Question about Troy-Bilt 179cc 24-in Two-Stage Gas Snow Blower 31AS62N2711
Auger the auger turns when handle is not engaged. Just changed the auger belt. Any ideas?
  • 3,289 Answers
Hi Brenda,
This machine makes use of two levers on the handle. The right controls the drive and the left controls the auger. When both are released, the drive wheels and the auger should stop. The impeller (the part inside that pushes snow up and out of the chute) will run as long as the motor is running and not controlled by the levers.
You said the auger continues to spin even when the lever is released. Both levers are connected by a flexible, thin, steel cable that extends down to a "wheel" or pulley assembly that is held in place by two hex nut bolts to the rear (operator position) corners of the machine. The steel cable should be ON the wheel - not hanging in free air and not wedged between the pulley and pulley support. Loosening the bolts and adjusting the pulley UPWARD should reduce tension / provide SLACK required to disengage the auger when the lever is released (adjust for a *small* amount of slack only). Positioning the pulley DOWNWARD increases tension that reduces the amount travel the lever needs to ENGAGE the auger. The pulley assembly position needs to be adjusted so that when the lever is released, the auger shuts off, and when squeezed, the auger turns on. These same adjustment procedures can be used for the DRIVE lever control, too.
If you are unable to adjust the cable so that there is a little slack, then there is a problem with the cable at the other end - inside the machine. It will require someone who is mechanically inclined - or snow blower serviceman to adjust / repair this for you if you lack the tools and understanding to do the work yourself. It is not likely to be an expensive repair, however. You should ask for an estimate or be given the opportunity to authorize repairs before they are started.
I hope this helps and good luck!
Posted on Mar 24, 2014
  • Steve Mar 24, 2014
    Error -> The impeller (the part inside that pushes snow up and out of the chute) will run as long as the motor is running and not controlled by the levers.<-- this was edited out, but somehow got back in. Sorry for the confusion!
Auger on snowblower doesn't engage
how do I find good anime movie on Netflix help me fam
Feb 11, 2015 | Mtd Garden
Auger won't stop
Open up plastic cover over belts.There is a pulley that moves against belt to engage front auger.There is a spring that hold it in the off position and when you pull the handle it moves that pulley.Sounds like spring broke or slipped off.
Mar 23, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
The snow blower orger gets stuck when trying to remove snow
Check to see if the shear pins are broken off if so remove any fragments and replace. if not..With the engine off, try moving the auger with the handle engaged (you may need to have someone hold the handle while you wiggle the auger. If the auger spins freely without moving the belt mechanism you have either a shear pin issue or shaft breakage if it will not move or moves with great difficulty work your way back through the machine looking for the obstruction or damage. If the auger moves freely and the belt pulleys etc. move with it you likely need to adjust/ replace the tensioner, control handle or belt.
Feb 28, 2014 | Mtd Garden
Noma auger wont stop spinning when disengaged
Sounds like either the auger belt is jammed to tight or handle mechanism to engage/disengage is stuck in on position. I would remove belt cover to inspect auger belt and pulley first, then remove bottom cover and inspect auger engage apparatus. I think once you inspect the problem will be self explanatory. Good luck!
Feb 18, 2014 | Garden
Fix ariens snowblower 520 dies when engaging the auger lever
Your front end is jammed. Its either frozen or there is a rock or something jamming it up. Before you start engine reach down chute and turn back impeller that throws the snow out of blower. Should turn freely. when its free its fixed. You will probably need a new belt.
Feb 17, 2014 | Garden
Honda hs55 when handle depressed blower fan moves at fast speedauger turns very slow.if auger makes contact with snow auger and blower fan stopsnew belt was installed no slippage of belt present
I suspect that all is needed is a little adjustment of the rod attached to the handle, which hooks on a lever at the bottom of the snow blower drive axle case. Try adjusting the nut two turns, that will pull the rod a little bit more and engage the rubber faced drive wheel, giving it a snugger connection. If this has been checked or still does not help, then I would check inside the case where the drive axle is located. There is a rubber faced drive wheel (as noted above), that runs against a smooth flat metal pulley. The rubber on the drive wheel could be worn out and not engaging properly. I would also check on the front of the case where you installed new belts to make sure that the brake shoe puck that connects to the auger pulley is not binding or perhaps has flipped out of its normal location.
Dec 05, 2013 | Honda Piston Rings Snow Blower Lawn Mower...
Auger on ariens 522 turns when not engaged
the drive shaft that connects to the auger may be stuck in gear or depending on the wear and age rusted shut. I would check that before doing anything.
Dec 29, 2012 | Garden
I have an Ariens 1128 Snowblower. Here's the problem, everything seems to function fine, impeller spins, augers spin, howerver, when I put it into any real snow (more than 6-12 inches) the impeller and...
Hi, I will try to help you with this problem. I think the problem might be an adjustment issue. If you take the cover, usually plastic, situated just in front of the engine housing, you will see the belts and pulleys. Without the engine running, press on the auger/impeller lever, and if you look inside you should see how the belt is made to engage the auger pulley. Probably by an idler pulley that pushes on the belt to make it tight to turn the big pulley. That is the most popular way, it is to loosen the bolt on the idler pulley and push it towards the belt so it applies more pressure to the belt to turn the auger pulley and tighten the bolt. There could also be an adjustment on the linkage that might be adjustable. Another possibility is that the belt is worn and is riding on the bottom of the pulleys therefore not providing enough friction to turn the pulleys properly. I think if you take a good look at that system you will comprehend it. Hope this is helpful. All the best and good luck. I will gladly answer any other questions.
Feb 02, 2011 | Garden
How do i change the auger belt on a honda hs 70 snowblower?
Remove the auger belt housing cover 4 bolts (10mm), if you are lucky, you can take the belt out, or just cut it. The slide the new belt between the auger and driving pulleys. there is a break pad under the auger pulley, so have someone engage the auger handle and put the new belt on the auger pulley. Or you can remove 10 12mm bolts and separate the auger and engine. Even though you have remove more bolts, it is easier.
Nov 26, 2010 | Garden
Auger blades won't turn
You need what they call a "friction wheel" replaced.
Oct 31, 2009 | Garden
Troy-Bilt 179cc 24-in Two-Stage Gas Snow Blower 31AS62N2711 Logo
228 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
