Question about Moen & One Handle Tub & Shower Faucet
No water in tub
Replaced cartridge and now I have no water at all
  • 40 Answers
You may have some obstruction. remove the cartridge and check if there's anything in the valve body. sometimes the rubber pieces on the cartridge can dislodge. you might try to flush a little water through the valve before you put it back together. remember Moen says "buy it for looks, buy it for life." The cartridge is guaranteed for life.
Posted on Mar 25, 2014
Danze UPC tub/shower valve leaks constantly at tub spout
shut off water and pull cartridge...go to lowes or plumbing supply and match up cartridge and replace...you may also just replace seats and springs if cartridge is ok....cheaper...but if not sure just replace whole cartridge...make sure hot is on left...
Aug 15, 2011 | Danze Home
I have a Moen tub and shower system similar to the Moen 2919 Chateau two handle above. When I turn on the faucets up to 1/2 way everthing works fine. If I try to increase the water capacity by turning up...
To talk about your problem forces me to assume a few things.....If you allow the water to flow without cartridges and handles, the water must be flowing straight through the cartridge channels and out into the tub. It is not flowing through your tub spout or shower head when you test the water this way. If I'm correct, then the problem is isolated to the water mix operation. That means coming out of your spout or shower head. So now I have to ask a question. When you operate as normal (cartridges and handles installed) does your problem show up only on your shower head or does it also show up when operating out of the tub spout? If the problem is isolated to the shower head, try a head replacement. It may be partially plugged. If it's head or spout there may be something in the mixing pipe that only shifts around as pressure increases. I hope that is not your problem. It would require pulling those pipes out for inspection and most likely replacement. Nimsgame
Feb 19, 2011 | Moen 2919 Chateau Two Handle Tub and...
We had our hot water tank replaced and now our water flows really slow out of the tap of our tub. Yet the flow is OK from the shower. We have the single handle faucet. It seems you have to pull the little...
It is not uncommon for one or more faucet devices to go haywire immediately after a water heater change out, especially if the cold water line to the water is galvanized metal pipe and is quite old. while this scenario is the most common, it is not the only possibility. Sometimes it's just plain coincidence in the timing of events.
I would remove and replace the #1222 cartridge, inspect it for obvious debris from the heater replacement, briefly turn the hot water supply on to flush out any possible debris in the valve body itself, then reinstall the cartridge. Valve flushing should always be done before any cartridge gets reinstalled.
If the problem persists, the diverter on the tup spout would be my next focus. Again, debris from the heater replacement could (but far less likely) have affected its function. While not as easy to remove and exactly replace, by taking it off...then turning the water on, you will be able to observe the flow difference..With no difference the problem is in the valve and the cartridge should be replaced....with significant flow difference the, replace the tub spout. Be sure to take the tub spout with you, if it's the problem, when you take it to your plumbing supply store so it can be matched to a replacement. There are many tub spouts for many situations.
Search this site for Moen cartridge removal procedures. I have posted numerous solutions.
Nov 09, 2010 | Moen Posi-Temp Single HandleTub And Shower...
No cold water from Moen 2253 tub/shower valve, when i turn handle to cold I get hot water, when handle is turn to hot i get hot water
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Apr 05, 2010 | Moen & One Handle Tub & Shower Faucet
The hot water is not working at our tub. we had the water turned off for a couple months and I believe sediment is in the line. The hot water works everywhere except at this one tub. i need instructions on...
Your problem is most likely a bad cartridge.#1 turn off water in house #2 remove handle #3 you will see a horseshoe shaped clip that holds in cartridge remove clip and try to pull cartridge straight out you may need to purchase a moen cartridge removal tool for easier removal and install new cartridge and replace horseclip
Nov 14, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Water will not turn off
are the handle extensions on the cartridges all the way. i know sometimes the moens are a pain after you put the trim on to get them on and seated right so it actually spins the cartridge. also check the cartridge alignment the cartridges have little white tabs on the sides that correspond with a slot in the valve body if they aren't aligned it won't shut off either
Jul 31, 2009 | Moen 2919 Chateau Two Handle Tub and...
Single handle facuet for shower/tub leaks hot water
change the cartridge it is bad,it has rubber gaskets on the outside of the cartridge it is worn,just replace it and it should work,it may also be trash in the way.take out and shake,if this does not work replace with new cartridge.
Jun 07, 2009 | Moen & One Handle Tub & Shower Faucet
Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
Low water flow in Shower
Definitely try reversing the cartridge.
Mar 11, 2009 | Moen & One Handle Tub & Shower Faucet
Moen & One Handle Tub & Shower Faucet  Logo
54 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
