CPU Fan I recently upgraded my processor from a AMD Athlon II X2 220 to a Phenom X4 840. For some reason the CPU fan will come on and shut off a few times within a minute. Can anyone give me a few suggestions on what can be causing this problem ?????
  • bjones8205 Mar 29, 2014
    Thanks for your help. I was getting a false reading for my TMPIN2. When I changed the processor I applied new thermal paste to the new one. I guess I have to upgrade my fins and fan.
  • Paul Smith Mar 29, 2014
    My pleasure. Happy computing. :D
    Problem Solver:
  • 8 Answers
When it comes to computers and changes in system heat, the very first thing I always tell folks is to clean your computer. Dust is one of the best insulators out there so get the dust out, drop the computer's running temperature. (Oh.. and please don't use a regular vacuum cleaner unless you like dead motherboards!!)
I've come across this fan issue a couple of times now. Barring a dusty computer, it's most likely that your new hotter system is running at the same temperature as the fan setting on your motherboard. The X4 Phenom runs hotter than the X2 220 by only a slight margin but that's all it takes. I'm assuming you're comparing these at default speeds as when you overclock, your base temperatures all go out the window.
There are two solutions to this, up the temperature range of your fans or cool down your system. If your system is already running at 50C or hotter, you'll need to look at some combination of reducing internal clutter (blocks or diverts air flow), getting higher CFM fans (though not necessarily noisier.. there's some quiet fans out there), or even changing your case for one that pushes high air flow.
If your system is already running sufficiently cool, your may simply want to increase the fan temperature value in the BIOS/UEFI.
There's a bunch of good freeware tools out there to monitor your system temperatures like HWMonitor or AIDA64.
Hope this helps some.
Posted on Mar 24, 2014
  • 5 more comments
  • bjones8205 Mar 26, 2014
    From the CPU section in HWMonitor I am getting between a 52 - 61 degrees C. And my TMPIN2 is reading a 128 degrees C. Is this normal?
  • Paul Smith Mar 26, 2014
    No.. your TMPIN2 (likely your northbridge chip) is either running incredibly hot or you may be getting a bad value from either the software or your motherboard. Please re-test the values with a different software like RealTemp to see if your software is misinterpreting the value. If you could let us know what motherboard you are using, that would be very helpful.
    Ok. Iam using a DA061L-3D m/b
  • Paul Smith Mar 27, 2014
    OK.. This is an Acer board from pre 2006 so we're talking about
    some pretty old thermal compound. You might consider pulling the finned heatsink off and redoing the thermal compound... possibly even changing the fins out for fins and a fan... Zamlan has come pretty nice quiet chipset fans..
    and (sorry for the broken message.. arrgghh!!) do the same for your main CPU as well. See what that changes... you might be pleasantly surprised. Nice upgrade btw!!
    Thanks for you help. I was getting a false reading for the TMPIN2. When I changed the processor, I also applied thermal paste to the new processor. I'm guess I have to upgrade my fins and fan.
4 Suggested Answers
SOURCE: Emachines - ET1331G-03w... amd athlon II x2 core
NO.
Posted on Jan 29, 2010
  • 11800 Answers
SOURCE: upgrade cpu for amd athlon4050e processor
  • Any AMD processor for AM2 socket that has a higher rating will do. Best one is http://www.mwave.com.au/newAU/mwaveAU/productdetail.asp?SKU=19040125
All it takes is a powerfull enough motherboard with a matching BIOS.
Or you could buy this combo
  • http://www.outletpc.com/c3688.html
Posted on Apr 11, 2010
lars_olsson6
  • 3400 Answers
SOURCE: upgrade processor
You have to now your motherboard.whithout that it is impossible to say.
Posted on Apr 06, 2013
How do I upgrade an AMD Phenom II x3 710
I suspect you mean the Motherboard that has the AMD Phenom II x3 710.
If so then find specifications on that motherboard to see what better, faster? CPU is compatible with it.
4th Core is Disabled by AMD and you need to know how to enable it?
Maybe this can help.
Overclocking Phenom II x3 710 2 6GHz to 3 5GHz unlocking 4th core
Hope it helps
Oct 11, 2014 | AMD Computers & Internet
Is the Am3+ socket also possible for sapphire AM3RS890G2?
am3+ socket is what the socket is listed on the motherboard, so if you have a CPU that fits only AM3+, the CPU wont fit it unless directed by the CPU manufacture seeing that AM3+ is for AMD processors only if you have a older AM3 CPU it might fit the AM3+ motherboard if listed, this paticular model only lists AM3 and fits Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6
Aug 10, 2014 | Sapphire Technology PC-AM3RS890G2 Desktop...
Upgraded cpu and fan om HP p6320y desktop won't stay powered up
The AMD Phenom II X4 850 (HDX850WFK42GM) uses up to 95 Watts of power,
http://www.cpu-world.com/CPUs/K10/AMD-Phenom%20II%20X4%20850.html
(Electrical/Thermal parameters)
While the AMD Phenom II X4 965 uses up to 125 Watts, or 140 Watts; depending on which Part Number....
HDZ965FBK4DGI uses up to 140 Watts.
HDZ965FBK4DGM uses up to 125 Watts.
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#.22Deneb.22_.28C2.2FC3.2C_45_nm.2C_Quad-core.29
Scroll down a little.
I'm going with Not enough power from the Power Supply.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01969880&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=4120661
Power Supply is ONLY 300 Watts?
Yes, the Power Supply is too small IMHO.
Is there also a graphics card you have installed, and not stated?
Regards,
joecoolvette
May 14, 2013 | Computers & Internet
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
Error message shuts computer at start up...CPU fan failed. HP Pavilion M8400 F Phenom X49500 2.2 GHz (computer is new to me)
the trick is that there is more than one spot where you can plug in the CPU fan, had the same issue with an HP myself. try a different spot to plug in the CPU cooler. mine was in the upper right hand of the board and was labeled CFAN. the one i thought was for the CPU (it was same color as the fan connector) was actually a case fan connection.
Mar 29, 2010 | ASUS M3A78-CM AMD 780V AM2+ Phenom FX /...
Problems with Abit NF-M2S Motherboard?
hi there..
i also have the same mobo like yours. i also thinking to upgrade my old processor with better one..
made some quick research.. i would say the mobo unable to support the new processor. checked the BIOS update n CPU support list in Abit's site..
didn't show X4 processor is supported :(
Jan 15, 2010 | Abit NF-M2S Motherboard
Hello again, Upgrading CPU's
Your board supports socket AM2 CPUs the fastest of which is the AMD Athlon 64 X2 6000+ dual-core processor at 3.1 GHz.
Your motherboard does not accept socket AM3 CPUs.
Dec 15, 2009 | Computers & Internet
Fan overspeeding / usb ports not working
I'm glad that fixed it!
(Posted as a solution so that you can rate the response.)
AMDFan, update to the most recent BIOS and that should fix the problem. It fixed death88scyth's issue, I see no reason as to why it won't fix it for you.
Mar 25, 2009 | ASUS M3A78-CM AMD 780V AM2+ Phenom FX /...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
