Question about Life Fitness T3 Treadmill with Advanced Console
How to reset t3i after service
I had a startup error and have fixed everything but i believe because therror code is still there it is still stopping. how do i clear the code?
How to repair fixing unit of copier machine it replies Error C6000
Hi
I assume that your printer is a Kyocera Mita and probably one from their KM range. I proceed on this basis.
It is possible to reset this using U163 in Maintenance Mode to reset the code. If the error still persists it is to do with the fuser unit. I found many error codes for many printers and the particular page of relevance to you is here:
Error Codes Kyocera Mita KM2540 Code C6000
It is for the KM2540 but you can change models easily using the drop down menu in the centre of and near the top of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 03, 2014 | Office Equipment & Supplies
Tip
Error code CANON iR2270 / iR2870 / iR3570 / iR4570 ...
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E713 communication error for finisher
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Regarding most common errors related to fixing section:
E000 The temperature of the fixing assembly is abnormally high.
0001 While startup control is under way, the reading of
the main thermistor is less than 30 deg C
continuously for 200 msec or more 1 sec after the
start of power supply.
the main thermistor is less than 70 deg C
continuously for 200 msec or more 2 sec after the
the main thermistor is less than 120 deg C
continuously for 200 msec 6 sec after the start of
power supply.
The startup control does not end 30 sec after the
Reset the condition in service mode:
COPIER>FUNCTION>CLEAR>ERR. Replace the
main thermistor. Replace the DC controller PCB
E001 The temperature of the fixing assembly is abnormally high.
0000 The reading of the main thermistor is 250 deg C
or more continuously for 200 msec.
0001 The hardware circuit detects overheating of the
main or sub thermistor for 200 msec.
Reset the condition in service mode: COPIER>FUNCTION>CLEAR>ERR. Replace the
E002 The rise in temperature of the fixing assembly is faulty.
0000 While startup control is under way, the reading of
the main thermistor is less than 115 deg C
continuously for 400 msec 1.3 sec after it has
indicated 100 deg C.
the main thermistor is less than 150 deg C
indicated 140 deg C.
E003 The fixing temperature is too low after a standby state.
0000 While regular temperature control is under way,
the reading of the main thermistor is less than 140
deg C continuously for 400 msec or more.
E007 The rotation of the fixing film is faulty.
0000 While the fixing motor is rotating, the marker
signal is not detected for 6 sec with the reading of
the main thermistor indicating 100 deg C or more.
REPLACE FIXING FILM ASSY(HEATER)
To enter service mode:
* 2 8 *
on Aug 03, 2010 | Office Equipment & Supplies
How to clear error code e000002-0000
Hi
I have found a list of error codes for your machine here:
Error Codes Canon iR2270 Code E002 0000
and it looks as if your error is described as follows: Description The rise in temperature of the fixing assembly is faulty
While startup control is under way, the reading of the main thermistor is less than 115 deg C continuously for 400 msec 1.3 sec after it has indicated 100 deg C. While startup control is under way, the reading of the main thermistor is less than 150 deg C continuously for 400 msec 1.3 sec after it has indicated 140 deg C. Remedy Reset the condition in service mode: COPIER>FUNCTION>CLEAR> ERR. Replace the main thermistor. Replace the DC controller PCB. You can check all error codes on this page by choosing the relevant code from the drop down menu at the top right of the page.
Cheers
Nov 24, 2014 | Canon IR 2270 Digital Copier RECONDITIONED
How to fix err20 for Canon Rebel T3i?
Error code 20 refers to a detected mechanical problem
Error code 30 refers to a detected shutter problem
-Turn the power switch to < ON > to turn on the power.
-Remove and re-install the battery.
-Use a Canon lens.
-If the instructions above do not solve the problem you may need contact your nearest Canon Service Center.
Aug 03, 2014 | Canon Cameras
Dropped laptop, Error codes 2000-0142 and 2000-0123
Remove the HDD and test. Replace if necessary.
Nov 29, 2012 | Computers & Internet
Cannon Error Code 0121
I believe the copier is similar to the CLC-1120, if it is the 1120 book says that the E-000 is a fixing error. The 01 is upper heater and the 21 is for the temperature not increasing 3 degrees after 4 minutes after being turned on.
Check for paper stucked on the fusor roller
It can be paper stuck under the upper Thermistor or a dry joint on the thermistor you will need to clear the error from service mode to reset it and you can check analog in display of the service mode to check if the thermistor is working ok.
I have also seen cases where the customer would open the door really fast and pull out the transfer frame unit before the machine actually powers off. This would cause a fuser error code when in fact everything was fine.
I have also have had bad connectors and needed to replace the back frame connector and/or fixing frame connector. In some cases we could fix by inserting spacers so the connectors would go deeper into each other.
Also, check your Heat lamps. Good luck.
Jun 07, 2012 | Canon CLC 1150 Color Copier
My printer has an error with error code E42 how can i fix that? pls help..
E42 I believe is a scanner error. Try first to switch it off for 30 minutes and try. Else re-attach the ribbon cables of the scanner and try again.
If error still persist then do a factory reset as per below
1) Switch off the printer
2) Press and hold the Stop/Reset button while switching on the printer.
3) With the Power LED lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) Release the Power button and the Stop/Reset button that will put the printer in service mode. Just wait for the menu selection.
5) When the LED lights in green, press Stop/Reset button to specified number of time(s)
according to the Legend below.
Legend:
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset procedures below.
5 times Orange Destination setting See Destination setting procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jul 13, 2011 | Canon PIXMA MP160 All-In-One Printer
How to fix error code. STOP: 0x0000C1F5
This issue occurs because the Common Log File System (Clfs.sys) driver does not fix the $TxfLog file when the file is corrupted. In addition to the Stop error message, Windows Vista may not start during startup until the offending disk is removed from the computer.
Support for Windows Vista without any service packs installed ended on April 13, 2010. To continue receiving security updates for Windows, make sure you're running Windows Vista with Service Pack 2 (SP2).
To fix this allow Microsoft Windows to update you to the latest service pack.
http://windows.microsoft.com/en-US/windows7/Install-Windows-updates
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Sep 18, 2010 | Computers & Internet
Open Questions:
See all Life Fitness T3 Treadmill with Advanced Console Questions
Life Fitness T3 Treadmill with Advanced Console Logo
Top Life Fitness Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
sajeel1978 .
Level 1 Expert
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
