Question about Sewing Machines
In addition to my problem with 3160 QDC.
My Bobbin case is brand new. The Bobbin case has been replaced several time. Although I have had the machine 4 years. The usage has only been = 1/12 years at the most.
  • Sewing Machines Master
  • 1,388 Answers
And the question is....??
Posted on Apr 22, 2014
I have a Janome 3160 QDC and the bobbin case has slipped. i removed it and cant insert it corectly
You may get help for that on the Janome web site, the bigger manufacturers often have a support page or download instructions
Apr 26, 2017 | Janome Sewing Machines
Model 4075 white sewing machine thread from bobbin builds up and stops sewing.
Check the stitching and confirm that it is in fact bobbin thread and not the top thread that is creating knots & loops under the fabric. This is usually the case and is called thread nests or bird nests. (You can search the internet for more information about this symptom.)
Install a brand new needle.
Remove the thread from the machine.
ALWAYS RAISE the presser foot while rethreading the upper thread.
Confirm the thread path is correct.
Verify the bobbin is installed facing the correct direction in the bobbin case and the bobbin case is threaded properly.
Set the upper tension to the midway point (factory standard) although it may need to be tweaked as machines change with use and time.
Pull up the bobbin thread. This method works with general sewing projects, not just quilting.
How and Why to Bring up the Bobbin Thread
Begin to test sew slowly.
If the thread is still making a mess, then the machine most likely has a timing issue. There are multiple web sites and videos that discuss sewing machine timing. Or take it for service.
Sep 30, 2016 | White Sewing Sewing Machines
Upper thread is not pulling lower thread from bobbin up through sewing hole
increase the needle thread tension up more the tension is correct when the threads meet at the middle of the material being sewn
Mar 14, 2016 | Singer 2250 Tradition
Won't catch the bobbin thread everytime. skips. I have retreaded everything several times, reajusted tension, and even the presser foot tension.
Check the upper tension: Remove the thread. RAISE the presser foot and rethread from the beginning. This ensures the thread is seated properly in the tension disk. Make sure the bobbin case is threaded properly.
If still missing the bobbin thread, it probably has a needle/hook timing issue.
Feb 10, 2016 | Sewing Machines
Side wheel will not turn all the way
it's possible that the machine has a timing problem and would be a good idea to have it checked
Nov 26, 2014 | Singer 2263 Mechanical Sewing Machine
Janome bobbin problems
try getting a new bobbin case
Mar 23, 2014 | Sewing Machines
Hello dear
have you tried changing the needle?
have you tried adjusting the top thread tension?
it might be the needle and the thread are not compatable,, the needle may be to light for the thread.
if the suggestions don't help, sew on the sewing machine till it makes the loop and then stop the machine and take it to the repair man and let him see the loop and then ask him why it's making the loop.
Jul 25, 2013 | Janome Sewing Machines
Janome 3160 qdc drop feed dogs
Look on the back side for a slide type switch.
Aug 04, 2012 | Janome Sewing Machines
I can not get the thread from the bobbin to grab the thread
Things to check: 1) is the needle bent? Replace needle. 2) Do you have any lint/dirt in the bobbin case or the race (where the thread catches)? Clean the bobbin case. 3) Make sure that you are using the correct bobbin for your machine and that it is installed correctly. 4) Check that the bobbin case tension is correctly set. (For some machines this is easy. If the bobbin case can be easily removed, hold onto the bobbin thread and dangle the bobbin and bobbin case assembly. Additional thread should not pull through.)
The bobbin case or race may be damaged. Depending on the brand and model, you may find a replacement at your sewing machine dealer or online. If you add a comment with the your machine brand and model, I may be able to provide additional assistance.
(make sure you hold onto the top thread and have the presser foot down.)
Oct 06, 2011 | Sewing Machines
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
