Question about Jack Lalanne Power Juicer 250 Watts
Blade wont spin new never been used
Blade wont spin
  • Jack Lalanne Master
  • 4,176 Answers
The blade wont spin even though the mothor is on. I can hear the motor engage but the blade will not move...it has not been used in awhile.
Have you ensured that the blade is securely screwed into the drive motor? Using the two-pronged tool that came with the juicer (or, if you've misplaced it, a DIY solution like two small screwdrivers), make sure that the blade unit is screwed clockwise onto the drive motor. There should be two holes on the inside of the blade unit, at the bottom of the "bowl." That's where you remove the blade unit for cleaning and reattach and tighten it.
Mar 01, 2011 | Jack Lalanne Power Juicer 250 Watts
The blade to my Jack LaLanne juicer was screwed on without the filter in place. Now the blade spins but will not come off. How can I get the blade off?
it came with a blade removal tool,, if not take a dish towel and place it over the blades ,push down and turn it will come off
Oct 19, 2010 | Juicers
Acme juicer #6001, has a new blade, becomes unbalanced...
Hello, First, make sure the screw on clamp that holds the blade down is centering the blade correctly. Also make sure it tightens down firmly against the blade. Wiggle the blade to ensure it is mounted securely. If this doesn' fix it try your old blade again. If your old blade works you may have a bad, unbalance blade but I would suspect he screw on clamp knob may be somewhat worn and not securing the blade causing it to run "out of round" when a piece of vegetable pushes on it. If everything looks good with both blades and the blade securing knob it could be a worn bearing on the juicer. Try wiggling the motor shaft and see if there is any play in it. I have an ACME 6001 that is quite old so I wouldn't suspect the bearings are going. One other thing, does the bowl take 3 to 5 minutes to stop spinning when you shut off the motor? If it does then the shaft and bearing are probalby ok
Good luck with it...gary
Jan 05, 2009 | Acme 6001 Juice Extractor
I bought the juicer at a second-hand store in brand new condition however the crescent tool was missing. To remove the flat blade for cleaning, I use a pair of scissors spread far enough to fit the ends in both holes. Hold the basket still while turning the scissors counter-clockwise untill the flat blade detaches. Easy as that! I ordered the tool, but it hasn't arrived yet. Hope this helps!
Oct 11, 2008 | Jack Lalanne Power Juicer 250 Watts
NutriSource juicer
The support number is:
866-290-1851
Oct 01, 2008 | Back to Basics NS1000 Nutri Source Juicer
Cutting Blade won't come off
I do not have a tool so I used two pen tops, turned the blade counterclockwise while ensuring the filter basket stayed put. It worked well
Apr 16, 2008 | Jack Lalanne Power Juicer 250 Watts
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Red mesh blade
I saw one for auction on eBay. <a href="http://cgi.ebay.com/Jack-LaLanne-Power-Juicer-Replacement-Parts-Kit-1-NEW_W0QQitemZ260179789909QQihZ016QQcategoryZ20677QQssPageNameZWDVWQQrdZ1QQcmdZViewItem"target=_self<Click here.</a>
Oct 16, 2007 | Jack Lalanne Power Juicer 250 Watts
The blade will not spin when the top piece is secure, & I the inside will not come out to clean
There is a roll pin under the flywheel, I you can get the basket off then you pull up on the flywheel , It is the last part before the motor housing. Once you have that off I think you may find that pin is sheared off. It is a common automotive or bearing house part. push out the old and push in the new pin and away you go. The new pin shoud protrude about 3?16 " on both sides of the pin. I hope this helps.
Dec 27, 2006 | Acme 6001 Juice Extractor
Jack Lalanne Power Juicer 250 Watts Logo
74 people viewed this question
Top Jack Lalanne Juicers Experts
Starnley Johnwells
Starnley Johnwells
Cory Koby
Cory Koby
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
