Question about Electric Demolition Jackhammer
I need armature for chicago 46935 can some one help me
Need armature chicago jack hammer
2 Suggested Answers
SOURCE: burnt armature for a series
Chicago model #96035 is the same W/ different attachments, use this model when ordering from Harbor Freight. Total cost will set you back about $40.00
Posted on Jan 20, 2012
Sparks coming off brush
#1 Check your brushes & brush springs - you will have to remove the switch handle completely to access both brushes
#2 Visual of the armature - is it black / burnt or does it have raised segments?
Most likely it will need an armature if it has run for any length of time with bad brushes.
The armature comes out the front of the motor housing so you need to remove the gearcase to access it. Armature 2610003331 for Bosch Power Tool eReplacement Parts Carbon Brush Set
Mar 25, 2014 | Bosch Factory - Reconditioned 7/8" SDS -...
Bosch demolition hammer bearings are ceased up, how can I remove it properly to replace?
Ok here goes. Purchase or use the bearing cover nut 3613461500 that you have taken from the base of the machine. and drill a 6mm hole in it. remove the armature from the machine and measure how far the end of the armature sticks out of the bearing. then fit the cover nut onto the bearing holder and whilst supporting the cover nut use a puller or press to press the armature off the bearing through the cover nut. Replace the bearing in the holder and press the bearing and holder back onto the armature until the amount of armature shaft showing is to the same distance that measured in the first place. Hope this helps.
Dec 13, 2012 | Bosch 11316evs Elec Vs Sdsmax Demolition...
How do I disassemble the impact mechanism?
wouldnt be surprized if its pressed together as if theres plenty of oil in there,they dont normally need stripping right down
Mar 04, 2012 | Chicago Pneumatic 1/2" Electric Impact...
Where can iget armature or commutator for 46935 hammer
Contact Harbor Freight Tools for parts. You can also have your armature rebuilt thru Eurton Electric in California. They do a good job on the Brute armature so most likely do same for yours. Turn around time usually couple of weeks. Good luck
Oct 10, 2011 | Electric Demolition Jackhammer
Chicago 46935 armature i need 1
Chicago jackhammer 96035 is the same model W/ different accessories. Use this model when ordering parts from Harbor Freight, total cost W/ shipping and tax will set you back about $40.00
Sep 25, 2011 | Electric Demolition Jackhammer
Needle gun won't hammer , expect a broken part ,but don't have a schematic to check
Do you have the model number? You can always check http://www.eReplacementParts.com for the schematics. They have Chicago Pneumatic parts and schematics for pretty much every model.
Feb 07, 2011 | Chicago Pneumatic Heavy Duty Zip GunĀ® Air...
Need to change the brushes in my chicago breaker hammer
If change brushes it has having its workinghours Use a service kit for your model if there is support for your hammer ??? on EBAY there is a set brushes parts are maybe hard to find for electrical demolition hammer of this brand.
Carbon Brushes Chicago electric UL breaker jack hammer NEW 46935 harbor...
Jan 30, 2011 | Electric Demolition Jackhammer
Burnt armature for a series #46935 Chicago Electric jack hammer
Sep 03, 2010 | Electric Demolition Jackhammer
Armature in motor messed up need brushes also
if the armature is bad its time to junk it, a new or reworked armature will be more than new drill
Nov 01, 2009 | Milwaukee 5321-21 Rotary Hammer
Electric Demolition Jackhammer Logo
95 people viewed this question
Top Electric Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Dan Webster
Dan Webster
Are you an Electric Hammering Expert? Answer questions, earn points and help others
