure that the ice maker is not turned off on the display? And take a little bit of time and go through your user manual if you don't have the user manual let me know I will send you one
http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1509233L.pdf
Appliance 911 Sea Breeze
Sep 02, 2016 | Samsung Refrigerators
Ice maker ice jam
Not a whole lot you can do but to keep the frost down.
If you are able to move the items in the freezer to another freezer and let it sit overnight, all your problems will melt away....
Until a couple months later when it builds up
Make sure to double check your freezer is sealing correctly, bad gasket causes moisture to be sucked in.
Here are some basic ways to slow the buildup
How to Avoid Freezer Frost
Feb 10, 2016 | Samsung Refrigerators
Cracking sounds from top of refrigerator compartment of a 7 year old WSE6070WA
Had the problem in a similar fridge - the repair person said the noise was most likely the sound of ice build up being removed during defrost cycle and not to worry. Suggest you check the freezer temperature is not too cold and building up excess ice.
Oct 20, 2013 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Ice Maker WR30X0327 Freezing Over I have an
We have extremely hard water in the East Mountains of NM. Our refrigerator Ice Makers only lasted about a year before the Calcium from the underground Calcium just killed them. I solved the problem by buying, from ebay, a small restaurant ice-maker. I Always fill it with filtered water, and it has been chugging away for years. Our water tested Harder than an Hot-tub maker had ever seen, even after going through our old, Sears, water-filter. Ergo - how hard is your water? Could that be the problem. Just a thought.
Mar 03, 2017 | Refrigerators
Water line stopping right before going into ice
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 13, 2010 | Roper RT21SKXLQ Top Freezer Refrigerator
Refrigerator is 7 years old. no ice is being made and refrigerator is now setting on the "coldest" setting, and barely keeping refrigerator cool and freezer items barely frozen. could dirty coils be...
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 13, 2009 | Roper RT18HDXKQ Top Freezer Refrigerator
Ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Roper top freezer ice maker out of sync? Too warm?
sorry you must replace the icemaker.
Mar 30, 2008 | Refrigerators
Ice maker leaks into the ice storage bin
turn off the power to the appliance and apply a hairdryer to the ice maker compartment for about 2 mins , worked for me.
Jan 11, 2008 | Freezers
Refrigerators Logo
94 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
