Question about Roomba Vacuums
Replace rubber on wheels
Replace wheel
Take it to guarantee vacuum and sewing center they can do it for you and it will not cost mutch
Posted on Mar 24, 2014
soumyak
  • 73 Answers
SOURCE: Roomba pro elite change drive wheels
U can get the solution of your problem with the following URL
http://www.roombahelp.com/
Posted on Sep 18, 2008
  • 55 Answers
SOURCE: Royal Airo RY2000 Broken Wheel on Carpet tool
Royal parts are not too hard to come by. They will pretty much sell them to anybody, but you will probably have to call up a local independent dealer (someone with access to schematics) with your model number and have them look up the parts and order them in for you.
Posted on Nov 24, 2008
VacuumRepair
  • 438 Answers
SOURCE: self propel wheels not moving
I believe that you're asking about the Hoover Windtunnel Self-Propelled upright, but I can't be sure. I've posted a video below that we recorded showing how to replace the belts on your Hoover WT. If you have a different model then this, please just add a comment to this repair of the make and model and I'll be more then happy to walk you through.
Thank you,
Chris J.
GoVacuum
Posted on Apr 10, 2010
  • 694 Answers
SOURCE: Vaccuumed up a coin and it broke the impeller. Is
Yes, the impeller can be replaced. The drive wheels may need to be replaced. On the below listed site are video instructions for replacing the impeller. Instructions are in two parts.
On the second site, written instructions are found.
http://www.youtube.com/watch?v=dhIoSRs2R4M&feature=player_embedded#!
http://www.youtube.com/watch?v=I0DS02D01Vc&feature=relmfu
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302
Posted on Mar 01, 2011
  • 34 Answers
SOURCE: I need rear replacement wheels
http://www.vacuums24x7.com/
They have Simplicity replacement parts. There are a number of different wheels / wheels with trays / and more. If you contact them with your make and model, they will get you the proper wheels.
Posted on Mar 07, 2011
Panasonic upright bag MCE3001 smell of burning rubber, beater not rotating but suction ok. how do i clean the wheel and or fit a new belt?
Hi, You need to disassemble beater bar. There is a belt that is broken and rubbing on motor. Replace the belt with new on.
Jun 10, 2011 | Panasonic Vacuums
I need rear replacement wheels for my Simplicity Jack Canister vacuum. They were replaced under warranty a year ago and they have cracked again. It's a plastic wheel with a rubber tread. The plastic has...
Mar 06, 2011 | Vacuums
Trying to replace wheel,,how do I remove wheel
you need to pry the hub cap of wheel off to replace it. order the wheel with the hub caps. they may brake in the process of removing it.
Feb 09, 2011 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Dyson dc11 replacing motor
DYSON DC-11 MOTOR REPLACEMENT
1. Remove dirt cylinders as normal
2. Using large flat screwdriver, remove airway splitter and hose
3. Undo 6 Torx screws from top and one at the back under tool holder
(Note that 2 front screws are shorter)
4. Make sure the screws are completely withdrawn
5. From the back, withdraw tool holder section
6. Unhook and withdraw hose holder section
7. Place large flat screwdriver behind the wheels and forcefully snap them off
8. Remove 2 more screws under each wheel
9. Cover now lifts off
10. Motor pod is now visible. Remove its 4 screws and lift its lid
11. Motor can now be lifted out. Disconnect its 2 wires
12. Remove the rubber base and transfer to the new motor
13. Connect wires, Red to Brown (Live) and Black to Blue (Neutral)
14. Make sure motor is correctly fits on its alignment studs in the pod and replace its cover and 4 screws
15. Replace top cover of machine, and the 4 screws under the wheels, but no other screws yet
16. Turn machine on its side and hammer each wheel back on - take care that no fingers are under wheels while doing this
17. Stretch and snap hose holder back into position
18. Slide tool holder forward into position
19. Replace the 6 screws into top section, and one into tool holder section
20. Replace filters, airway splitter and dirt cylinders, and the job is complete :D
May 22, 2010 | Dyson DC11 All Floors Bagless Canister...
My rear wheels keep poppping off. I've hammered and glued, but they won't stay on. Do I need new wheels or a new axle assembly?
Greetings,
You may need to just purchase the the little c-clips that hold the wheels onto the axle. Kirby Vacuums actually have a hub cap on their rear wheels that can be removed to access the axle end with the c-clip. If you take a flat head screwdriver, and pry off the plastic part of the wheel off of the rubber part, you should be able to see the end of the axle. There should be a little tiny c-clip at the end of the axle that holds the rear wheel in place. Is that clip there on both sides?
If yes, then you may need to replace the entire axle assembly. If they are missing these clips are available for purchase through many online websites including our own, govacuum.com.
If this repair didn't fix your Kirby, please contact me, I'm happy to try and diagnosis this further with you. If it did help, please rate the repair as helpful, thank you.
Chris J.
Mar 13, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Brush wheels are not spinngin
There should be a rubber belt that drives the brush roller(s) which may be broken. Should be able to detach plastic retainer on bottom of machine to check/replace.
Oct 09, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Hoover windtunnel U6439900
please go to the hoover vac store using the following link. you will have your exploded diagram for the machine and any spare parts you might need. http://www.thehooverstore.com/U6425.html
Sep 15, 2007 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
53 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
