Question about Garden
Mower won't start just replaced solenoid connection are clean + tight I think it is the safety switches but I don't have anything to test them The mower try's to start turns over but it won't catch
  • Garden Master
  • 2,478 Answers
WHAT MODEL? You buy good cheap ohm meters at Harbor Ferght or one about 2O
Posted on Mar 24, 2014
  • 313 Answers
SOURCE: Black and decker cordless lawn mower CMM1200
cmm1200 switch in the handle problem. switch contact maybe burnt out. parts are available. see dewaltservicenet.com or toolpartsdirect.com for diagarm etc.
Posted on May 31, 2008
  • 53 Answers
SOURCE: Sears lawn tractor 917256491 unable to activate start solenoid.
first see if u can jump the started with a screw driver, also check fuse could be blown. do u have battery voltage? here is a site for a wiring diagram www.managemyhome.com.
Posted on Jul 23, 2009
SOURCE: Murray Riding Lawn Mower won't start or move
The Drive Belt keeps coming off as soon as I engage the mower I replaced the Drive Pulley and put on a new belt but it still comes off. Any Ideas.
Posted on Aug 15, 2009
  • 61 Answers
SOURCE: 18.5 hp 42'' mower model no. 917.274811.Mower will
ck the terminals battery, solenoid. are they clean? and tight?
Posted on Sep 06, 2009
rwvanlue
  • 486 Answers
SOURCE: Craftsman riding mower Model 917.270824
I do not believe there is a manual available to the public for troubleshooting, however, you have at least 3 switches to tell the mower to stop when blades are engaged or clutch pedal released.
Seat switch
pedal switch
mower engage switch
The pedal and mower lever switches are identical, and have two sides, one for starting, one for blades turning. One side can fail. The pedal switch is on the frame very close to the pivot point of the pedal/shaft. The mower switch will be under the dash close to the bottom of the lever.
1) Locate and inspect the switches for broken or pinch wires, switch housing, or loose mounting, and how each lever or pedal engages the swtich.
2) This is a picture of the wiring so that you can get a better idea of location.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917270824&productCategoryId=1509200&brandId=0247&modelName=TRACTOR&diagramPageId=00011&componentDescription=SCHEMATIC%20DIAGRAM-TRACTOR&documentId=P0811014&blt=06
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917270824&productCategoryId=1509200&brandId=0247&modelName=TRACTOR&diagramPageId=00001&componentDescription=ELECTRICAL&documentId=P0811014&blt=06
Posted on Nov 11, 2009
Wont start
Hi John, The links below are youtube videos that might get you out of trouble... Also there's videos down the right side of the links that may help as well....... I hope these help......... CHEERS..
How to test a lawn mower Key switch....
How to test lawn mower key switch
How to test a solenoid....
How to test lawn mower solenoid
How to test lawn mower electrical safety switches....
shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 25, 2016 | Garden
Lawnmower TRY3.5PMLA - trying to find manual for this online as it currently won' start.
Hi Anonymous, I don't know if your mower is push OR ride on so the links below are youtube videos that might get you out of trouble... Also there's videos down the right side that may help as well....... I hope these help.........CHEERS..
https://www.youtube.com/watch?v=Xi3p465MN1E
How small engine governors work...
How Small Engine Governors Work any governor setup
Apr 24, 2016 | Garden
Craftsman Tractor solenoid clicks but won't start
could be a safety switch or a ground problem check the ground for corrosion and make sure it is tight at all places then check each safety switch they usually have one for the seat,mower deck and clutch/brake pedal
Jun 19, 2013 | Garden
Mower won't start
If you have jumper cables or a jump box you can put the positive lead on the hot wire running to the starter and the ground to any clean (unpainted) surface on the mower and the starter will get power. Place your key in the on position and the unit should start if it is getting fuel.
Apr 06, 2013 | Husqvarna Yth 150 Riding Mower Illustrated...
