Question about Pet Ag Nursing Bottle and Nipple
My petag nuring bottle is leaking
I need to fix it
Water leaking out and not filling water bottle
difficult to judge.. the good news is that since water leaks means that the system is working, but before the collecting the condensed water into the bottle, it leaks outside.
there is no quick fix for that, you have to pull the machine out and open it to check where the leak comes from (perhaps it is a worn rubber hose that connects the condenser to the bottle, or it was disconnected due to rust ring). after all, you machine looks as it it survived the WWII :). just be careful to pull the electric socket from the outlet before you start.
Jan 26, 2013 | Dryers
My hamsters' water bottle keeps leaking, what can I do to fix this?
It could be that thelittle ball that stops the water from leaking is broken, you will need to get anew one so for the time being put a little bowl of water in the nest, make sureyou change the water regular though as it will get bedding in it.
May 13, 2012 | Pets - Others
Leaking antifreeze badly from a head bolt. How do I fix it?
Okay, you may be in luck. If you go to the auto parts store and find a product by the name of "blue devil" and follow the directions on the bottle you have about a 99% chance of fixing your problem. The stuff cost bout $65 a bottle but you only need 1 and it is alot cheaper than the repair u would be facing. I had a warped head after I replaced the gasket on my grand prix so it stilled leaked. Refused to take it apart again cuz it was a pain. Went out bought a bottle and within minutes everything was runnin right and leak had stopped. It really does what it says it does. Good Luck hope this helps.
Jan 07, 2012 | 2000 Pontiac Sunfire
I am putting water in my coolant bottle twice a day to avoid overheating. It won't hold water?
Is the coolant bottle actually leaking or do you have a more severe problem? I would start by looking on the ground underneath your vehicle underneath the engine. If its coming from the front look at your radiator first, then your hoses upper and lower then your water pump and finally your heater hoses. If you cant see a leak start the car and let it warm up so your system has pressure to it. Then take a look and please dont stick your hand anywhere around the engine while it is running. Last place to look is feel the rug on the passenger side of the car to see if the rug is wet that would lead to a faulty heater core. If your handy with tools call around to your local auto parts store or tool rental places to see if they have a pressure tester. You can then pressurise your system with this tool and it should help you to find the leak.
I hope this helps you out, and if so please leave me a rating.
Apr 04, 2011 | 1999 Chevrolet Malibu
Coolant leaking. Can i fix it myself?
Just find the leak. Do you know where the leak is at? Check all end hoses. Make sure clamps are on tight. Leaking coolant on the wires cause major problems.
Feb 11, 2011 | 2002 Buick Century
My light on the temperture gauge is flashing does anyone know why? its a ford galaxy
the red light flashing on the temp gauge means that there is no coolant in the expansion tank.
look behind the battery (slightly above) and you will see a bottle.
With the engine cold open the cap on the bottle slowly and release the pressure inside.
Check to make sure that the coolant inside the tank is between the min and max line.
if coolant isnt there you need to fill it with a mixture of water and coolant(coolant purchased at any garage) as directed on the bottle.
Keep an eye on the level of coolant in the bottle for a few days if it falls below min or dissapears it could indicate a leak.
I had a small leak in my 98 2.3 ghia x galaxy and fixed it by buying a bottle of rad weld, poured the liquid rad weld into the coolant bottle, and it worked a treat plus it stops the inside of the radiator rusting and rotting away.
Hope this helps :-)
Jan 06, 2010 | Galaxy BC-9901 Temperature Monitoring...
Coolant bottle in 200o Daewoo Lanos 1.6 is leaking
Replace the bottle.
It's to hard to weld together again...
Oct 31, 2009 | 2000 Daewoo Lanos
LEAKING WASHER BOTTLE FORD ESCORT 1998
this is a plastic bottle replace with one from the dealer or sometimes you get luck in a junkyard
Jan 06, 2009 | 2003 Ford Focus
Pet Ag Nursing Bottle and Nipple Logo
94 people viewed this question
Top Pet Ag Baby Care Experts
masud
masud
Tom Chichester
Are you a Pet Ag Baby Care Expert? Answer questions, earn points and help others
