Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Medx500xwo I need to open the bottom front panel to see if there is lint inside the dryer body.
    Sergeant:
  • 446 Answers
If you take a putty knife put it in the crack slide either way till it stops pull it out move to where it stoped and push straight in that will release the clips
Posted on Mar 24, 2014
reg501
  • 413 Answers
SOURCE: lint trapped inside dryer housing
SHUT OFF POWER AND GAS
1. Begin by opening the door removing the two screws on the left side of the door opening.
2. Then remove the screws that secure the door hinges to the cabinet. Lift off the door (may take some wiggling)
3. Grasp the outer top sides of the front panel and pull toward you.
4. Lower the front panel and lift off.
5. At each top corner remove the screw and latch that hold down the top.
6. You should be able to do the rest from here.
Posted on Jun 14, 2008
captaynkyrk
  • 170 Answers
SOURCE: dryer making squeaking noise
Usually there's a kick plate or panel at very bottom front of dryer. Take that off, then you can take the front off and then the top to look inside.
Posted on Jul 05, 2008
SOURCE: I have a build up of lint that is keeping the
Disconnect from electric
Remove the back cover
Clean all lint from heating element and ducting to it.
Posted on Oct 14, 2010
  • 3074 Answers
SOURCE: an ring fell out of jacket pocket while jacket
You will need to remove the hinges, they lift up and out once screws are removed, the the two white plastic pieces with the screws these are for door reversal, then the front panel lifts off. Good Luck Tim
Posted on Nov 06, 2010
Testimonial: "quick response, great help"
SOURCE: How do I remove the front panel?
I would like to chance my gas dryer from natural gas to LP. bought all the neccesary items . how do I get to the orifice on my maytag atlantis mdg 8400 through the front or back ?
Posted on Jul 14, 2011
How do I get into my whirlpool duet front loader dryer to clean the lint out
Hello. First, turn the power off to the dryer or remove the power cord from the AC outlet. Next, locate the 2 screws in-between the upper and lower front panels and at the bottom front of the dryer--there will be 2-3 screws, usually 1/4 inch hex head, and remove them--use a magnetic nut driver, it makes it a whole lot easier! (note:sometimes, to replace the panel, you have to push up on the bottom of the panel hard to get the screw holes to line up again.) Set the panel aside. Open the dryer door and remove the lint screen from the holder. Close the door. Next, notice the blower housing cover, pic 3, #45, lower left corner. There should be 3-4 screws holding the cover to the blower housing. Remove the screws and cover--use caution--most metal edges inside a dryer are unfinished and razor sharp--akin to putting your hand inside a box of razor blades(ask me how I know this, lol). Remove any lint build-up inside the cover with a vacuum. Again, using a vacuum, suck out any lint from inside the blower housing and fan as best you can. Take care to not damage the fan blades! Now, try to remove as much lint build-up as you can with the vacuum. Be especially careful when vacuuming around the mouth of the heater element. Do the best you can. At this point, re-assemble the dryer using the reverse of assembly. If there is still a lot of lint inside the cabinet and you can't reach it--STOP! In order to remove the remaining lint requires removal of the front bulkhead(large metal plate that supports the front of the drum), drum belt, and drum from the cabinet. This is INVOLVED and can be very difficult to re-assemble if you have never done it before. Call for service. I hope I helped you!
Oct 02, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I want to clean the inside of my DLG0452W. Hasn't been done in 10-11 years. This is all part of venting. It properly. Can I take the bottom panel off?
i looked up your model and it looks like you haave to remove the top panel and then the front panel to get to the inside cabinet,if on the front you do have an access panel on the bottom then yes you want to remove the bottom front panel,pull out the lint filter,remove the duct that the lint filter slides into and clean that,then with a shop vac vac out the cabinet,then set the shop vac up to blow and blow all the lint from the back forwards and blow off the motor,this way you don't have to pull the belt and drum.when that's done go to the back and remove the vent line from the dryer,if it's a long run to the outside,go outside and make sure the duct is open,no cage or screen blocking it,go back inside,stick a leaf blower into the vent line and blow it out.do this once a year and your dryer will run better and last longer but mostly you won't have a fire.hope this helps.