White lt-13 cruisematic won't start
use jumper cables direct to the starter that will test the starter next jump power to the small wire on the solenoid that will test the solenoid next jumper the safety switches with a paper clip
May 20, 2012 | Garden
ITurn key, clicking sound, no turn over
If it won't crank over, it's a problem in the starting circuit, not the ignition circuit. Check your battery and starter for clean, tight connections. Listen for that click to see if it comes from the starter solenoid on the starter-maybe have someone try to start it while you watch and listen under the hood. If the click is from the solenoid (and not from the starter relay), then the starter is not getting full battery power to crank (bad connection), or the starter needs to come off and be tested.
If the click is from the starter relay, you could pull off the little purple wire to the starter solenoid and see if it has 12 volts when the key is in start position. If you have power there in cranking position on the switch, the solenoid is bad or the starter may be the problem-again, it will have to come off for testing. If you have no power at the solenoid in cranking position, the circuit from the ignition switch to the solenoid is not working. The start relay and the neutral safety switch (or clutch switch if manual transmission) are in the starting circuit from ignition switch to the starter solenoid. Good luck.
Apr 01, 2012 | GMC Cars & Trucks
Want start or turn over
My name is Dane and I am going to assist you in solving your problem. However, I would ask that you do one check for me before we go to the seat switch procedure. Please find the starter solenoid on your mower. Make sure that the 2 large cables (1 coming from the battery and 1 going to the starter) are clean and tight. Make sure that your 1 (possibly 2) wires going from your switch to your solenoid are also clean and secure. Use a volt meter on DC volts, or a test light and check the small lead on the solenoid and make sure that when the parking brake is on, transmission in neutral, and the Deck PTO is off, that you are getting 12VDC when the key switch is turned to the start position. If you have a 2-wire system, 1 of them is for ground only. 1 of the 2 wires should get 12VDC. If you get 12VDC at the small terminal of the solenoid, but no power to your starter, the solenoid is bad.
But you probably have a problem with the seat safety switch on your lawn mower. The seat safety switch makes sure that if you are ever thrown from your mower, the engine will die.
You should check under the seat of your mower and locate a small square box with normally 2 wires connected to the end of it. While looking at the switch, press down on the back of your seat and make sure your seat is activating the switch. If not, you must get the switch correctly positioned so it makes contact and pushes the button. If you found nothing wrong there, go to the next step.
Make sure the 2 wires are connected and the wiring is in good shape. Disconnect the wires from the switch and make sure there isn't any corrosion on the terminals of the switch or the connector. After you have done this, reconnect the switch and try again to see if the mower will start.
If not, disconnect the switch again and place a jumper wire between the 2 prongs of the connector and tape them so they will not ground out on the frame. Start your mower and see if it operates correctly. If so, you have got a bad seat safety switch and it needs to be replaced. This was only a troubleshooting procedure. You should never operate a mower with this switch disconnected, because you could be seriously injured. Go buy a new switch and replace it. You will need the make, model and serial number of the mower in order to get parts. I hope I've helped! Thank you! Dane
Dec 22, 2010 | Craftsman 21 Hp 42" Lawn Tractor Riding...
John Deer F725 won't start - one of the safety switches is prohibiting starting. Battery OK , even tried jump start ...but won't turn over.
My name is Dane and I am going to assist you in solving your problem. However, I would ask that you do one check for me before we go to the seat switch procedure. Please find the starter solenoid on your mower. Make sure that the large cables coming from the battery and going to the starter are clean and tight. Make sure that your 1 (possibly 2) wires going from your switch to your solenoid are also clean and secure. Use a volt meter on DC volts, or a test light and check the small lead on the solenoid and make sure that when the parking brake is on and the Deck PTO is off, that you aren't getting 12VDC when the key switch is turned to the start position. If you have a 2-wire system, 1 of them is for ground only. 1 of the 2 wires should get 12VDC. If you get 12VDC at the small terminal of the solenoid, but no power to your starter, the solenoid is bad.
But you are probably correct that you have a problem with the seat safety switch on your lawn mower. The seat safety switch makes sure that if you are ever thrown from your mower, the engine will die.
There is a small chance that either your clutch/brake safety switch or your PTO safety switch could also be at fault. Normally they won't go bad, but will just get out of posistion so that when you activate the clutch/brake they won
Dec 11, 2010 | John Deere Garden
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
