Question about Toshiba Satellite L745-S4110 Laptop 2.3GHz 4GB 500GB DVDRW WiFi Windows 7
Every time I plug in my charger it blows the house fuse
Do I need a new charger?
  • 128 Answers
Try to plug it into different outlet in different room..... if it happens again, then check wire (cable) that goes out of adaptor to wall, if there are some visible damages, or brakage, change either cable, or whole charger unit....
Posted on Mar 23, 2014
I have garmin nuvi760 gps when ever I hook it up in my car fuse in car charger cable blown up, I changed the fuse several time ,it does the same thing,it takes 3amp 250V fuse.I realy need help.
You need to determine if it is a charger problem or a problem in the Nuvi.
If you have the AC wall charger, plug that into your Nuvi. If the unit boots normally, then you can discount that there is a problem with the Nuvi. Does the Nuvi power up on its own internal battery with the charger disconnected? When you change the fuse and it blows, is the charger plugged into the Nuvi?
Try changing the fuse and powering up the charger without it being plugged into the Nuvi. If the fuse still blows, then the fault is with the charger. Please also be aware that the charger converts +12VDC from the car battery to +5VDC to power the Nuvi. Some chargers can fail and provide +12VDC directly to the Nuvi. This can damage the Nuvi and will certainly blow the fuse.
Sep 23, 2015 | Garmin nuvi GPS
Every time I plug my phone charger in power outlet the fuse blows. hyundai sonata 2013 why
I would just run two new wires from battery , and fit an after market cigarette lighter socket to you car . or just run the wires to the existing charging socket , and remove the factory ones . then you could use a heavier gauge wire and fuse . this is just an idea .
Mar 28, 2014 | Vehicle Parts & Accessories
Samsung nc10 charger blowing fuse?
The charge adapter is faulty. You need a new power adapter for your model Samsung notebook.
May 20, 2013 | Samsung NC10-14GW Notebook
My 2006 VW Beetle continuously blows the Accessory fuse utilized for the power port for the cigarette lighter and underneath the center console. The proper fuse was replaced. Only my phone plugged in when...
Hi Troy,
Without seeing the ports of the car and the plug of your charger, it would be difficult to diagnose with any certainty. I do have a suggestion however. Your note suggests that other devices do not cause the fuse to blow when they are used - it is only the charger for the phone. Since the charger works in other cars, it is probably not an overload condition due to a defective charger, but more likely a mismatched set of contacts between the plug and power port in your car when the two are mated. Some cars have slightly different sized power ports that can be either too tight or too loose for some plugs. Too tight ports could be causing parts internal to the charger's plug or car's power port to short together and blow the fuse.
We can get around this be using a different plug. The easiest way is to find a cord set that will plug into your car's power port and provides a simple extension for 1, 2 or 3 outlets. These can be found in auto parts stores and the automotive departments of stores like K-Mart, Sears, etc. Some examples look like these:
Insert the plug into the power port - and check that the fuse does not blow by checking the fuse - not by plugging something into the the outlet on the cord. If the fuse remains good, then it is safe to assume that the problem with your charger and the car's power port has been eliminated, and the car's power is available at each of the outlets of the new cord.
Try plugging the charger into the outlet of the new cord. If all is well, the charger should be working as expected. What we have done is removed the charger / car power port combination from the equation, by providing a different combination to do the same thing - but without the same physical connection that causes the fuse to blow.
You could achieve the same results by changing the charger plug under the right conditions - but many chargers now a days have circuitry inside them that change the car's 12 volts to something different. If you can find the voltage out of the charger and are able to match it with another - it must be the same voltage, polarity, current and phone power connector of course - it should work, too. You must be absolutely sure of the power requirements and your rewiring - if not, stick with the addition of a cord described above.
I hope this helps & good luck!
Aug 27, 2012 | 2000 Volkswagen Beetle
My aquabot keeps blowing fuses in or out of water
may be waterlogged. internal seal failed and its shorting out..
Aug 06, 2012 | Pool & Spa
It blows the fuse everytime I put the cell phone charger in. Going to change out lighter and can't figure out how to get behind the dash on 2002 Sebring
most of the time its the cell phone charger that is the problem. the ones with the cheap plug that has the fuse inside it are the worst. try the lighter in it, if it works without blowing the fuse then you should get a new charger or replace the plug with a good one
Mar 30, 2010 | 2002 Jeep Wrangler
My charge port in my 2006 cadillac cts repeatedly blows the fuse. How can I fix this?
Does the fuse blow every time you plug something into it? I guess what I'm getting at is it possibly your phone charger only, or does the fuse blow when someone else plugs thier charger in (different charger)? I guess if the fuse blows, no matter what you plug into it, I would suspect the charge port itself. Does it seem like it's loose in it's mounting bracket? You may have to replace the port.
Jan 03, 2010 | 1995 Cadillac DeVille
Dell Inspiron 6400 charger not always working
u r very correect its the time for new 1 to be bought. u can get the new 1 from radio shack websites. and also dont try to use that faulty charger again as it can possibly blow the laptop electrical parts internally due to any over power short circuit.
Jan 04, 2009 | Dell Inspiron 6400 Notebook
Fuse Keeps Blowing In Car Plug
try using a 3a or high fuse
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUAL 7" dvd player
Feb 09, 2008 | Durabrand Portable DVD
Toshiba Satellite L745-S4110 Laptop 2.3GHz 4GB 500GB DVDRW WiFi Windows 7 Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
