Question about Sony Audio Players & Recorders
Fisher dual cassette player recorder doors wont open
Hi I have an old fisher stereo system with a double cassette unit. For some reason the doors won't open when i hit the eject button. There is no tape in there and it was working fine. I just rolled the cabinet to a different location and now everything else works except for the cassette unit? Could it have locked itself or something?
    Top Expert:
  • Sony Master
  • 35,747 Answers
The eject mechanisms may have simply aged to a point where they no longer work. There could be dried out lubricant or a failed mechanical part.
Posted on Mar 23, 2014
  • 319 Answers
SOURCE: Denon Dual Cassette Deck DRW-660 will not eject either tape
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Posted on Apr 23, 2008
  • 4234 Answers
SOURCE: Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Posted on Oct 07, 2008
SOURCE: CT-W602R Dual Cassette Deck- door won't open
had same problem, just changed the belts and works like new.
Posted on Nov 18, 2008
CLARKPINK55
  • 71 Answers
SOURCE: Sony dual cassette recorder, cassette doors hard to open,
change al the belts that will sort it
Posted on Dec 17, 2008
Grubhead
  • 5158 Answers
SOURCE: Fisher cassette player and Fisher cd player need belts
I believe that FISHER was trade brand of Sanyo if that helps?
Posted on Mar 23, 2009
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
How do I play cds on my Philips portable stereo with the message 'door open'?
It could be caused by a small contact switch inside that has either broken or is stuck in the door open mode.
Oct 18, 2017 | Audio Players & Recorders
Download to mac computer
To make a USB audio the input sound device on the Mac follow these steps:
1. Click on Apple Menu
2. Choose "System Preferences"
3. Locate and open "Sound"
4. Click the "Input" tab
5. Choose the USB cassette player from available sources
You can use a range of programs to record the audio at this point including the latest version of Quicktime Player which has a recording feature.
Nov 08, 2013 | Pyle PT-659DU Dual Stereo Cassette Deck...
I have an Aiwa Surround Sound Theatre system Model #cx-nmt720. Has a 3 disc player, am/fm, and 2 cassette decks (one on right allows recording/dubbing) Everything works great except cassette...
The unit may be damaged or may just need adjustment- only a tape deck technician will be able to answer the question after seeing the unit. To answer it remotely like this, is really an impossible task.
Nov 03, 2012 | Audio Players & Recorders
I have a TC-WE835S Sony cassette deck I have not use for many years. Today after I insert a cassette into Deck A, it is stuck. I cannot open that side to recuprate my cassette. Please help. Your assistance...
I have the same unit...when it is "ON" ,plug the power cord off and than try to open the cassette door..
the head mechanism keeps the cassette in,power off will release it..
let me know if it does not work out..
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 08, 2011 | Sony Dual-Deck Cassette Player/Recorder...
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
Feb 23, 2009 | Sony Dual-Deck Cassette Player/Recorder...
Fisher 143a CD Changer
HI...
You wont be able to play any new format CDs on an old Fisher or any other older make . It 's the internal decoder logic that's needed. And older players dont have it.
As far as top-loaders..Do a websearch . I dont know of any.
Jan 27, 2009 | Jwin JK-777 Nostalgic Stereo System with...
Sony dual casette player/recorder
Unit may have slipping drive due to defective belt or tape may have wrapped around captsan. Have serviced
Jul 28, 2008 | Sony Dual-Deck Cassette Player/Recorder...
Much loved old J.V.C. unit
Sounds to me like the belt drive is slipping!
Need to open her up and check tightness of belt and probably try to buy another one which will be tighter!
Mar 21, 2008 | Audio Players & Recorders
108 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
