Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
Wont start Ive replaced the motor, the gasket the impeller and washer wont start do i need to replace more?
  • Fisher and P... Master
  • 3,247 Answers
Please be a bit more specific when you say "Won't Start".
If you are able to set the program but nothing happens when you press the start button, then it is very likley the proximity switch that detects drawer close, is failing and not letting the controller start the cycle.
Posted on Mar 23, 2014
Testimonial: "I press power button washer turns on then i select cycle and press start then it makes a noise then tries to do something(maybe seal itself) then it flashes on off on the screen then goes to a f2 error"
  • Sam Mar 30, 2014
    It is very likely there is some obstruction inside the rotor cavity. The dishwasher checks if the rotor is rotating at the correct speed. The sensor that does this is below the cavity. Get a thin stiff wire and clean the channel between the rotor cavity and the filter sump. Also use a clean cloth to wipe the cavity clean. If it still makes no difference then a) check out the new rotor in the other drawer to see if it is ok. b) need to replace the sensor that checks the rotor speed.
What is causing a whistling sound when the lg dish washer is in wash or rinse cycle but not when emptying wash or rinse water?
This does sound like the problem caused by the washer motor front bearing. The sound is more a whining sound. The bearing is of poor china quality and does start giving problems due to the water seal of the impeller that has the smallest water leak. The drop of water ends up on the front motor bearing causing the bearing to eventually pack up. You need to replace the water seal that is in the plastic impeller housing. Also replace the front motor bearing and this bearing is relatively cheap. Not necessary to replace the complete motor and impeller housing. Just the bearing (number 608) and the water seal (impeller housing includes seal)
Oct 09, 2014 | LG Dishwashers
Washer wont drain showin IE
Sonia, you either have a failed drain pump, or something has bypassed the filter ( bobby pins are notorious for this ) and is jamming up the pump impeller. If you can set the washer to drain/spin and can hear the pump running, you most likely have a impeller that has broken off of the pump motor shaft and will need to be replaced. If you cannot hear the pump running, and can hear a slight humming noise, then there is something jammed in the pump. The pump can be removed and cleared of the possible foriegn object. I can provide instructions on pump removal if needed.
Apr 20, 2014 | LG Tromm Front Load Washer And Dryer Set
I have a beko wm5100 washing machine and the pump impeller has come off Ive tried glueing it but to no avail is there anything else that I can do
Robert! Am I to understand that you...Never Mind! My Friend come over here I want to tell you a secret. Glue-Water-Pressure! They NEVER work! If it is an impeller it is probably a pump. most washers have two 1) Drain Pump (impeller) and circulating Pump-impeller. You need to REPLACE either or both the entire Pump, install it. Then use/store the glue to build Model Airplanes...Not on Washers?!
Mar 15, 2014 | Washing Machines
2000 Mercury 115 ELPTO impeller replacement. The Quicksilver replacement kit comes with various washers / face seal. The water pump housing didn't have a seal on top of the old one. Am I supposed to use...
if you mean a large flat sided 'O' ring then this is to help keep water in the impellor housing !? some housings have gaskets between the base plate and housing , check the impellor in the housing and see if it stands proud as then you need the gasket ! compare with the old one as it mite have been forgotten !! check the seal and tube for the water pipe also ok!
Sep 23, 2013 | MERCURY / QUICKSILVER Mercury/Quicksilver...
How do i replace the gasket 2hp
better to just replace whole pump motor will start to squeal soon after
Jun 02, 2010 | Waterway 5 Hp 230 Volt 2 Speed Side...
Washer drum doesn't spin, no draining of liquid
If you have got rid of all the water, and it still will not spin, then the odds are it is the brushes in the motor that need replacing.
Quite a common problem
Jan 18, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Maytag dishwasher won't drain after i repaird a leaky gasket
The issue is almost certainly with the motor. Possibly the wires that were accidentally interrupted, and if not, it is jambed. It has nothing to do with your replacing the door gasket if you never touched the motor. If it is jammed, remove piping attached to flange and loosen until you see the impeller. Rotate the impeller . If it turns easily, problem possibly not motor. Let me know.
Oct 02, 2009 | Maytag MDB7100AWB Dishwasher
2003 yz impeller seal is leaking, do i need to replaice head gaskets thanks ian
I am not sure what you mean by impeller seal so here are a few scenarios:
**Note: Based on YZ250. others may be similar.
-If the gasket around the impeller housing is leaking you can replace that on its own. Open rad cap, drain the coolant using the lower screw with the copper washer behind it. Then remove the other 3 bolts, remove cover, clean mating surface, install new gasket, snug everything up, and replace the coolant.
You don't need to replace the head gaskets unless your leaking from there, or getting coolant in the engine.
The same would apply to your base gasket.
just in case:
-if your transmission/gear oil is milky, your will have to change the oil seals on the impeller shaft.
Jul 17, 2009 | 2003 Yamaha YZ 250
Washer not spinning
my ge top load washer washes but wont spin at end of cycle to ring the clothes out. if i mess around with the switch or motor wire connections it starts to spin with some help
Jan 05, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Wont spin after ive replaced the drain pump
Plug off the wall. Check to see if all the wires are securely in place, not just with the pump, but all. At the motor un-plug & replug.
Nov 29, 2007 | Zanussi F1245W Front Load Washer
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
102 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
