Question about Polaroid Televison & Video
Cannot set up the new television
The 39" 39GSR3000. I keep getting a prompt that says "Please run channel auto scan" but there is no reference to this in the manual. How do I proceed?
    Top Expert:
  • Polaroid Master
  • 74,136 Answers
Http://polaroidhdtv.com/wp-content/uploads/2013/11/UM_39GSR3000.pdf
Try the above link to download its user manual. It has all details.
Gopakumar Gopalan Google
Posted on Mar 24, 2014
MNfisherman
  • 11896 Answers
SOURCE: Auto Scan doesn't pick up any channels.
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
Posted on Jun 22, 2009
bschilz
  • 2049 Answers
SOURCE: I am looking for the owners manual for a dynex 32
Here's a link to the manual...
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/07-062_DX-R32TV_WEB.pdf
Posted on Sep 04, 2009
budmrtn
  • 11361 Answers
SOURCE: Initiation
Yoiu should be using the video output signal from your satellite box, not RF cable, to get the full benefit of HD program to feed the video input of your TV. Please resd the instruction book on how to hook up satellite setup.
Posted on Nov 07, 2009
SOURCE: My tv keeps saying to run auto channel scan.
FIRST, you must check ALL antenna connection, and if possible, try another "Known Good" antenna system. If it proves that the antenna system is all OK, then I fear your Tuner, has failed, this is a common event, that I get from time to time at my shop. Usually, it is a straight forward job and the cost would be about $250 - $350, depending exactly what is going on. However it would be best to get a "Quote" first, before proceeding, as this may only be a symptom, of a larger underlying problem, that may indeed cost much more.
Posted on May 23, 2010
rickbrashear
  • 176 Answers
SOURCE: can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Posted on Aug 06, 2012
Channel auto scan repeated 3 times with no success.
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Dec 08, 2016 | Televison & Video
How to reset channel auto scan.After I finish channel scan,message pops up stating PLEASE RUN CHANNEL AUTO SCAN,
If when You scan, and you don't get at least one channel, it will keep showing You this message! look at screen it will show new channels! if no new channels check to make sure your coax is hooked up good, also make sure you are using right setting if outside antenna, select antenna, if cable select cable for your source!
Nov 03, 2016 | Televison & Video
Auto scan not working??
Make, model, and year please.
Jan 22, 2016 | Televison & Video
Display says please run auto channel scan
It sounds like it is not seeing any signal. Do you have the input set for the proper type? Air or Cable
Check your RF connection to ensure you have a signal coming into your television.
Nov 16, 2013 | AOC L22W898 22 in. LCD TV
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
When setting up a new TV, it keeps telling me to "Please run channel auto scan." But it also states that if I sellect Cable/satellite, that the tv does not need to run the auto scan. When you...
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
Sep 25, 2011 | Dynex Televison & Video
Where are my antenna channels ???
Please try Auto Programming the TV.
Please refer to the page number 37 in the manual to get information about Auto Programming the TV.
Select the Auto Program option under the ANALOG SETUP SETTINGS in the Menu of the TV to Auto Program the TV which should resolve the issue.
Jun 15, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
24 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
