Question about Electrical Supplies
Wen generator I removed the fuel **** from my WEN Generator. In the manual it states that to drain the fuel you simply remove the fuel line and turn t to open and the fuel should drain out. When I do that the fuel does not drain. In fact my generator frequently stalls out as if starved for fuel. Does anyone know if that means the fuel **** needs replaced? When I removed it and tried to blow air through it it wouldn't allow the air to flow through it in the open or closed positions. Any ideas?
    Sergeant:
  • 415 Answers
It sounds like the pickup tube in the tank is blocked. Try blowing air back through the fuel petcock into the tank- you may need compressed air to get enough pressure, but that shuld blow out any obstructions.They would still be in the tank though and could cause a problem again.
Posted on Apr 03, 2014
SOURCE: Honda EU3000is Generator is running poorly.
Can anyone help me with the eco-trottle switch when I switch it on it seems to run the same idle whether I have it off or on, what could be causing it not to work, is it a bad switch or I am running 89 octane could that be the problem.
Thanks
Alex
Posted on Oct 09, 2009
harlan301
  • 205 Answers
SOURCE: My Honda generator EG550 wont start. I have a
check your needle seat its stuck. clean and flush your fuel sys in tire sys carburetor to. new fuel and stabilize the fuel. try it but keep a look out for fuel leaking from the carburetor after Wards. if so you'll have to over haul the carburetor
Posted on Oct 15, 2009
sal_kh_sab
  • 98 Answers
SOURCE: Need to replace fuel shut-off valve
well..the whole valve has a place where u can place a 12 or 13 size spanner...and then just twist it..
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Posted on Oct 16, 2009
  • 16 Answers
SOURCE: I need to know what type of oil to get. The manual
if you use a quality 10w30 engine oil will work just fine.
Posted on Feb 11, 2010
miket756
  • 2702 Answers
SOURCE: generator will not run. Can start generator by
you have a blocked up card jet strip carb and clean out all jets
check fule flow from tank as well also clean all filters air + fule
best advice on missing hurricanes,,is move away?
Posted on Aug 14, 2010
My Ryobi 3500 generator starts but will not run
I've found this vid helpful:
https://www.youtube.com/watch?v=5AKKuuXUM6I
* check and clean out air filter.
* drain out old fuel from lines around on/off fuel valve.
* You may need to drain and force flush out fuel filter (I used the carborator cleaner to force out water in filter.)
* re-assemble fuel lines and clamp.
* pull out choke lever to full choke.
* Pull start cord (or start switch) several times to prime fuel line.
* Turn on switches to ready generator for start up.
* Try several times to start.
* If it won't start then spray in carborator cleaner or Generator start spay into the air intake (with air filter sponge removed. Just a short burst is needed.
* Try starting again.
* Pull at least 3 times before spraying any additional cleaner to prevent flooding.
* If generator does not even turn over then there is a spark or ignition problem. Pull the spark plug to clean and check gap. (see your specs for recommended gap.)
* try spray starting method again.
* if your still having problems (with not turning over at all) then you will have to take it to a small engine shop or contact the vendor for service. Check your warranty.
* Once the generator has started. Keep it running till smooth operation. Adjusting the choke to normal open position may take a few minutes till the engine has time to warm up. Install air filter and close up all covers. Allow for a 5 min run and check by connecting a load to the electrical out put. (plug in a saw or other heavy duty power tool) The generator should adjust to the additional load.
Aloha, ukeboy57
May 09, 2018 | Electrical Supplies
A powerhorse 9000 generator the electric starter will not crank with the key. have replaced the solenoid . Can also jump the solenoid and the starter cranks. Is there a fuse on the starter circuit?
manual says there is a fuse, but only covering the 12 volt DC output. There is a number where you can call them on page1.
[PDF]MODEL 9000 16 HP Generator - WEN Products
www.wenproducts.com/store/index.php?route=product/download/download...id...Thank you for purchasing a model 9000 generator. This manual ... Please keep this manual available to all users during the entire life of the generator. 04/06 ...
Questions? Problems?
Please call our customer help line:
(800) 232-1195 M-F 8-5 CT powerhorse 9000 generator manual Google Search
Aug 12, 2017 | Powerhorse 166114 9000w Portable Generator...
I have a 2009 5500 wen generator with 10 hrs on it . Won't run without choke on.
Cloged or dirty filter or no filter or carburetor jet dirty or closed, bad gas some times to.
Mar 31, 2017 | Electrical Supplies
My generator stop after 2 hours what the problem
fuel or oil level
there is a low oil switch that shuts it down wen the sump oil level gets to a dangerous level
if the oil level is correct , it could be that system that has failed
Mar 14, 2016 | Electrical Supplies
My WEN 550 generator has spark, but won't run. I have used some started fluid and it will run a couple of seconds only. I took the carb. apart and cleaned the needle valve, this did not do any good. Still...
I suspect that your carburetor is gummed up by the alcohol laced fuel that you are forced to use. If you leave that fuel in your machine for 3 months or longer. the alcohol absorbs water that will form a jelly like gunk that will clog all of the ports as well as your fuel filter. What happens is the alcohol evaporates and leaves behind the water that mixes with the other additives in gasoline. You are going to have to clean your carb, and fuel filter. Drain all of the old gasoline out. Put fresh in and mix a little SeaFoam or other gasoline additive. The SeaFoam will help dissolve the gunk, and maybe you can get it started to run to see if it will clean itself out. You may still have to dismantle the carb and clean. At the end of the use, drain all of the gasoline out of the tank and leave it dry for storage.
Feb 05, 2011 | Watts Onan Portable Generator - 4000 ,...
The MOTOR on my Wen Power Pro model 5500 runs fine, but the GENERATOR does not come on. any ideas?
The brushes need to be filed smooth or replaced. 15 minute job, remove 2 bolts on the generator cover ( side opposite the pull start ). Remove 2 more bolts holding a black plastic thing about 4 inches long on the left. Behing that piece, there is 1 bolt holding in the brushes ( red and white wire attached ). Remove the brushes and if they're not smooth, file down and reconnect everything. I was done in 15 minutes in the middle of Maine woods thanks to my Leatherman.
Jan 31, 2010 | Watts Onan Portable Generator - 4000 ,...
Where can i find fuel valve for a 3500watt generator by wen besides xmc products
should be on the tank where the fuel line comes out. May be another near the choke adjustment
Dec 04, 2009 | Watts Onan Portable Generator - 4000 ,...
I've got a Power Pro By Wen Power Model 9000 16 HP Generator - kicks on with one pull however shuts down after about 10 min of operation. I've changed the oil and cleaned the air filter. Any other...
Check the gas cap. There is a vent to allow air into the fuel tank as the fuel is drawn out. If this vent becomes clogged, a vacuum can be formed in the tank. This can prevent gas from flowing to the carburetor.
Listen carefully when you remove the cap. If you hear a "whoosh," there likely was a vacuum.
Oct 17, 2009 | Watts Onan Portable Generator - 4000 ,...
My Coleman Generator Model 19G412 has a fuel shut-off screw/valve. It was in the off position. I needed to use the generator, but when I tried to turn the screw/valve to the on position, it would not turn....
explore the possibility of removing & replacing the 'petcock'[fuel valve] in the tank.drain tank,remove gas line,unscrew petcock retaining nut at tank & replace.
Oct 12, 2009 | Coleman Powermate Powermate 5000W...
Coleman powermate 6560 generator won't stay running
coleman powermate 6560 that runs good but wont gennerate power, i tried to exite it by plugging a drill in & holding the trigger in & turnning it backwards but still no power any suggestions?
Aug 17, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
104 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
