Question about Homelite Garden
Tried replacing welch plug and broke
I have never worked on homelite chainsaws but recently got an old Homelite 330 for free. I have replaced everything that needs replaced except the carb. So i got a zama carb kit, got everything in except the round welch plug. I have read you poke a hole threw them and pop them out with a screwdriver. When i tried i took a flatnose screwdriver and tried to hammer(lightly) threw the plug but it just pushed the whole thing threw and out the other side of the carb. I dont know if thats a part i could get or its something i could put in myself because the holes in the carb and the part have to line up. What should i do?
  • 21 Answers
Take the carb to a carb centre
Posted on Apr 10, 2014
What is a replacement spark plug for the Homelite DJ168F-18500A plug provided with this unit?
HOMELITE DJ168F-18500-A - SPARK PLUG - Part Number ...
www.smallenginesprodealer.com/homelite/.../homelite-dj168f-18500-a-spa...
HOMELITE DJ168F-18500-A - SPARK PLUG - Part number DJ168F-18500-A (HOMELITE ... This is an original approved HOMELITE replacement part.
A100643 - SPARK PLUG - Part # A100643 - Small Engines ...
www.smallenginesprodealer.com/homelite/.../a100643-spark-plug-part-a...
This is an original approved HOMELITE replacement part. ... HOMELITE DJ168F-18500-A - SPARK PLUG - Part number DJ168F-18500-A (HOMELITE ...
HOMELITE GM304012 - SPARK PLUG A - Part Number ...
Jan 18, 2016 | Homelite Garden
Fuel line routing
i took the homelite 330apart in doing so the lines broke no problem i needed to replace them any way so now im confused to where they all go
Oct 01, 2013 | Homelite Zama Rb3 Carb Kit 330 Chainsaw...
I was using my Homelite 330 and it quit running.Now when it starts it runs at a high rpm for 5 seconds or so then winds down and stops running. I've checked fuel. The local repair shop won't even...
dO  tune -up.Here is a link : www.ehow.com/how_6971799_homelite-chainsaw-tuneup-instructions.html also visit www.homelite.com/ for more.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 07, 2011 | Homelite ZR10926 16 Chain Saw
I would like to know where I can buy or order an inlet manifold boot for Homelite 330 Chainsaw. I am having difficulty finding this part.
hi photobil
pauly46 here
here is web site for parts
http://www.odref.com/homelite/chainsaw/ut-10540.pdf
go to page 9
part ref # 26 number 93838b boot connector
save a copy of this file
here is another web site
http://store.chainsawr.com/collections/homelite-1?page=11
he has had them but o/s at present but order 1 anyway
check out www.chainsawr.com , go to parts by brand homelite ,
cheers hope it helps
pauly46
May 29, 2011 | Homelite Zama Rb3 Carb Kit 330 Chainsaw...
No spark on homelite 330 chainsaw. wire on on\off switch broke. thought to be ground wire. attached to block, still no spark switch in either direction.
The switch grounds the coil and kills the spark. Make sure you dont have a rub through on the wire coming from the coil. Better yet disconnect the coil wire. If this works you will have spark but wont be able to shut it down. Verify good spark, then repair the wire.
Hope this helps, Matt
Dec 12, 2010 | Homelite Garden
Chainsaw will not run, there is no spark detected
Homelite 330 – no points
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/baf9791bfc773f1a88256c2600142688?OpenDocument
Please try this
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Oct 27, 2009 | Remington Electric Chain Saw
Cant find a muffler for 1984 approx. 245 homelite
I tried the Homelite site (no longer available). You probably did too.
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/673d78ec01557aea88256b00005457e6/53fd90eee11e3fe8882572a300167f51?OpenDocument
There is at least one old Homey parts source.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I did a search there are many hits on Homelite saws one matches your model... that you spud? HTH
Lou
Oct 01, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
15 year old #330 Homelite 16'' Need spaqrk plug #. I replaced a plug today, the saw started right up. Used it for about 20 minutes and turned off to take a break. When I wanted to start again it fires one...
This sounds like carburetor trouble. These small carbs have a tendency to do just what you've described. Run like a champ until all the old gas in the carb is broken loose and then clogs the jets. Have the carb gone through and you will thank yourself. Hope this helps. good luck.
Jul 18, 2009 | Homelite Garden
Garden Logo
54 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
