Question about Garmin Nuvi 200 205 250 255 260 W
Screw size The blank for the microSDHC card slot broke off and is jammed inside the unit. What is the best way to remove blank?
    Sergeant:
    Champion:
  • Garmin Expert
  • 373 Answers
Cocktail stick, its spring loaded so should click when you push it in, then shake with a jolt to get it out
Posted on Apr 11, 2014
  • Gene Wilson
    Gene Wilson Apr 13, 2014
    Think that trying too many other "tools" has it jammed in there pretty tight. Tried this and could not get piece that stuck to budge. Thank you
  • compusat Apr 13, 2014
    Your only other option then is to dismantle the unit and remove the card, the reader may need to be changed as a result of damage. you got a 50 50 chance.
What size micro memory card does the JVC Everio GZ MG360 take
The GZ-MG360 takes microSD cards. Make sure you get a microSD card, not a microSDHC card. While a microSDHC card will fit into the slot, it is electronically incompatible and will not work. microSD cards go up to 2GB in size, microSDHC cards start at 4GB and go up.
Apr 05, 2012 | JVC Everio GZ-MG360 HDD Camcorder
Can I attach an 8 GB Micro SD Card in the expansion slot of my Sansa e250? If not, what is the maximum storage size it supports?
The e250 uses microSD cards, not microSDHC cards. The maximum size of microSD cards is 2GB. Anything larger are microSDHC cards.
Mar 16, 2010 | SanDisk Sansa e250 MP3 Player
Where do i put it in my lap top
It depends on whether your laptop supports SDHC, microSDHC, or neither.
1. Supports MicroSDHC: check on the manual the position of the MicroSDHC slot.
2. Only supports SDHC: you need to purchase an adapter - essentially a full-size SDHC with a slot where the MicroSDHC goes. Plug the micro card in the adapter, plug the adapter+card into the SDHC slot.
3. Neither: you need to purchase both a micro-to-SDHC adapter and a SDHC-to-USB reader (usually SDHC in supported in most "XYZ-in-1 readers", like Quanta 32-in-1 USB reader - check out "SDHC USB reader" in eBay, for example).
Feb 11, 2010 | SanDisk 4GB microSDHC Memory Card
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jammed
Paper Jams
Cause 1 : Paper jams in the paper output slot/Auto Sheet Feeder.
a) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will be ejected automatically.
b) Reload the paper into the machine and press [OK].
* If you have turned OFF the machine in step a), you will need to retry printing, because this operation cancels any print jobs in progress.
Cause 2 : Landscape Credit Card-size Paper Jams inside the Machine.
Action : You cannot load Credit Card-size paper in the landscape orientation.
If <PAPER JAMMED> or <E3> is displayed on the LCD/LED, remove the paper following the procedure below:
a) Load Credit Card-sized paper in the Auto Sheet Feeder one sheet at a time.
Do not load it in the landscape orientation.
b) Press [ON/OFF] on the machine to turn OFF the power.
c) Press [ON/OFF] again on the machine to turn ON the power.
The paper is fed and the jammed paper is ejected accordingly.
If you cannot remove the jammed paper or the error still persists, contact a Canon service representative.
Hope this helps
Please rate my response.
Thanks
Have a good day.
Dec 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How do I remove paper jamed in the printer?
Paper Jam :
Cause 1 : Paper jammer in the Paper Output slot or the Rear Tray.
Action : Remove the paper following the procedure below.
a) Slowly pull the paper out, either from the Rear Tray or from the Paper Output Slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, turn the machine off, open the Scanning Unit (Printer Cover) and remove it.
Be careful not to touch the components inside the machine.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
*If you cannot pull the paper paper out, turn the machine off, and turn it back on. The paper will be ejected automatically.
b) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step a), all print jobs in queue are canceled.
Reprint if necessary.
If you canot remove the paper or the paper tears inside the machine or if the paper jam error continues after removing the paper, contact your Canon Service representative.
Cause b)Landscape credit-card-size paper jammed inside the machine.
Action : Do not load credit card-size paper in landscape orientation.
Slowly pull out the paper from the Tray and remove it.
If you canot remove the jammed paper or if the paper jam error continues after removing the paper, contact your Canon Service representative.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 25, 2009 | Canon PIXMA MX300 All-in-One Printer
How do you put your sandisk microSDHC card with adapter in your camera
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper jam
You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
Also see this:
Issue: Paper is jammed inside the printer
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 22, 2009 | Canon PIXMA MP600 all-In-One InkJet...
5110 ERROR ON PIXMA PRO 9000
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Solution: Removing paper jams MP800R / MP830 / MP530
  1. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note: Be careful not to touch the components inside the printer.
  2. Turn on the printer and confirm that the Alarm light is off.
  3. Load paper back into the ASF.
  4. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
  3. Open the rear cover to check if the paper is jammed.
  4. Pull out the cassette and check if the paper is jammed inside the cassette area.
  5. Stand the printer with the rear side down, holding the document cover.
  6. Press the tabs together and pull the green cover toward you.
  7. Check if the paper is jammed.
  8. Close the green cover and place the printer back to a normal position.
  9. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  10. Load paper back into the ASF or cassette.
  11. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Thanks
Thiru
Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Garmin Nuvi 200 205 250 255 260 W Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
