Question about Freezers
Danby freezer My two year old Danby DUF808 quit working in January it had recently been moved to garbage and we have had very cold below freezing temps. Now it's spring it still does not work. What's wrong?
  • 884 Answers
If it stopped working after being moved, check all the electrical connections. Also check no pipes were broken in the move. Is there any noise from the compressor?
Posted on Apr 26, 2014
5 Suggested Answers
  • 2920 Answers
SOURCE: New 3.6 Danby freezer not freezing
maybe you should go with a different brand???
Posted on Feb 04, 2009
SOURCE: FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Posted on Oct 22, 2009
walesarumi
  • 6993 Answers
SOURCE: my danby 3.6 chest frezzer
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps........
Good luck.
Posted on Apr 14, 2011
  • 884 Answers
SOURCE: Danby freezer, DCF550W, Works for several months, quits, reset the dial and continues to work for several months
You can bypass the thermostat and it will run continuously, or replace the thermostat
Posted on Aug 08, 2012
My 19 year old daughter is going to University in Kitchener/Waterloo 7 hours by car from us in Ottawa. We bought her a Danby diplomat freezer from Walmart and then had to hurry home. She has pluged it in...
dear sir /madam
i think after 7 hour journey your freezer has been leak it,s need now to find out leakage and brazing after that refill gas so please contact to your maintenance personnel for further action
hope answer the question
thank you
please vote !
Sep 06, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
HOW TO FIND REGISTRATION AND WARRANTY IN CANADA
You can register and warranty the Danby at the link below for Canada.
https://www.danby.com/registration.php?ln=CE&
Good Luck and please rate 4 thumbs up for the free answer
Jul 14, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
I moved my freezer and now will only stay cold for a short time, why?
You jard the liquids. Did you just move it a little or move like to another house because if you move a frig or freezer somewhere or lay on it's side you shouldn't plug in for an hour or more so it all settles or it won't work. Hope this helped
Apr 29, 2010 | Danby 5.5 cu. ft. / 156 liter Chest...
Would a bad thermostat cause my danby to not completely freeze?
Should operate 24 hours before putting anything in that is not already frozen. Check it again after it has run for 24 hours. Anytime you adjust the thermostat go one click at a time and wait 24 hours for it to stabilize.
eric
Jun 30, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
Feb 04, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezers Logo
110 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
