Question about Refrigerators
Thetford refrigerator problems
Fridge will not light
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
It could be the bulb, the bulb socked , the light switch , or broken wire all have to be traced. it it is the socket be sure to unplug refer take a small screw driver and bend the small metal piece up a little bity to make sure it is making contact to the bottom of the bulb
Posted on Mar 24, 2014
3 Suggested Answers
  • 68 Answers
SOURCE: thetford caravan fridge freezes all food in fridge
Thats a Norcold compact fridge. The most likley problem would be the thermister. Need to do an ohms reading. From inside of the fridge remone the thermister from the fins and unplug the wires. With a VOM set it on Ohms, touch the wires with the probes/ does not matter which probe to wire/ hold the bulb end of the thermister between your fingers, your reading should stat at about 7000 Ohms. Stick the bulb end of the thermister in a glass of ice water, reading should start climbing and go to about 22000 Ohms. If this happens the thermister is good and you need to look elsewhere. If it does not test out you need to replace the thermister. The thermister is a thermostat that controls the heat source that makes the fridge cool. If the thermister reads good you may want to get the circuit board tested.
Hope this helps
Thank you for using Fixya
Jerry
Posted on Mar 30, 2009
  • 8 Answers
SOURCE: I have a Thetford N112 which will not cool the
un plug the heating element from the circuit board and ohm it out. also check fuse on board. but sounds like the heating element has gone out. if when you ohm it its on 0 its bad
Posted on Aug 27, 2009
Today i found my thetford fridge in c/van not working on 240 power so i turned it on to gas and it workes. Any idea what might be the problem?
the fridge works by heating crystals that creates a gas that is the refrigeration
if it works on gas then the system is good and indicates that the 240 volt heating element is not working
find a caravan repair center and have it checked out
Nov 25, 2016 | Thetford Refrigerators
How do I connect my new 3097 thetford fridge
NO WAY they come prewired from the factory.
Jul 15, 2016 | Thetford Refrigerators
I have a thetford N112 fridge which works on gas but not on mains, the element heats up but fridge does not cool
Hope this answers all your questions
Leave a comment if you need more help.
Thanks for using Fixya.
Oct 16, 2012 | Thetford Refrigerators
I have error code 8 on thetford fridge how do I remove code to used on 240 v
If switching off and on again doesn't clear fault 8 (ac volts 20% lower than spec) you may need to replace the board for one with a resetting fuse.
May 19, 2012 | Thetford Refrigerators
N90 EHLtype C 11 Pilot gas wont stay alight.
Your problem is probably with the thermacouple. Contact a service company.
Apr 13, 2010 | Thetford Refrigerators
Thetford N90 EL.L built-in has stopped cooling/freezing. It has power (the light is on) Any repair suggestions?
If it won't cool on all 3 power sources the cooling unit is probably faulty. Contact Thetford asap if the unit is uner 3 years old as it should be under warranty. Thetford won't sell a replacement cooling unit, their only answer is that you need to buy a new fridge at over £600. I have this problem too and am looking for another solution but to luck so far
Mar 28, 2010 | Thetford RV Refrigerator - N300 Model -...
Aug 27, 2009 | Refrigerators
We have a Thetford N80 fridge in the caravn which will not light on gas. It clicks but no flame appears.
Try manually lighting the pilot when it is clicking. If it lights you need a new thermo couple let us know what you find out from this step
Aug 17, 2008 | Thetford Refrigerators
Thetford Fridge N112
There is a very likely possibility that the resistance heater for the 12 Volt side of the operation is open. This heater can be checked for continuity using an OHM meter from the terminals for the 12 volt .
Jun 02, 2008 | Thetford Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
