Question about Electronics - Others
Flash drive not detected, not accessible
I have an ADATA 32 GB USB 3 flash drive which until recently was working perfectly for backing up data. Now when I plug it in the light flashes continuously and the drive does not open or show in Explorer. I have tried it in several computers with the same result. AT first the problem started out as intermittent (more fails than starts) but now it ndoes not seem to matter what I do. As far as I can tell the terminals in the USB plug are clean and undamaged, and it has not been wet or suffered any mechanical damage. It is a robust rubber covered pen drive. I would like to at least recover the files of the drive and then try to reformat it for further use.
    Sergeant:
  • 376 Answers
You'll need to try a file recovery program to attempt file recovery.... Bad Copy Pro 4.10.125 works great for me. Then you will need to reformat the card to fat32 file system. That software is usually available from the manufacturer. It sounds like you have a defective card but you can try the above to see what the results are.
Posted on Jun 22, 2014
Beni S-P
  • 1006 Answers
SOURCE: transcend 1 GB removeable Pen drive is not detected
The pen driver is ifected with virus.Just format it with CMD and ur problem will be solved
Posted on Nov 02, 2007
bijoybakal
  • 57 Answers
SOURCE: pen drive problem
hi.
Vista doesnt recognize all pen drives. only few like Sandisk, Transcend etc get recognized. Even brands like kingston don't get recognized. so to make them work install the driver for the pendrive. If you specify the brand of your pen drive ..i will try to help out with a driver .
regards
bzoy
Posted on Jan 09, 2008
  • 30 Answers
SOURCE: Imation Swivel Flash Drive Cant detect
Check it another computer. If drive is still powerless, then you most likely have a failed flash drive.
Posted on Mar 15, 2008
SOURCE: USB Flash Drive (Transcend Jet Flash 1gig) not detected
use device not recognized
Posted on Jul 31, 2008
SOURCE: My computer wont detect my USB flash drive
i) try to put the usb drive in some other ports(such as usb port present on the backside of yur computer tower) and check whether your computer is detecting the drive.....
ii) if not there is sureluy some problem with ur usb drive, replace it  or repair it..., you can even try putting another usb drive(if you have an spare one...)
Thanking you
M. Sridhar
Posted on Dec 31, 2008
How to dismantle my ADATA Classic CH11
Use something similar to an ATM card and pry open the bottom face. There are no screws but the faces are glued pretty good so it will take some effort.
Once the face is off, its pretty simple. About 4 screws to free hdd from the shell and then disconnect from the data connector
Aug 14, 2015 | ADATA CH11 500 GB USB 3.0 External Hard...
How to I clean out adata nobility nh92 so I can start updates again?
Check in "Properties" i if your external hard dreive is really full. If it is full, check entries; probably about half of your hard drive is useless backup. Delete unnecesary files and folders so it might continue backing up.
Aug 24, 2014 | ADATA A-DATA Nobility Series NH92 500 GB...
It can't be initilized
All I can suggest is to check the connections of your USB and Power Supply. If everything is ok, you should find someone specialized in recovering data from Hard Drives with access problem.
Jun 17, 2014 | ADATA A-DATA Nobility Series NH92 500 GB...
Hi there! I got this PQI i221 8GB Flash drive for 3 years now of perfect working condition until lately, the light that used to flash during normal operation failed to lit up. It has been detected on My...
You probably need data recovery help to get the data off your flash drive but first try a free program like Recuva to save your data: http://www.piriform.com/recuva
A good choice for fast remote data recovery performed over the Internet is: http://FreeDataRecovery.us
Another reasonably priced choice but you need to ship out the flash drive is: http://300dollardatarecovery.com
Jul 26, 2011 | PQI 512MB Intelligent Stick USB 2.0 Flash...
I have a My Book which has a broken USB jack. I removed the drive from the case and would like to know if it's still possible to access the data on it. Smart tests detect the drive as OK, and it ran...
If the SATA-to-USB converter is working properly, then Disk Management should show the device, assuming that the disk-drive itself is working properly.
Dec 27, 2010 | Western Digital My Book Essential...
Pen drive is not working properly
try to replace the unit.
it is possibly faulty.
also you should note that pen disks are not as reliable as hard drives.
Jan 23, 2009 | Electronics - Others
Electronics - Others Logo
77 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
