Question about Dryers
Fv lp003 Fan works but light doesn't. I replaced the light bulbs and still doesn't work. Can I replace the baluster only without buying a new fan/light? or is there any other reason why the light doesn't work?
  • Brian Bates
    Brian Bates Nov 22, 2014
    Hi - My Fv lp003 bulb are done and new bulbs don't work. Fan works fine. What is the issue here?
  • 37 Answers
SOURCE: Installation of a Panasonic Fan FV-05VFL2...
If you are not very handy I don't think I'd tackle this project. There's going to be drywall cutting, backing to install, attic crawling, wiring, ducting to attach, proper insulating. As an electrician I've done this sort of thing in between 1 and 2 hours, depending on how smooth things go. If you find somebody you trust that's done it before who is willing do to it on the side for cash you're looking at $25-$60 for labor. Is it worth it to you?
Posted on Jan 30, 2009
  • 323 Answers
SOURCE: Hampton Bay Covington 54" Ceiling Fan Light Does Not Come On
Try taking the lighting kit completely off it make sure the blue wire and white wire are both firmly connected.
Does the remote work on the fan part ok? Do you have the black, white, and green wire on the house side connected to the side of the receiver with the same wires?
You know the black and blue are hot for the fan and lights (blue for lights). If the wiring connections are ok it had to be either in the remote or receiver. Are the dip switches set for the same on each?
Posted on Jun 02, 2009
SOURCE: replace shower fan motor in a Broan model 678
I need to get the cover off of a BROAN fan and light kit. The two solutions listed did not provide me with sufficient information. Thanks!
Posted on Jul 02, 2009
SOURCE: minka aire concept II ceiling fan bulb replacement
The glass dome is tightened firmly in the factory, so removal is difficult. When removal is attempted to, the metal housing to which the dome is attached will spin with it, making removal impossible. To see what I'm talking about, look in the small space between the dome and the bottom of the blade housing - it looks like a metal flange, but this is only the bottom of the reflective metal canister that holds the light. Note that there are 4 "dimples" around the circumference of this housing, facing inward. These dimples are what hold the glass dome in place. The trick is to use a rigid piece of wood or metal about the size of a 12" ruler and place the corner of that ruler in one of those dimples - FIRMLY. Then, a second person can get some leverage on the glass dome and "unscrew" it from the housing (counter-clockwise). The purpose of holding the ruler-sized material against the dimple is to keep the housing from spinning with the dome. This is easier said than done, but it will work.
Posted on Jan 23, 2011
  • 122 Answers
SOURCE: My Hunter fan with light
this sounds like the remote in the fan went out the diod will burn out and cause this issue if you go in the fan by the breaker box and see the board you will see a burnt out diod you just need to replace the remote at lowes there about 45dollars good luck
Posted on Aug 04, 2011
Testimonial: "Thanks for taking the time to help me. I did not know where to go to find the part. I'll check Lowe's, as you suggest."
Hunter ceiling fan fan is working but lights are not
Make sure light wire is connected at the ceiling & at the bottom. Otherwise it's probably the receiver. 1-888-830-1326 ( Hunter parts )
Jan 05, 2013 | Hunter 52" Ceiling Fan With Light And...
My wall ceiling fan's control unit UC 9051T failed. Light switch button does not work. If I replace it with some generic universal unit, do I need to replace transducer located in the fan housing also, or...
First, you didn't say you checked that the bulb worked. Is that burned out?
If bulb is ok, you will have to make sure the switch is matched with the fan (ususally a set of 4, 6 or 8 micro-switches have to be set the same in both switch and fan to be on same frequency of communication - even if you have an exact US 9051T controller).
A whole new fan is not too expensive ($100) and may be best route if you use the fan alot and it is over 7 years old - just an option.
Also, just because the light doen't work doesn't mean it is the switch transmitter that is broken, it could also be the receiver. Call the company on the website below - they will either tell you how to check or you can send everything to them and they will check for you.
Sorry for making it so difficult - I hope it is just your bulb.
May 05, 2011 | Vacuums
The light fixture needed to be repaired. It never worked when I bought the house. New light bulbs didn't worked. I replaced the two ceramic light switches that had corroded wiring and reconnected blue to...
if its a duel switch that controls lights, and the fan seperately. sounds like the power for the lights is going directly to the fan, and therefore making the lights work also. also check out switch, make sure power is only going to the lights, with light switch on.
May 01, 2011 | Heating & Cooling
My 52" Hunter Ceiling Fan with remote has been a gem. Last week when one of the light bulbs burnt out, I replaced the bulb, and then neither of the lights (it's a 2 light bulb fan) would come on. The fan...
The two bulbs are just having a separate live cable in parallel with the one of the motor.
So since you have mentioned that you had a burned bulb this sometimes causes a short inside the receptacle of the bulb. So you just need to disassemble the receptacle of the burned bulb and check both the wires live and neutral they are loose or disconnect or even melt and disconnect.
Is a simple operation since you need to check only two wires however it not so easy to remove the bulbs and reconnect the wires.
Oct 16, 2010 | Hunter 52" Ceiling Fan With Light And...
Minka Aire Como F603 ceiling fan - light bulb replacement
Try Googling (Minka Aire)(F603)(manual) without parens for instructions.
Jul 28, 2017 | Minka F603-WH Ceiling Fan
GE spacemaker microwave model #JVM1650SH
Allways unplug when your working inside a microwave, you will most likely have to replace the bulb again and also the fan, or anything else that is damaged, you will need to inspect the microwave for broken parts.
Il get you a few links to repair parts.
Sep 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Fan stopped working then globe and remote stopped
Hi there
Yes, unfortunately it is another common fault, sad really lol
The remote not working could be due to the little remote sensor board that you will have seen when taking it apart (I have a service manual if you would like it), do any of the buttons on the unit itself work that you know of?
The bulb not lighting issue can be a number of things, usually a safety wise. When you replaced the fan, what were the specifications of the fan you used? Usually computer fans differ slightly to the ones used in this model, and can cause them to fail and the unit to over heat. If the projector switches on for a bit and then turns off, it means the safety thermostat in it is cutting out preventing overheating, you could try bypassing it just to see if the bulb will ignite. I know it may sound a bit dumb but check the safety switch on the door is fully in?
If you would like the service manual I could send it to you, I found it very helpful with mine, also a forum, I think AVS was extremely helpful aswell.
Sorry if this doesn't help, I will look into it further
Jun 17, 2008 | InFocus ScreenPlay 4805 Multimedia...
Ceiling fan lights do not work
You may have shorted out the light kit. Did you remove the other bulbs and put in new ones? They may have all blown when you heard the noise. Try that first, and if it still doesn't work, you may have to buy a new light kit. They are not expensive, and you can buy one without the glass bulb holders or cans, whatever you have. Then you can still use yours after you install the new light kit. Good luck!
Jan 05, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
167 people viewed this question
Top Dryers Experts
