Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
The compartment wont seal
The piece on top of top of washer is stuck
  • Fisher and P... Master
  • 3,247 Answers
This piece you are mentioning could be the Lid seal. It looks like this part. (use a mirror to check as it is on top of drawer housing)
https://www.genuineapplianceparts.net/product/522566/522566-Lid-and-Seal-Kit/
It is more likely the lid seal motors are stuck. Need to turn mains power off and then pull the drawer out. If there is no difference when you turn mains power back on, then the technician work is involved to free up or replace the parts.
Posted on Apr 03, 2014
Why is there oil under my briggs and stratton 4hp pressure washer motor? (on the top of the pump)
pressure washers are unique in the fact they have two separate compartments for lubricating oil , one compartment holds engine oil and the other compartment holds pump oil/coolant the two compartments should never mix (bad idea) even though they both take similar type oils , sometimes the pump oil chamber will expand a bit with heat in use and a little oil will pop out a vent hole in top of pump , this is normal but if this is too excess its an indicator of larger problems (blown seal) both compartments should be ck'd before use every time for both level and clarity and causes fixed for any thing that's noticed , pressure washer pumps are very expensive to repair , with costs in the hundreds to thousands of dollars for seemly minor repairs ( nothings minor on them) and the oil is there way to keep cool and work ok for years
Jul 05, 2014 | Briggs & Stratton Garden
We are replacing the white plastic washer, but don't remember what order the washers were in when removed.
The white neoprene piece from the seal kit is on the bottom, then place the metal washer in and the bolt on top of it. Then insert the black plastic piece on top and insert into the sump area and tighten it down with a screwdriver. If you need further assistance, please call customer service at 800-352-2866.
Sep 14, 2010 | Bunn-O-Matic Coffee Brewer GRW8
Refrigerator runs all the time ,the freezer compartment on the outsie is cold.
Check the seals on the doors- a decent seal should be able to grip a piece of paper, if the paper just drops out or pulls out very easily you need to replace the seal. There are many excellent online guides on how to change a door seal, just make sure you get the right size.
Sep 11, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Clothes wrapping under agitator
Somewhat inherent in this design. You can try to carefully unwrap the clothes by gently rocking them back and forth to see if you can release them, or gently spin the drum while you tug (not too hard!) on the stuck clothes. The wash plate seal might be compromised, but if you start taking the inner workings apart you have to replace the gasket set. I have not tackled this on my unit yet though I have replaced the old pump motor with the improved one (single piece instead of 2 pieces), and I have gotten adept at taking the unit apart from the bottom to remove draw strings which get sucked into the pump impeller, jamming or clogging it. The wash plate seal might be getting old - I think mine probably needs to be replaced but doing that will require more extensive repairs than just putting in a new seal. The service manual warns several times about replacing the proper seals, gaskets o-rings and/or grommets if you remove the outer or inner wash plates, to avoid compromising the water tight seals and causing damage to the U-joint assembly that gives the washer its characteristic wash motion.
Apr 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
The drum wont hold water. it goes right out the draim
The drain needs to be above the actual water level or it will run out, the pvc should be above this point in order for the hose to get air and not act like trap and run out all that comes in,< woud suggest going to hardware store and getting piece to add on to 4 inch section with a coupler and washer drain cap>. they will cut to length, < take measurement of pipe size and length needed to get just bellow height of washer top, pvc goes together by cleaning and glueing, if the 4 inch piece has angle cut then it will have to be cut to strait line for good seal.
Apr 22, 2009 | Amana NAV3330E Top Load Washer
Water leaking into washer
the seals where your water lines hook up are going bad.cant tell you which one though whether its hot or cold but its one of the seals
Jan 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune Washer dispenser unit has mold and mildew inside top of dispenser compartment.
You can pour the bleach in the drawer every time you do white loads and it will stay clear too!
Just flush it out good before you do colored clothes or you may get a small bleach spot on a red shirt !
Neil
Ps. Give me a problem solved rating here on fixya.com
Aug 19, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Water leaking from front door
not really due to therebeing 3 holes at the bottom of the door seal which lets water out that is stuck in the seal
Sep 12, 2007 | Miele W969 Washer
Water leak
If the main seal is leaking there will typically be a splash line around the inside of your washer cabinet. There is a special wrench available for removing the large nut that holds the inner basket in. This nut is aluminum and can be removed with a chissel if it is stuck. remove the inner basket and you will see cone shaped "NUT" that is covered in cork. There is a torx screw on the side of the cone shaped piece. once the screw is removed then the cone shaped nut can be removed using the special wrench and brute force.
Mar 10, 2007 | Maytag Legacy Series Top Load Washer
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
59 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
