Question about Radio Shack Pro-96 Scanner
Pro96 PROBLEM I monitor Henrico Police in Virginia and everything was running smooth, but now i turn it on and my scanner picks up NOTHING, except State Police with high static/squelch. Yet when I go to MAN then PGM, voices will be talking on some freq.'s. I have looked into my trucked talkgroup channels and all i want to hear are unlocked. I have a new 800 MHz antenna from radioshack that has been working fine and i even exchanged it with my old/standard one, and still it doesnt work...HELP!!!!
  • Bill Buchsbaum
    Bill Buchsbaum May 11, 2010
    You didn't mention what type trunking system "disappeared" from the scanner. If it's an EDACS system it's possible that the police activated a ProVoice feature that in effect causes your scanner to ignore programmed groups and users in the system. You can tune the freqs manually, but you cannot scan them, and the scanner will not follow a conversation as it skips through the system freqs. You might want to check with www.RadioReference.com to see if the system is in fact and EDACS ProVoice. It it is, NO scanner can follow it.
  • 127 Answers
Http://www.police-scanner.info/police-scanner-frequencies.htm you may need to put in the new freq. # a few months ago most went to new freq. #
Posted on Jul 09, 2009
Police scanner frequencies marion va
RadioReference Dot Com has everyting you need. Go to their database, click on Virginia, then click on your county. Keep in mind that MANY police and fire units have switched to digital or to analog trunking, and a special scanner is required. Good luck.
Mar 08, 2013 | Radio Communications
What is ment be reflashing a police scanner
  • When police, public safety, etc re-band then some scanners may not pick up the frequencies and you need to update the firmware (when available) to keep your scanners ability to monitor certain frequencies, pairs of frequencies, splinter channels etc.
  • Hope this helps.
Regards, Tony
Oct 17, 2011 | Radio Shack Pro-96 Scanner
I have a uniden analog scanner and I want ot put in the codes (that I can't find) for Henrico County, Virginia? Also, they are on a digital system. So, I need the codes and instruction on how to...
Henrico County Virginia are operating on Digital Frequencies (854 to 868MHz) as detailed at the link below so as yours is only an Analogue Scanner (25 to 512MHz) you can't listen to their Frequencies.
http://www.radioreference.com/apps/db/?sid=556&opt=all_tg
Jul 21, 2011 | Uniden BC340CRS Base Scanner
I have a handheld Uniden scanner that is several years old. BC80XLT. My police channels went digital, but emt, fire, etc stayed the same . Do I have to buy a new scanner to get my police or can I get...
If your locals went digital they are probably using trunked systems as well. Sorry, but there is no way to convert or modify your scanner to let you monitor the new systems. You'll need to pick up a trunking/digital scanner such as the Uniden BCD996XT. Programming the trunked systems is a real task, so I recommend that you purchase the Butel ARC XT PRO software and a subscription to RadioReference.com. The combination will let you research the systems in your area, decide which ones you want to monitor, and download them straight to your scanner.
Bill B.
Listening in since the 60's
Apr 16, 2011 | Uniden BC80XLT Handheld Scanner
My pro96 hand held police scanner cuts out or breaks up when police are talking in differant locations of the city, at my house and surronding area it breaks up, at work 4 miles away it is great, i can...
Hi Bill, my name is John. Try checking your antenna for bad connections, also turn your SQUELCH to where you just barely here static, then slowly rotate it until it is clear. ...hope this was helpful
Sep 01, 2010 | Radio Shack Pro-96 Scanner
Can't pick up local Police, fire & emergency
Is it programable?If it is, turn it on,and turn the squelch till it is no noise,then push scan....hope this helps..........
Feb 28, 2010 | Radio Communications
When in the MO mode, I hear nothing. In the FM mode, I hear everything. I want just to listen to local FD. I have their codes loaded in. Just doesn't seem to scan the channels when in MO. What am I doing...
MO is for monitoring MOtorola trunking systems and will only work if you have programmed a system into your scanner. Most fire departments are using conventional, (FM) transmissions, not trunked systems - mainly so that volunteers and neighboring departments can follow the action and respond if needed. For a comprehensive database of active frequencies and systems in your area, visit:
Need the manual for your scanner? You can download and print it here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-96/pro96.pdf
Bill B
Feb 21, 2010 | Radio Shack Pro-96 Scanner
Motorola k7gt9500 police channel in manassas virginia?
Your Motorola radios operate in the FRS/GMRS band, which is at 462 MHz. Police, fire, EMS services, etc. operate in the 150 or 800 MHz bands. Your radios cannot receive public service transmissions, and they cannot be modified to do so. Monitoring public service transmissions will require a scanner.
For a comprehensive database of active frequencies and services in your area, visit:
For a good listing of available scanners, visit:
www.ScannerMaster.com
Jan 02, 2010 | Radio Communications
Scanner codes for police in hanover & richmond va
try scanner master.com if this don't work let me know and i will give you a new site.
Jan 27, 2009 | Uniden BCT8 Base Scanner
Local police frequencies 155.490 and 156.150 act like a birdie frequencies. I cannot pick up these well used frequencies on my scanner. I have to lock them out when I would like to get them due to the...
HELLO I NEED THE INSTRUCTIONS ON UNIDEN BEARCAT 50 CHANNLE BOOK OR IF YOU CAN TELL ME WHERE OR HOW TO GET IT THANK YOU MIKE HERE IS MY EMAIL MI7CE@AOL.COM
Jan 01, 2007 | Radio Shack Pro-94 Scanner
Radio Shack Pro-96 Scanner Logo
232 people viewed this question
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
