Question about Dryers
Dryer won't start 7yr old dryer, was working fine yesterday, today was making strange buzzing noise while running, stopped it to check, and now won't turn back on.DEAD
    Sergeant:
  • 222 Answers
Sounds like a defective motor starter contactor. DO NOT continue to try to use the dryer or you'll burn the motor out. The motor starter is built into the motor, but most are replaceable without replacing the entire motor.
Could also be the motor, but sounds like the motor is stuck in 'start' mode and never goes into 'run,' which would be the classic symptom of a stuck motor start contactor.
Posted on Jun 15, 2009
  • David Mcintosh
    David Mcintosh Jun 15, 2009
  • David Mcintosh
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Kitchen Aid Dryer Gas/Front Loading Model KGYS750JQ1
Does the noise stop when you let off the start button? If so you either have a bad motor or something has gotten into the blower keeping it from turning. If the motor is running but drum not turning, you have a broken belt. Please post the complete model number from the dryer and I will try to help you with diagnosing and repairing the problem.
Thanks/Mike
Jan 07, 2008 | Dryers
We bought our dryer new 2.5 years ago and up until today it's been working great. ran it yesterday with no problem. put clothes in it today, pressed the start button and it made the buzzing noise as if...
Dryer motors are common for lint build up in the motor at the motor switch. If you get the dryer apart again use a vacuum and small paint brush or compressed air and blow out the motor. Make sure you clean your external vent frequently and do not use flexible vinyl ducting. Also, make sure you check the blower for any obstructions as this will also prevent the motor from starting.
Jan 07, 2011 | Amana NED5200TQ Electric Dryer
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Electric Kenmore Dryer runs short time (seconds) and then stops.
your thermostat/s are not doing their jobs. They are allowing your dryer to overheat and also if your dryer has not been cleaned out on the interior you might want to do that. I've taken out globbs of lint build-up in them.
Mar 25, 2009 | Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Amana gas dryer wont start. just makes a faint buzzing noise
The drive motor starting capacitor is likely dead. This can be tested if you are competent enough to take the thing apart and use an electronic multimeter. Otherwise it is a cheap part to replace, depending on how much the repair guy charges for labor and to be called out.
Mar 18, 2009 | Amana NDG5800 Gas Dryer
Dryer makes a loud buzzing noise then quits working.
Sounds like the motor's done. That thing is probably the start-run switch. Not worth trying to fix on an old motor. I've found dryer motors to be fairly generic, you should be able to find a replacement. I use Repairclinic.com when I can't get parts locally.
Nov 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
Kenmore elite HE3
You need to check if the Spray Arms are knocking against an item in a basket. If the source of noise cannot be determined, run a program without plates or glassware. If the noises continue, let me know for further investigation.
Oct 05, 2008 | Kenmore 82822 Electric Dryer
Kenmore gas dryer runs but not heating
Try replacing the valve coils first, then the valve if the prior doesn't work. If there is a buzzing noise, I believe it's more likely the valve. I'm replacing both on mine to be sure.
Aug 18, 2008 | Kenmore Dryers
Dryers Logo
120 people viewed this question
Top Dryers Experts
Marvin
Marvin
