Sharp 25N-S100 25" TV
Problem for Sharp 25N-S100 25" TV
Tv turns on cable is in tv,but no cable or anything black screen
By judge2be on Jun 14, 2009
The tv works and I have the remote it is just when I hook up the cable to the tv I get no cable just a black screen.
Comments:
Jun 15, 2009
- ok all that has been done and we still have no cable connection. We had my daughters tv hooked up to it the day we got our tv.
Jun 17, 2009
- Thanks for all the help unfourtunatly my tv has no place to hook up a dvd or vcr so I took it apart and the connector inside broke off,but thanks anyway.
Best Solution
posted on Jun 14, 2009
Helpful)
gregstlawren
Rank: Wiz
Rating: 83%, 41 votes
First is the cable active? If so make sure all cables are connected propperly from the outside sorce to the tv. If all of the above are ok check the remote menu to make sure that it is acsessing the correct inport source:cable,antenna,hdmi,etc. Also with the change over to digital you may have to have the tv rescan all availlable channels.
Comments:
Jun 15, 2009
- Without beihg there I'm not sure. Here are some ideas. To test the tv try hooking up a VCR or DVD player and see if you get a picture. If so then the TV is not set to the correct input source for cable. If you are using a cable converter box the TV needs to be tuned into the default channel for that box(usually 2 or 3). You can also try rebooting the box,by unplugging from power for a few minutes, if the preceeding has been done or have the cable company do it remotely. If all of the above has been done and cable is being supplied input,either from a dish or a cable company, then I feel that the TV is not on the right setting for cable input. This happens occationally to my wife as I have our TV set up to recieve from four different sources. Good luck!!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sharp 25N-S100 25" TV
Questions and Unsolved Problems for Sharp 25N-S100 25" TV
Do you recommend Sharp 25N-S100 25" TV?
Answer
Answer
It works when it wants and then it goes on and off until I disconnect it and some times goes on... (More)
Answer
when turning on tv it just it like it hisses and goes off ,then you turn it on again clicks and turn... (More)
Answer
* cannot get Sharp 25N - S100 to work properly with Bright Cordless Headphones from Brookstone: Mod... (More)
Answer
My son turned on the television a while back and the power switch fell into the television. We... (More)
Answer
buenas tardes srs , les escribo desde honduras ,por que tengo un problema con mi tv ,tenia... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp 25N-S100 25" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
