Question about Panasonic 55 inch VIERA 1080p 120hz LED TV - TC-L55E50 [TC-L55E50]
How do I get digital audio out from a panasonic panel to optical in on a yamaha amp
My Yamaha amp has a optical plug but the tv has no optical out only hdmi out is it possible to get an adaptor
  • Official Brand Answer
  • 350 Answers
The TC-L55E50 has an optical output located on the rear of the TV. Simply connect the optical cable from the TV to the amplifier.
Posted on Mar 24, 2014
Can't get sound when plug my Lg tv to my Yamaha amp model ax-396
What sockets are you using on the LG TV to connect to the amp?
Having viewed the back of that Yamaha amp, it has no digital inputs, for either coax or optical. Many modern TV's have no RCA audio out connectors. Though people think the component RCA type connectors are these. In fact connecting the amp to them will produce no sound at all.
If the TV has a scart socket you can get a scart to phono out lead and use the audio out from that, providing you are not using the scart socket for a video device. If you are you will need to also buy a scart switching box see image(s) below. These often have RCA audio out sockets on them so you wouldn't need the lead.
Both available on Amazon.
Alternatively you can consider upgrading your amp to one that has digital inputs. Thus getting Dolby Digital, if the TV has HD channels built in.
Apr 21, 2016 | Yamaha Audio Players & Recorders
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
I need some help hooking up an amp, tv, and xbox 360 together please! I have a Toshiba 46g310u TV and Xbox 360 already hooked up together using an HDMI cable. I just bought a Yamaha R-S300 amplifier,...
Many TVs have to have the optical output enabled in a set-up menu. Do you see red when the connector is disconnected (which doesn't necessarily mean that it is active, just that it is 'ON').
Have you checked the amplifier to insure that the input is working by connecting something else directly up to it? Can you test the TOSLINK converter by plugging the output into something else to determine where the problem lies. I still suspect it is in the menus of the TV.
Sep 10, 2013 | Toshiba 46G310U LCD TV
My (Cable Service) wire feed is directly behind my HDTV and hooked up over my fireplace . The Rxv667 is located on a side wall book shelf. I have A HDMI wire running to the TV from my receiver. Do I need...
Is there a set top cable box, or are you feeding the cable directly to your HDTV (coax directly to the TV). If you are feeding cable directly to the HDTV then you don't need HDMI. There maybe exceptions, but most TV's don't have HDMI output. The only thing you need to run from your TV to the Yamaha is an audio cable. I assume your HDTV has an optical audio out (either TOS or coax.... Your Yamaha will accept either). Connect the optical audio cable to the AV4 input on the Yamaha. This way when you hit the TV scene button on the Yamaha remote, it will select the AV4 audio input (the default for the TV scene). The optical cable will feed the full audio signal, so that the Yamaha can pass through the surround sound or use the decoder as appropriate to feed your 7.1 or 5.1 speaker system.
If you have a set top box, you may be better off moving that near the Yamaha. In this case, cable goes to settop box, output of set top box via HDMI or component video (RGB) and optical audio to the Yamaha (if you use HDMI Input 2, and AV4 for the optical audio (if necessary), the TV Scene will select the appropriate inputs) and then an HDMI to your HDTV.
In case one, you may need to setup the TV to process the audio appropriately. I have experience with Panasonic Plasma but thats about it.
Feb 24, 2011 | Yamaha RXV667 Receiver
How do i connect my HDTV to my YAMAHA HTR-5930 receiver? for example i am watching a movie from my usb port on my LG 42LE5300 or i am playing on my xbox, how do i get that sound to come out of the...
The simplest for the movie would be to connect the Optical digital audio out of the TV (above the VGA port) to the Optical Audio In on the receiver. You will need to get this cable from any store that sells TOSLink cables. The manual for the TV is available here: http://www.lg.com/uk/tv-audio-video/televisions/LG-led-tv-42LE5300.jsp . The manual for the receiver is available at the Yamaha support page if you are a registered Yamaha customer: http://download.yamaha.com/search/product/?category_id1=16445&&category_id2=16446&product_id=1060939 .
For the XBox, I'd suggest the same connection if you are using HDMI out on the XBox. If you are using component or composite video, route the audio cables to the receiver's RCA audio in.
I hope this helps.
Feb 22, 2011 | Yamaha HTR-5930 Receiver
Have no sound from my tv panasonic th-58px600u which is hook up to my receiver with an hdmi and fiber optic for the video out into my receiver yamaha 6090
Do you expect TV audio to go TOWARD the receiver in this setup? The HDMI is to get video and audio TO the TV. The BEST TV-related audio will come from the device supplying it, not the TV.
Try this. Take the digital audio from the cable / satellite box into the receiver. Ditto for games or whatever.
After all, what else enters the TV that isn't already connected directly to the receiver?
Mar 17, 2010 | Yamaha HTR-6090 Receiver
Yamaha rx-v365 plugged in the hdmi from cable box
You have to configure your DTV input to use optical audio instead of analog dtv audio (red/white plugs). Input assignment should be described in the manual. Come back to me if you have still problems with it.
Dec 26, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Hooking up multiple components to HTR 6030
Once you have installed all the cables to the system, you will need to go in to the Yamaha's system settings (see owner's manual) and assign the audio inputs accordingly. The DVD input will need to be set to the optical input # you have selected. Optical and digital coax are not preset in most cases. Once you get to the input selection assign the digital # for DVD and then exit out. You should begin to hear the audio immediately. If not you missed a step. I do this for a living and every unit has its own routine you need to learn.  Enjoy the system Rob
Feb 27, 2009 | Yamaha HTR-6130 Receiver
I have a Yamaha Rx-v363 receiver using HDMI jacks but I am not getting any sound through my surround sound only my tv speakers. I have a digital audio optical cable running from the receiver to the blue...
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Jan 02, 2009 | Yamaha RX-V363 Receiver
Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
Apr 26, 2008 | Televison & Video
Panasonic 55 inch VIERA 1080p 120hz LED TV - TC-L55E50 [TC-L55E50] Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
