Question about SkyCaddie Aire GPS
My skycaddie aire wont give front centre and back of green yardage was told to reset it but don't know how
Skycaddie aire wont display front centre and back of green yardage try to reset it but I am unable
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: My SkyCaddie SG4 fails to
Hi
Thanks for using FixYa. The issue seems to be with the battery going bad and should be replaced, will cost you around $25 to replace the battery. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 06, 2010
Device did not show yardage to hole
Maybe the yardage indication is predicated on the screen size - on many units if you are way out in range, you get nada until you zoom in. Check that angle out.
Sep 11, 2015 | SkyCaddie SkyGolf Sky Caddie SGX
Tip
Loss of GPS Signal and Yardages
It is often thought that a GPS device like the SkyCaddie should keep constant uninterrupted view and connection to the satellites, thus always giving accurate yardage information. This is true of cellular technology, indoors or out, etc, but not for a GPS device like the SkyCaddie. A clear, unobstructed view of the sky must always be maintained for optimum performance. Here are some other tips:
1. When going to play golf, the SkyCaddie should have a fully charged battery and should be allowed to search and acquire satellites for at least 10-15 minutes, prior to play. During this time, the device should be stationary. Many people power the device on then head straight to the course. From that point on, the yardage info you get may be off or may not show at all.
2. Is the golf course you are playing in need of an update? It's good to plug your SkyCaddie into your computer and allow it to sync with the SkyCaddie desktop software. You will receive updates to the device if you do this periodically and you can view your course list to see if any of your downloaded golf courses should need an update. An unupdated golf course on the device can cause yardage problems.
3. Placing the SkyCaddie in your pocket during the game, placing it in a golf cart cup holder, tall trees or heavy shrubbery, hilly terrain, very overcast cloudy days, etc., all can impede satellite acquisition and yardage accuracy.
4. Internal issues. Most SkyCaddie models may have an outward antennae view, but there is also an inward antennae connection that could be compromised. If this is true, the user will not know this, as this type of issue is internal and will need to be sent in to the company for repair, contact them to have this done. This can also be the source of why a device never seems to acquire satellites and/or give accurate yardage information.
on Aug 12, 2008 | SkyGolf SkyCaddie Handheld GPS Unit
Bushnell neo+
The wording on this question is almost word for word of a message I sent iGolf customer support. If it's my message I don't know how it showed up here on fixya. Sent it also to bushnell support, both said in essence that a demo unit won't work, although i have seen factory demo's being sold on various websites. 1 tech. @ IGolf uploaded to me 2 files EMBEDD01.GLF and SYSREG.SMI which I loaded on th my neo+ after deleting both of the 2 files originally on the unit. But again everthing works, satallite signal strong, courses are loaded but no yardage is shown. It seems to be working when mapping a hole on the course (front, center, and back) but on resume play hole shows no yardage.I believe it's the firmware that is in the demo unit. my ? to iGolf and bushnell was if there was anyway to update the firmware but neither gave me an answer.
Jul 28, 2013 | GPS
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
Will not give me yardage readout ??? Bullseye blinks but does not display yardage
http://www.bushnell.com/manuals/rangefinders/20-5102_Pinseeker.pdf here is the manual it will show you how to reset and also trouble shoot the issue there is an explantion to your problem on thre to on page 8 let me know if this worked please
Mar 17, 2011 | Bushnell Pinseeker 1500 Rangefinder
My SkyCaddie SG5 turns off on its own on the course and is slow to update yardages. It worked perfectly for a year and then I noticed the screw that hold the battery cover closed was missing. I replaced...
i have the same problem, I turn it on to play and about 2 min later it shuts off. i plugged it into the wall and it passed the 30min trial test. when i removed the back a small little half circle piece came out. not sure what to do??
Aug 28, 2010 | SkyGolf SkyCaddie Handheld GPS Unit
I tried to renew my skycaddy. I got on line but was told to download a update. which I did. Then as I proceded through the renewal it said to hit on the icon. Problem was the icon disappeared after the...
Did you download the courses of choice first before you tried to renew after applying the update?
If your membership has been renewed and the SkyCaddie still displays a renewal reminder, your renewal information was not successfully communicated to the SkyCaddie. To finalize the renewal process, please download the courses of your choice to the SkyCaddie from your Favorites list in CaddieSync. The download communicates your new expiration date to the SkyCaddie.
Jun 22, 2010 | SkyGolf SkyCaddie SG4 GPS Receiver
My Pinseeker will turn on but will not give any yardage.
Sounds like the unit needs an alignment. If the crosshairs appear in the display and stay on....it needs a CPU board and reprogramming.
Jan 13, 2009 | Bushnell Medalist Rangefinder
SkyCaddie Aire GPS Logo
Top SkyCaddie Dryers Experts
Dan Webster
Dan Webster
Are you a SkyCaddie Dryer Expert? Answer questions, earn points and help others
