Question about Samsung DW80F600 24" Black Built-In Dishwasher 15 Place Settings, Energy Star
Heavy light flashing
Book says this is a leakage error. I found a pinched supply line that leaked. Replaced the supply line and Re-installed it and still have the error.
  • 4 Answers
Heavy Light flashing indicates leakage error.
The leakage sensor on the bottom cover of the unit is detecting water in the bottom of the dishwasher. Possible parts that could be the issue are as follows: Hose Connections, sump and tub assembly, drain pump or just simply the main PCB.
tip the unit in its back and remove the bottom cover. disconnect the leakage sensor and inspect the inside of the unit carefully for ANY water leaks. Most of the time its a mouse chewing holes in the tubing for water. Otherwise check carefully and you will see the leak.
Posted on Jan 30, 2015
What causes a Samsung dishwasher to flash heavy and smart auto on control panel
Hello. The lights you describe are an error code that means over-level filling (overflow condition) and/or the leakage sensor underneath has detected water. You need to check underneath the unit for any moisture. There is a leakage sensor located at the center of the base, underneath the unit. If it detects water, it will notify the main board which will stop the unit until the condition is cleared.
Aug 02, 2015 | Samsung Dishwashers
Why is the heavy light blinking on my samsung dishwasher
That is usually indicating a leakage error, which means water has leaked down into the base of the dishwasher. You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water, but you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Aug 03, 2014 | Samsung Dishwashers
Samsung dmt400rhs blinking HEAVY light
I believe that error code indicates that you've got a leakage error, which means water has leaked down into the base of the dishwasher. You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water, but then you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Jul 09, 2014 | Samsung DMT400RHS Builtin Dishwasher
Leakage error
You need to dry out the water collection pan under the leak sensor. Depending on the model, this may be on the left side, on the other side of the case-brake assembly (a styrofoam float device), or may be on the right-hand side (2 prongs that stick down into water, where the water completes the circuit).
Jun 08, 2014 | Samsung DMT400RHB
Engine light came on smell gas fumes see no leakes its a 2003 dodge grandcaravan
My 2004 Mazda 6 had a similar problem. It smelled like gas inside the car and had code # P0456. I found that the PCV line was pinched. The line was not an Original Equipment. I replaced the line and the PCV valve. So far so good...
Apr 13, 2014 | Dodge Caravan Cars & Trucks
Samsung Dishwasher error light "heavy" or leakage error
I had the same problem, SAMSUNG did not want to tell me how to fix so I jumped in with research I found that after you remove the power supply, i.e. plug, 1) you need to remove the dishwasher and turn it upside down. 2) There is a white sensor tray; 12x12 approx. on the bottom held in with two screws, remove the screws and use a flat head screwdrider to undo the clips holding the tray in place. 3) Dry the tray and sensor tips with a towel and replace the tray. Bammmm, you have just fixed the LE(leaking error) code error.
Feb 19, 2013 | Samsung DMT400RHW Builtin Dishwasher
P1495 on 2000 dodge stratus 2.4 l engine how to fix the problem
The code is telling you that you have a problem with the pump.
DTC P1495 - LEAK DETECTION PUMP SOLENOID CIRCUIT
WHEN MONITORED Ignition on and battery voltage greater than 10.4 volts .
SET CONDITION The state of the solenoid circuit does not change.
POSSIBLE CAUSES Fused ignition switch output circuit open
Leak detection pump defective LDP solenoid circuit wiring harness observable def LDP solenoid ckt wiring harness intermittent def LDP solenoid control circuit short to ground Leak detection pump solenoid control circuit open Powertrain control module defective
During evaporative system diagnosis, Leak Detection Pumps have mistakenly been replaced. A thorough inspection for pinched, kinked, or disconnected supply vacuum lines (as currently listed in the Powertrain Diagnostic Procedures) is a critical step in diagnosing DTC P1494 (LDP SW OR MECHANICAL FAULT). Additionally, the other evaporative leak faults (DTC P0442 - SMALL LEAK, P0455 - LARGE LEAK, and P0456 - VERY SMALL LEAK) should have the supply vacuum lines examined for pinches or kinks prior to any LDP component replacement.
The supply vacuum lines should be checked from the engine compartment all the way to the fuel tank, including the LDP and purge system.
NOTE: VERIFY ALL RELATED SUPPLY VACUUM LINE ROUTINGS FOR PINCHES, KINKS, OR DISCONNECTION'S BEFORE REPLACING LDP SYSTEM COMPONENTS.
Hope this helps, also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Apr 16, 2012 | Cars & Trucks
We have a 46 inch sharp tv model number 46SB54U won't turn on. The green timer light is flashing. We just replaced the power supply board thinking that was the problem. TV still won't turn on...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will helpout ......
Jun 25, 2011 | Sharp LC46SB54U 46 in. LCD TV
P1494
The Dodge P1494 engine light code means Leak Detection Pump Switch or Mechanical Fault. A proper diagnosis must be done, you can't simply replace the LDP and expect that to fix the problem. It shouldn't hurt anything to keep driving it for a while until you can get it fixed.
There is a technical service bulletin that applies to your vehicle and it mentions that code specifically. I'm including it here for your information: TSB-18-01-00
SUBJECT: Misdiagnosed Leak Detection Pump Systems With DTC P1494, P0442, P0455, OR P0456.
MODELS: 1997 - 2000 (LH) Concorde/Intrepid/LHS/300M/Vision and others
DISCUSSION:
During evaporative system diagnosis, Leak Detection Pumps have mistakenly been replaced. A thorough inspection for pinched, kinked, or disconnected supply vacuum lines (as currently listed in the Powertrain Diagnostic Procedures) is a critical step in diagnosing DTC P1494 (LDP SW OR MECHANICAL FAULT). Additionally, the other evaporative leak faults (DTC P0442 - SMALL LEAK, P0455 - LARGE LEAK, and P0456 - VERY SMALL LEAK) should have the supply vacuum lines examined for pinches or kinks prior to any LDP component replacement. The supply vacuum lines should be checked from the engine compartment all the way to the fuel tank, including the LDP and purge system.
Hope helps (remember rated and comment this).
Sep 08, 2010 | Dodge Dakota Cars & Trucks
Television will not stay on. The indicator light
first you have to open the back cover of the television to check for bulged capacitors,if found replace with the same number, but if otherwise
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helps....
Jun 07, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Samsung DW80F600 24" Black Built-In Dishwasher 15 Place Settings, Energy Star Logo
214 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
