Question about Sharp Aquos Televison & Video
Tv not turning on
Power on, red led ok, push on button led turns green then back to red.no click from start up relay, relay and transformers tested ok.
    Top Expert:
  • Sharp Master
  • 74,185 Answers
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 24, 2014
I am having problems with Lionel Fastrack layout. When I put electrics to the layout the green light comes on and I think all is ok. However as and when I start to increase the power the red light A.
remove all the cars and engine from tracks and try it, if green stays on add one car back to track at a time and try it , when light turns red , the last car added is the problem
Mar 20, 2016 | Crafts & Hobbies
Polaroid tlx-03210b no power to backlight
I have the exact tv model and the exact problem.. replaced bad caps and still the same problem. no voltage on the backlight plug. and the blinking red led on the board.
Aug 07, 2012 | Televison & Video
RCA D40W20 rear projection tv. Power supply problem. Pressing the power button causes the small green LED on that same button to illuminate for a short while. The LED then turns off. It does this about...
HI:
Check all the connections around the Flyback transformer, the click you are hearing are relays not ttransformer. You should have or someone check all the connections in the Horizontal circuits as well. Also there is a capacitor on this same board that may need replacing is a 2200uf 10volt capacitor replace it with same value but increase the voltage rating to 16 volts..
Sep 24, 2011 | RCA Televison & Video
Stays in standbye and will only flash green (power on) twice before staying in standbye
The 6 inverter transformers on the bottom of the picture is the problem and what need to be tested.
Unplug the 6 wires that goes to the LCD screen. Use a multimeter to test for resistance from each output plug on the board. The one without the resistance is the bad one.
If this doesn't locate the bad one this way, Each plug should give out DC voltage if working properly. Test each plug for voltage.
The TV will automatically turn off in a couple of seconds like before. You'll have to keep pushing the power button to test each output plug for voltage.
Soon as you find the bad Inverter Transformer, just solder in a new one and the TV should work fine after that.
The part # for the Inverter Transformer is LTZ2PC0MS008.
Here's two places to get them:
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
Apr 23, 2009 | Televison & Video
No picture or sound
Remove the rear panel. With the TV on you should see a red LED near the center of the PCB. There should also be 5 green leds, 3 to the left a 2 behind. If there is no red leds, check the fuses. If there are no green leds or maybe 1 or 2, disconect PSD5. It's a connector on the left side of the power board that connects to the audio board. It's the 3rd on fro the back. It's labled. With that disconected, turn on the set and look for the green leds. If all 5 light, the power supply is OK and you have a problem beyond that. If they don't all light you have a bad power supply.
Jul 21, 2008 | Hitachi 50EX20B 50" Rear Projection...
42PF9956/37 SHUTSDOWN...
Ok. I got my tv back on.
I pulled off the back cover and found the relay that was clicking.
I have two blue relays next to each other that click when the power is pushed.
I placed a hair dryer over the relays for about a minute.
Once heated up, it only took 4 tries to get the TV to stay on.
Jan 03, 2008 | Philips 42PF9956 42 in. HD-Ready Plasma...
Progressive power up problem
Yeppers. Sounds like the standby power supply has a bad capacitor in it and the regulator Ic is defective. These parts should only be replaced by quilified technician as there is very high voltage inside these sets. Good Luck
Jun 14, 2006 | JVC AV-K29MX1U 29" TV
Televison & Video Logo
35 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