Oct 08, 2013 | LG DLG0452W Gas Dryer
How do I clean the lint from the dryer past the lint trap?
you need to unplug the dryer,then with a putty knife stick it in between the top panel and the front panel and there are clips one on each side that you release with the putty knife and remove the front panel or you could have two 5/16 inch screws on the bottom of the front panel but i believe your model has the clips,when you remove the front panel you need to clean out the duct that the lint filter slides into,vac out the inside cabinet where the motor is,put it back together then pull out the dryer and remove the vent line from the rear,if it's a long run to the outside you can stick a leaf blower inside the vent line and blow all the lint out to the outside hood,before you blow it out go outside and make sure the hood is clear then blow out the line,
Oct 30, 2010 | Maytag HYE3658AY Electric Dryer
Can't find the lint cleaner
In order to locate the lint filter for your dryer you must first remove the door. to do this first open the door and remove the screw that hold the hinges to the front of the dryer. once the door is off. there are 2 screws at the bottom of the front access panel. once the screws are out the panel will come off of its brackets by pulling the bottom out first. once this panel has been removed you will be able to see the inside of the dryer and the lint screen is directly behind this panel on the LEFT hand side and it will just pull straight out. if you need a new one the part number is 33001808.hope this helps
Thanks
Oct 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a maytag model HYE3657Ayw how can I open it up to clean lint inside the cabinet
first pull it away from the wall, then clean out the lint from the vent, then you will need to pull the front panel off, you should find 2 screws inside the door opening, and then you will need to pop loose the tabs from the bottom
Jul 10, 2009 | Maytag Neptune MCE8000AY Electric Dryer
HOW DO I REPLACE THE BELT
2 screws at bottom front, pull out slowly from bottom first. Remove the door switch wiring. Then you will see the rest. Note how the belt rides thru the pulley and onto the motor. Belt # 341241, available for $11.99 at timerking.com. Hope this helps!
Jan 07, 2009 | Estate TEDS840JQ Electric Dryer
Install dryer belt
more information needed to specifcally match the model
however dryers are all similar so
generically, UNPLUG dryer
A:top mounted lint filter (kenmore maytag(New))
  • remove lint filter
  • remove screws in lint filter housing
  • with putty knife or other flat blade depress lock tabs at front corners of top body panel
  • tilt top panel up
  • remove screws 1/3 way down each side, remove door switch wires
  • remove front panel set aside
B:dryers with screws at bottom of front panel (maytag speedqueen)
  • remove screws from bottom of front panel
  • tilt front panel up
  • remove door switch wires
All
  • pull drum forward & out
  • examine drum felts, rollers, and slides for wear replace if worn
  • wrap new belt round drum at old wear marks
  • insert drum
  • wrap belt round motor pully
  • pull tensioner pulley hard to end of travel against spring
  • wrap belt round tensioner pulley
  • release tensioner
reassemble
Oct 19, 2008 | GE Dryers
Drum bearing
most dryers
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
maytag
  • unpug dryer
  • remove screws from bottom bend of front panel
  • lift front panel off
  • sent front panel aside
pull tensioner pully off bellt
pull belt off motor pulley
pull drum out forward
felts installed on drum edges can be examined for wear, as should roller support bearings
reassemble in reverse order
Different dryers may have: nylon glide plates, felt bearings rubber tired roller bearings or any combination of the above.
Local parts guy will have the parts as they are common to many dryer models.
Sep 06, 2008 | Dryers
Lint trapped inside dryer housing
Jun 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
DRYER WON'T HEAT.
ok facing the drier front open thee door and remove the bolts around the door panel there are four of them two on each side then grasp the front about 3 inches down on either side to disengage the side retain clips tilt the panel back toward you and lift it up to disengage the bottom clips remove the front panel and if you need to lift the top remove the screws on the hooks on either side at the top and take the hooks off then you can lift the top that should give you plenty of access to do what you need to do
Jan 20, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
140 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
