Question about Tablets & eReaders
Factory data reset proscan plt8015-k tablet with no volume buttons?
I cant do it with no volume button?
nliwilson
  • 114 Answers
SOURCE: Mobits A221 tablet pc reset
You can forcibly power off the unit in exactly the same way you can any PC, hold down the power (on/off) button for 6 seconds.
Technically it's actually 4 seconds but 6 seconds gives you a margin of error. Unfortunately Microsoft make poor quality products and Windows XP Tablet Edition is no exception, Keep a a note of this procedure as this won't be the last time you need it.
Posted on Dec 04, 2007
TechyDrood
  • 2072 Answers
SOURCE: Cant turn on my Craig Android Tablet...
Is it charged, does it charge properly? It may just be dead.
Posted on Dec 30, 2012
  • 8068 Answers
SOURCE: I have a Tablet that was giving to me from a friend but she has forgotting her password and its lock at the main screen. I tried by pressing the reset button as well pressing the volume button but not
Take it back to the generous person who gave it to you and ask her to try hard to remember the password or to unlock it for you so that you can change the pattern. Or contact the manufacturer's service center.
Posted on Dec 06, 2013
  • 18 Answers
SOURCE: How to do hard reset on tablet without volume
If it can boot, use Backup & reset option on the latest versions of Android or Privacy under older versions
Posted on Apr 22, 2014
newfie_todd
SOURCE: Proscan PLT8235G stuck on blue screen. Reset button just shuts tablet off, and problem still remains.
I have had the same issue with this tablet. After weeks of looking around on the net i have found a way to reset the tablet to factory settings when the power and vol down button will not work.
1. Download the firmware from the proscan website. http://www.proscanvideo.com/item.asp?itemnmbr=PLT8235G.
2. unzip the file and copy the files update.zip recovery.img and factory_update_param.aml to an external micro sd card.
3. Plug the tablet in and insert the sd card. Press the power button to see the battery icon then press the power button 5 times. Then let it run for 4 minutes and it should be set back to factory settings.
****NOTE***** If it fails to update then you still have the access to the recovery menu where you can do the factory wipe and still reset it.
Hope this helps.
Posted on Apr 27, 2014
Reset my proscan notebook plt1035
I cannot find that model number is it a tablet or is it running windows?
if tablet
How to reset Proscan PLT722 when you forgot your password or unlock pattern. How to remove unlock pattern on your Proscan PLT722 android tablet
To reset this tablet is a little bit tricky, because there are no physical Volume keys on the device, but we have a "hidden" RESET hole (on the side of the tablet) and using this we can easily do a factory reset on the tablet to remove the password and get access to it.
Using the Hard Reset (Factory Reset)
If you want to restore your Proscan Android tablet to its original condition, use a Hard Reset (Factory Reset) to initialize it.
1. Turn the power off.
2. Find the tiniest RESET hole on the side of the tablet next to the micro USB charger port and use a paper clip or similar tool to click it, press gently the RESET button in the hole. While you are pressing the reset button press and hold the Power button also until the Proscan logo comes up and the Android robot is displaying on the screen. (Note this is not the RESET hole on the back of the device.)
3. Release the Power and the reset button.
4. To get into the Android recovery menu you have to click it push it down again the tiny little RESET button in the hole and the POWER button together. Keep pushing the two buttons until the recovery menu displayed.
5. To highlight the options use the paper clip and press the RESET button to move down the highlighter bar until you get to Wipe data / Factory Reset. Press the POWER key to get in the next menu.
6. Move the bar again using the reset button and highlight Yes -- delete all data and press the POWER button.
WARNING
If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to backup any important data before performing a Hard Reset.
Proscan PLT722 soft reset or restart the device when it is frozen If device is hanging, use a small pin or paper clip to press Reset hole on the back of the device, it will forced shut down and the device will power on again.
Proscan PLT722 factory reset from the menu Factory data reset - Reset your settings to the factory default values and delete all your data. If you reset the tablet this way, you are prompted to re-enter the same information as when you first started your Android tablet.
Go to Settings > Backup & reset > Factory data reset > Reset Tablet and confirm
All data will be deleted!
Check the software version on your tablet: Settings > About tablet> System updates > Check now.
NOTE: Your personal data from internal phone storage - including information about your Google account and any other accounts, your system/application data and settings, any downloaded applications and your DRM licence - might be lost in the process of updating your phone's software. Therefore, it is always recommended to backup your personal data before updating your phone's software.
Jan 23, 2018 | Tablets & eReaders
My sister locked his tablet with a password and now he cant remember what the unlock code is. its the type of code you unlock by making a pattern with your finger.
You have to reset it to factory default just follow those steps:
1. shutdown the tablette
2. hold volume up button and press the power button
3. when manufacturer logo come realise the power button but keep hloding the volume button to get into recovery mode
4. in recovery mode use volume up/down button to navigate and the power button to select
5. choose WIPE DATA / FACTORY RESET than select YES .... wait a moment then select WIPE CACHE PARTITION
6. finale step select REBOOT
keep in your mind the all data in the phone will be erased (apps & games)
ALL DONE!!!!
Mar 05, 2015 | Proscan 7-Inch Android Internet Tablet,...
ALL DONE!!!!
How do I decrypt a storage password for a PLT7100G(DG)
try a factory reset
1. shutdown the phone
3. when manufacturer logo come leave the power button but keep volume up button to get to recovery mode
keep in your mind all data in the phone will be erased
Feb 25, 2015 | Proscan 7-Inch Android Internet Tablet,...
My proscan tablet is locket and ican't unlocket it what can i do???
Since I don't know which exact Proscan Tablet you have, here is how to restore the PLT9045K.
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
Jul 12, 2014 | Proscan 7-Inch Android Internet Tablet,...
How to unlock proscan android tablet plt8015-k-b
To perform a factory reset, you will need to do the following: -turn of the tablet -press the following and hold: power button reset hole -hold until you see android logo screen -poke the reset hole to navigate to `wipe data` or `factory reset` -select using the power button -select delete all user data -restart the device -choose restart/reboot after reset This procedure will delete all apps and data on your table
Jun 30, 2014 | Proscan Recertified - PLT7035 4GB NAND...
Help how do hard reset my proscan tablet plt7035 i for got my pattern to unlock it
1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
All info on tablet will be deleted but not the info in the SD card
The tablet will complete the hard reset process and reboot into a factory default state.
Oct 19, 2013 | Proscan Recertified - PLT7035 4GB NAND...
I have a Proscan PLT7223GK6 Android tablet, and I can't seem to get it unlocked. I am not using a pattern to unlock the device. Is there a way to reset the password without resetting the whole device?
Tablet PLT7223GK6-B ((Solution)) Funtional
1. Power off the Tablet.
2. Press and hold the Volume Down button of the device, then a press and hold the Power button.
3- when you leave proscan logo, you can release the botton
4- leaving snowman Android, Press and hold the Volume up button, then Press and hold the power button.
Until you see the menu.
up / down- escojen the option to make
power button- the selecionan
5- Wipe Data / Factory Reset
6- Reboot System now
May 17, 2013 | Tablets & eReaders
I have to reset a proscan tablet plt7044k that is locked up with a pattern password that i have forgot do you know how toreset it
Steps on how to reset the Proscan PLT7044K 7" android tablet.
1. Hold down the power and volume up buttons at the same time until you see the android logo then release both buttons.
2.Hold down power button then push the volume up button once for the reset menu to appear.
3.Use the volume down to select the factory reset to reset all data.
4.Reboot the device after reset has completed.
Mar 29, 2013 | Tablets & eReaders
Tablets & eReaders Logo
273 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
