Question about Samsung RS2630SH Side by Side Refrigerator
Samsung RS267LASH model will not dispense ice cubes!
I have a Samsung RS267LASH model side by side refrigerator. It will only dispense crushed ice when I want it it to give me cubes. The ice bucket is full and the cubes are loose and not stuck together. What is wrong?
SOURCE: Samsung, american style fridge
We had a service tech service our fridge for the same problem. Although the ice that was dispensed was not as fine as crushed ice, mainly chunks. In any case, he said this is a known problem and is typically resolved by ensuring the freezer temp is not set at the maximum setting. Ours is currently now set at 3 bars and is producing cubes. Not sure if reducing the temp was the ultimate fix as he also replaced the ice maker.
Posted on Aug 05, 2007
fridgetech
  • 473 Answers
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Posted on Oct 14, 2007
  • 184 Answers
SOURCE: Ice dispenser only dispenses crushed ice
THE WAY A DISPENSER CHANGES FROM CUBES TO CRUSHED ICE IS BY RAISING AN ARM THAT RUNS ALONG THE BOTTOM OF THE ICE BIN. IF IT SETS FOR A LONG TIME, IT CAN GET A BUILUP OF FROST OR ICE THAT KEEPS IT FROM MOVING. PULL THE ICE BIN OUT AND TRY TWISTING THE END OF THE ARM MANUALLY. IT SHOULD OPEN A DOOR AT THE FRONT OF THE BIN THAT WOULD ALLOW THE ICE TO BYPASS THE CUTTER ASSEMBLY.
ALSO,WITH THE ICE BIN REMOVED, PUSH THE DOOR SWITCH BUTTON CLOSED BUT KEEP THE FREEZER DOOR OPEN. WHERE THAT ARM GOES IN THROUGH THE BACK WALL, CHECK FOR MOVEMENT OF A ROD UPWARD WHEN YOU CALL FOR CUBED ICE. IF YOU HEAR A LOUD HUM BUT THE ROD DOESN'T MOVE, YOU MAY NEED TO REPLACE THE SOLENOID ASSEMBLY IN THAT MODULE.
Posted on Apr 10, 2008
  • 415 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
elbozi
  • 4 Answers
SOURCE: Samsung french door ice maker
Check my solution here. The noisy sound is the swing arm trying to knock out some stuck ice.
http://www.fixya.com/support/t1141317-two_issues
Posted on Oct 31, 2008
Water and ice cube dispenser working fine, crushed ice not crushing. 26 cuft side by side model MZD266SHES
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid. Crushed ice is the default position and the solenoid is energized to cube ice.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Feb 21, 2011 | Maytag MFI2568A Side by Side French Door...
Hi i have a double door samsung fridge and when i place dispensable ice on cube i still get crushed ice in addition is there any way to increase the speed at which water comes out the dispenser
There is likely a faulty solenoid which switches the ice dispenser between "crush" and "cube" mode.
The water pressure at the water dispenser is proportional to the supply line water pressure. Unless there is a restriction in the supply line or the dispenser line, the only way to increase the water flow is to increase the supply line water pressure -- not an easy proposition.
More info, let me know.
Charlie
Feb 12, 2011 | Samsung RS2630SH Side by Side Refrigerator
Dispenses crushed ice instead of cube ice
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
ICE Maker stuck in dispensing crushed Ice
That means that the evaporator fan system that releases the the ice cubes is not working.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Nov 29, 2008 | Frigidaire GLRS267ZC Side by Side...
hi there,
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Oct 23, 2007 | Hotpoint HSS25GFP Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
202 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
