Question about Toshiba Office Equipment & Supplies
Printer can not connect to my pc. its not in a file.
Epson work force 645 it use to work.
2 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: Epson R380 connected to PC can't use its driver on MAC OS X 10.5
Make sure that you have only loaded drivers for XP and that they are the latest ones instead of the MAC OS ones at http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=72086&prodoid=63059189&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=17&y=12
Posted on Aug 29, 2009
I have a workforce 645 Epson printer and have no manual. I do not have the plug in for it and was wondering if you knew where to order plug in from?.
You should be able to purchase the printer cable from a local office supply store. Before shopping check to see which kind you would need. The most popular ones are the old kind with tiny pins, but most printers have a small almost square slot. Be sure to check the connection prior to purchasing. If you get the wrong kind you should be able to return it but would be inconvenient.
Oct 15, 2017 | Epson Office Equipment & Supplies
How to rest ink count epson work force 1100
Hello friend,
I found this.
go to www.epson.com/ipr
Agree to the terms, download the reset file and follow directions.
Aug 25, 2014 | Epson Office Equipment & Supplies
Ink pad is at the end of its service life workforce 645
is there a cheat to reset the counter for the workforce 645? similar to the r320 you listed above?
Feb 05, 2013 | Epson Workforce 645 4x Ink MFC
How decrease number of rings for answering
Here is the link to the Printer user's manual.
http://files.support.epson.com/htmldocs/wf545_/wf545_ug/index.html
Look in the Faxing Section under Setting up Fax features.Then look under:
Setting Up Fax Features Using the Product Control Panel
Go to the "Fax Communications Options" section.
Look for "Rings to Answer"
Aug 25, 2012 | Epson Workforce 645 4x Ink MFC
Epson CX5500 does not see cartage replacements as being full ,so will not print !!
Ok
If your printer cartages are full filled and will not able to print. Please follow the following steps-
1- Uninstall the printer driver and disconnect printer from PC.
2- Download the latest Epson Stylus CX5500 Driver 6.5b Windows 2000/XP  from given web link
    http://down3.driversdown.com/Printer/CX5500_W2K_65bE.zip
3- Install the printer driver from downloaded file and connect printer as setup ask.
4- Now remove the cartages from printer and clean the connecting points & inkjet point by soft cloath.
5- While cleaning the cartage's injet points you will must see the ink on cloath. If ink does not see on cloath may be your cartages are dry. try to clean them by little force.
6- connect the cartages to printer. tyr to print.
It will help you.
Nov 22, 2008 | Office Equipment & Supplies
EPSON STYLUS C90 PROBLEM
Let's start here:
Go through file and printer sharing in all three
Ensure that in PC#2 the Epson is the Deafault Printer chosen
Install the printer locally and directly on PC3 to test from the paralell ports. If it works normally, we continue to susperct network glitches.
Are you using the same operating system in all three PCs?
Let
Feb 18, 2008 | Computers & Internet
41 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
