Question about Saeco Vienna Digital Coffee Maker, Espresso Machine
"hi i have a saeco vienna digital esspresso machine that when it is turned on faint bars appear along the top of the lcd screen and then after a few minutes the normal warming up message appears and t
Startup issue
SOURCE: Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Posted on Nov 07, 2007
johnychel
  • 796 Answers
SOURCE: Saeco vienna deluxe
hello
Posted on Mar 01, 2008
mirran
  • 515 Answers
SOURCE: Looking for instructions on cleaning and servicing the Saeco Royal
When you clean the brewing unit wash it with hot water, do not
use any solvent.
Make sure there are no coffee residues on the two steel filters: the upper filter can be removed by unloosening and turning the plastic pin anticlockwise using the tool supplied.
Dry thoroughly each central unit component, fit the filter again and tighten it properly with the screw .
To do a descaling:
Saeco descaler is recommended; however, you can use any non-toxic and/or non-harmful descaling product for coffee machines, commonly available in retail stores. The used solution is to be disposed of according to the manufacturer’s
instructions and/or regulations in force in the country of use.
Never use vinegar!
Best regards
/Mirran
Posted on Jan 29, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco Vienna Deluxe leaking problem and grinder problem
I would repair it, it sounds like the grinder needs to be adjusted (burrs may be dull), and the leak on the bottom may be coming from the small drain hole on the back of the brew chamber. If you remo;ve the chamber you will see the white water valve that the chamber connect to, if you look below the white valve the small chamber in there will be filled with water, below that there is a small discharge use a stit stick or paper clip to clear hole.
Posted on May 12, 2009
  • 1089 Answers
SOURCE: Saeco Vienna Digital does not turn on
Hi
There are a couple of things that might be wrong.
There is a reset button on the thermostat on the back side pof the boiler.
There is a fuse on the power board of the Digital its on the left side of the board.
You have to remove the top to do either and that is fun on the Digital.
Posted on May 28, 2009
Can the LCD screen on my Vienna Digital coffee machine be replaced? If yes, is it something I can do myself? Also, who would have the parts? Thanks!
Yes you can be replaced. Here is a website where you can get parts
http://www.cerinicoffee.com/Saeco_replacement_parts.asp
Aug 18, 2011 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco vienna saying brewunit blocked !
Hi There is a test mode for the Digital and we can see if you have a bad power board. Turn the machine off in back. Push and hold the small coffee button and the menu button (top left) at the same time and while you are holding the buttons turn the machine on. Release the buttons and you should have numbers in the display. If you can push the bottom left button and the machine makes a sound like the motor is moving, turn it off and then back on. If you don't get the message now you should really clean and lube your brew unit.
Jun 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
Hi
May 01, 2009 | Saeco Vienna SuperAutomatica Coffee...
Our Saeco Vienna deluxe had a couple of problems: the grinder wouldn't stop grinding..coffee all over the place...stopped it cleaned it and it's ok. The other problem is that it takes forever for a small...
What does the coffee produced taste like, is it bitter and watery, is there any creama on the espresso shot. Try adjusting the grind and the coffee level, maybe a little coarser.
Mar 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Is there anywhere in Ontario that I can get a replacement portafilter for my Saeco Gran Crema esspresso machine?
Try to contact Saeco Canada to see if they can help you.
Saeco Canada Ltée
8145 Boul. St. Laurent
Montreal-Quebec
H2P 2M1
Tel: +1 514 3855551
Fax: +1 514 3855585
E-mail: info@saeco.ca
Visit the Web: www.saeco.ca
Jul 29, 2008 | Saeco Vienna De Luxe Espresso Machine
I have saeco coffee machine cap002a ,when i turn on the machine the screen show self-test temper. error ,it's not working at all!
I think you need to take it to a Saeco service center.
It can be the circuit card that is the problem.
Apr 21, 2008 | Saeco Vienna Digital Coffee Maker,...
Superautomatic esspresso machine problem
You will probably find that the small holes in the filter are blocked with grounds of a perfect plug like size.
I carefully removed the filter plates and cleaned them thoroughly on mine and all was well.
Dec 17, 2007 | Saeco Vienna SuperAutomatica Coffee...
I had this problem on my Saeco Vienna Digital a while back. I read somewhere just to keep on ventilating, even if it took 20 hoppers of water. Sure enough after about 16 cycles, I heard a change in the noise and looked to see the ventilate sign was gone.
Oct 24, 2007 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna Digital Coffee Maker, Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
