Question about Invacare Lynx 3-Wheel Lightweight Portable Scooter
Rio 4 lightweight light flashes but doesn't drive
The battery is fully charged but the scooter sometimes does not drive - I thought it may be the large bunch of keys dragging on the lock but it still happens even with just one. It seems to be flashing some sort of code maybe? I don't have any way of finding what it may mean. No luck with downloading one. Can you tell me what the flashing codes are please I am not using it as I can't risk getting stranded.
  • Invacare Master
  • 1,263 Answers
Hi, please can you tell the number of flashes before a pause then it starts flashing again ?
Regards
Rob
www.gewizrepairs.co.uk
Posted on Mar 24, 2014
2 Suggested Answers
  • 5370 Answers
SOURCE: Invacare Meteor Hillclimber. Charger shows
In the batteries there are cells.That cells gets charged.If the internal cells get dead , then battery will actually charge but will also loose its charge quickly. --------- To confirm this you can test the battery charge by meter.When you face low charge problem in decline, at that time check the battery charge.f the voltage shows less, that means battery is loosing its charge quickly.If the battery is loosing its charge, that means cells are dead inside.This has to be confirmed by another set of battery.------ Thanks.Helpmech.
Posted on Jun 05, 2011
Aquasoothe travelite scooter, the batteries are fully charged, the battery gauge is showing full, but the battery light is flashing. It flashes 7 times then pauses, we can't get the machine to move or...
Response to similar query in 2011.
http://www.fixya.com/support/t5751777-aquasoothe_travel_lite_instruction
not my words. The link to the pdf for this is http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
you want page 22.
Problem Check Point
The driving of the wheelchair is too slow or insufficient, the status
indicator lamp flashes slowly Batteries are exhausted and need to be recharged
1 flash The battery needs charging or there is a bad connection to the battery. Check the connections to the battery or charge batteries.
2 flashes There is a bad connection to the motor.
Check all connections between the motor and the controller.
3 flashes The motor has a short circuit to a battery connection.
4 flashes Freewheel is engaged.
5 flashes Not used.
6 flashes The controller is being inhibited from driving; this may be because the battery charger is connected.
7 flashes A throttle fault is indicated. Make sure that the throttle is in the rest position before switching on the scooter
8 flashes A controller fault is indicated. Make sure the controller connections are secure.
9 flashes The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the controller connections are secure.
The-Active-Light
does not function,
the Battery/
Status indicator
flashes rapidly.
Count the number
of flashes:
10 flashes
An excessive voltage has been applied
to the controller. This is usually caused
by a poor battery connection. Check the
battery packs and controller
connections.
Sorry wasn't sure how much space they give you for answers. :)
Oct 11, 2013 | Health & Beauty
We have fully charged the battery but when we pull the paddle to move it doesn't go
Reengage the wheels again then give it a slit push you should fell some resistance .seems the freewheel is not fully in
Apr 24, 2013 | Electric Mobility Mobility Electric Power...
Victory 4 pride mobilty scooter,the charger dont seem to charge up the batterys. is the charger faulty.
DID YOU HAVE THE MANUAL? YOU CAN FIND THE RIGHT WAY TO CHARGE IF IT DO NOT CHARGE AT ALL MAY BE BATTERY IS BAD OR IF IT DO NOT CHARGER NOTHING PROBABLY THE PROBLEM IS THE ADAPTER, TRY TEST IT USING VOLTMETER OR POWER TESTER.
CLICK HERE MANUAL
Aug 27, 2012 | Pride Go Go Ultra 4 Wheel Travel Scooter
Battery full on Ascot Mobility scooter but wont start
mcdevito75 here, Double chek the connection at the battery and motor.
Jun 22, 2010 | Electric Strider Maxi 4 Wheel Mobility...
My invacare auriga 3 wheel scooter will not work got 2 new batteries but will not power light flashing on charger as if charging but when put key in not even lights comne on
hi,
Can you clarifly what happens you plug in the charger in ?
Are you sure the fuses on the battery leads are okay ? the is one for each battery like a glass container ? check they have not blown, check the connections to the battery , are they tight ?
Regards
gewizrepairs.co.uk
Nov 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Hogh - low speed switch is incorrectly wired , but i dont know how it should be wired - Pride Hurricane scooter
Hi, I take it been taken then, do you get a error codes ?
see below
DIAGNOSTIC FLASH CODES
The diagnostic flash codes for your scooter are designed to help you perform basic troubleshooting quickly and
easily. A diagnostic flash code will flash from the status LED in the event one of the conditions listed below
develops.
NOTE: Your scooter will not run unless the flash code condition is resolved and the scooter has been
turned off, then turned back on.
Any electromechanical device occasionally requires some troubleshooting. However, most of the problems that
may arise can usually be solved with a bit of thought and common sense. Many of these problems occur because
the batteries are not fully charged or because the batteries are worn down and can no longer hold a charge.
FLASH CODE CONDITION SOLUTION
! (1) Battery charge is low. Charge batteries as soon as possible.
! ! (2)
Batteries are too low to operate the
scooter.
Charge batteries.
! ! ! (3)
The scooter’s battery voltage is too
high to operate the scooter, or the
charger is still connected to charger
port.
Unplug charger and/or turn key off, then
back on again.
! ! ! ! (4) Current limit time out.
Turn the scooter off for a few minutes,
then turn your scooter back on.
! ! ! ! ! (5)
The manual freewheel lever is in the
(forward) freewheel position.
Remove the key from the key switch,
then push the manual freewheel lever to
the (rear) drive position, and restart your
scooter.
! ! ! ! ! ! (6)
Throttle control lever not at center
position at start up.
Return the throttle control lever to center
position, turn scooter off, then back on.
! ! ! ! ! ! ! (7) Speed pot error.
Contact your authorised Pride Dealer for
assistance.
! ! ! ! ! ! ! ! (8) Motor volts error.
assistance.
! ! ! ! ! ! ! ! ! (9) Other internal errors.
Regards
GeWiz.
Oct 20, 2009 | Pride Hurricane 4 Wheel Personal Mobility...
Invacare Lynx 3-Wheel Lightweight Portable Scooter Logo
79 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
