Question about Life Fitness Nut Lock, Cranknut, Lifecycle 6500HR/8500/8500HR/9100
The Fit Test and Fat Burn do not light up as an option on my Lifecycle 6500HR bike, they used to work now they don't.
I have replaced the battery and taken the console apart and looked at the board nothing appears bad.
  • Craig Wilkey
    Craig Wilkey Mar 25, 2014
    When you cycle through the options to decide what pattern you want to use on the bike, the Fit Test and Fat Burn options do not light up. It bypasses both of those options. It just continues to cycle between the other options never giving you the option to run the fit test. It worked nine months ago when we bought it as both my wife and I have used the fit test. Now all of a sudden it doesn't work.
  • Life Fitness Master
  • 914 Answers
This really sounds like there is a problem with your console. You might consider contacting LifeFitness for replacement options and or further troubleshooting. 1-800-351-3737 is the contact phone number for them directly.
Posted on Apr 24, 2014
How do I can replace console batteries
Hi Abraham.
What I'm finding in the way of manuals isn't more specific than that the system uses 2 'D' size batteries, which should last about 800 hours. A review here
Lifecycle GX Review Spin Bike Reviews Indoors Fitness (about 2/3 way down the page) mentions that the batteries are in the console and easy to replace. I'd look for a battery door, likely secured with a small phillips head screw, and large enough to accommodate D Cells. It also mentions that there is a low-battery warning at the top of the console.
Hoping this narrows it down for you.
D
Dec 04, 2015 | Life Fitness Lifecycle GX Indoor Cycle
Lifecycle 6500. Why doesn't console light?
The rain seeped in and shorted it.
Nov 17, 2015 | Exercise & Fitness
Screen wont work no display present
Most likely a dead battery,you could also check and make sure that that the sensor for the flywheel is in tact
You'll have to open up the battery assembly compartment on the user lower left side and replace your old batteries.
The LifeCycle GX power requirements are
• Battery: 2 D-Cell batteries
• Approximate Battery life: 800hrs
If this does not solve your issue or you need further assistance please do not hesitate to contact our Technical Support Team online or by phone 888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
Mar 30, 2014 | Life Fitness Lifecycle GX Indoor Cycle
Chain keeps comming off
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
It sounds like you are dealing with a stretched chain. If the chain will not tension any further, you may be looking at the need to purchase a new chain. Use your model and serial number at the following link to order a new chain.
Bike Parts for LifeFitness LifeCycle 9500 Upright Belts Pedals Seats...
Jan 29, 2014 | Life Fitness Lifecycle 9500 Upright...
How do I remove the pedals on a 8500 life fitness recumbent bike
Using a wrench, you remove the left pedal as you would loosen a normal, left hand threaded bolt. The right side is a reverse thread and would need to be loosened in the opposite direction.
Feb 20, 2013 | Life Fitness Nut Lock, Cranknut, Lifecycle...
Where is battery located for LifeFitness' Lifecycle 9500HR
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
Feb 02, 2011 | Life Fitness Exercise & Fitness
How can I determine which Lifecycle I own.. I purchased it second hand (X-Balley) and other then Lifecycle HR on its side I see nothing else discribing it. The battery is in need of replacement. I...
On the bottom the bike frame their should be s# plate. If you need to replace the battery you need to: first remove the foot pedals,then side panels.
they sold run about $20.00 to $27.00 plus S/H
Feb 26, 2010 | Life Fitness 9500RHRT Recumbent Bike
I have a lifecycle model 9500HR, will not turn on.
Some of these units have the main battery ( 6v @ 2.5AH ) inside the bike frame and a 9v in the backside of the upper console
Feb 18, 2010 | Exercise & Fitness
I was told that my lifecycle 9500hr wasnt turning on because of the alternator. I replaced that and the display still wont turn on...any ideas of how to fix this????
You were probably steered wrong. I would expect the battery is the problem.
Use a voltmeter to check voltages.
If the battery is fully down, the alternator MAY have to have the field "flashed" to start generating.
In an automobile the current throu the alternator "idiot light" DOES THIS AUTOMATICALLY.but for your lifecycle I don't know how they do that unless the alternator uses permanent magnets.
Oct 23, 2009 | Veritas Data Lifecycle Manager Win V5.0...
Life Fitness Nut Lock, Cranknut, Lifecycle 6500HR/8500/8500HR/9100 Logo
114 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
sajeel1978 .
Level 1 Expert
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
