Question about GE GTDP180EDWW
Dryer smell like grease
After shut down and setting to cool open the door and the dryer smells like grease and the clothes pick up the odor. No noises dryer functions fine. Just smells like grease??
Master_Tech
  • 770 Answers
SOURCE: GE Profile Harmony Dryer - not drying clothes
Check your email
Posted on Apr 29, 2008
jsrock516
  • 5911 Answers
SOURCE: burning smell coming from the dryer!
You have a serious clog somewhere in your dryer exhaust ventilation. I would recommend you STOP using the dryer immediately and clean both the interior and all the vent ducting from where it exits the dryer to where it exits the home. the burning is coming from lint build up in and around the heating element and its beginning to smolder. This is a potential fire hazard and may end up causing the heating circuits to fail. The condensation comes from the the inability of the hot air (which is mixed with humidity from your clothing) condensating inside the vent duct. The lint starts to collect and get wet to the point of saturation. Then it begins to cause water to form and leak out of the ducting and on to your floor. You do not want this condensation inside the dryer where the heating circuits are. The following link will provide with some guidance for future reference:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention the paragraph where it discusses proper dryer ventilation. I hope this helps you. Let me know if I can be of further assistance.
Posted on Sep 28, 2008
SOURCE: GE Dryer smells like its burning
the burning smell may be caused by a belt some have a look at the belt
Posted on Mar 07, 2009
  • 1122 Answers
SOURCE: burning smell from dryer
you smell lint heating up,when is the last time you had your lint trap,lint exhaust,and wall lint hole cleaned out,that is your problem(very unsafe could catch on fire inside the dryer,let me know-mike
Posted on Apr 10, 2009
buffalonyman
  • 1865 Answers
SOURCE: Dryer shuts off after 15 minutes and needs to cool down then will start again and the cylec continues!!On, off,on, off.
The problem is more likely a high temp limit switch. I don't have a schematic of your dryer, but one should be included somewhere on the dryer. You have to use a voltmeter to test the components in the circuit. The thermostat controls the heat temp, you may want to start there
Posted on May 07, 2009
My clothes smell after drying them
Have you cleaned the dryer? You should clean out the heating coil area at least once a year. Lint can build up and burn and the odor is drawn into the dryer when it runs.
Nov 18, 2013 | managemylife.com
Odor
if you have a bad odor,pull off the vent line from the back and see if an animal is dead there,i've found dead birds,mice and a possum,in the blower wheel of some dryers,they get in from the outside hood,once they get into the vent line and slide down they can't climb back out or if the dryer is running the wheel does a job on them.also if you had some painting or staining done this also can make the dryer smell bad.this is going by what i've found when someone complains about an odor in the dryer.hope this helps,one more thing if the motor is overheating from the dryer not being cleaned out it could have like a shellac smell,you might have to take the dryer apart to see what's stinking or it could be something near the dryer,when the air is heated in the dryer it makes the smell worse but if you find waht is causing it and remove it the smell will go away,if it is from a dead animal you can wash down the area with soapy water,you don't want to use anything with a strong smell because your clothes will smell of that when the dryer heats up.what does it smell like?
Apr 13, 2013 | Maytag Atlantis MDE6400AY Electric Dryer
I own a Bosch Nexxt Series Electric Dryer, the clothes come out with a petrolium smell, grease or something. I have cleaned the trap, duct work, bearing shield to no avial. It is not the washer, the
Instructions
Dryer Does Not Turn On
Ensure that the dryer's power supply cord is firmly plugged into an electrical outlet.
Inspect the structure's fuse box for a tripped fuse. Each fuse is assigned a single "On/Off" switch. If any fuse switch is in the "Off" position, flip that switch to the "On" position. If the problem persists, contact a professional electrician.
Press the "Start/Stop" button on the left side of the dryer's control panel.
Close the dryer door firmly so that the door clicks into place. The dryer will not operate if the door is not shut.
Lint Filter
5
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull the lint filter out of the dryer. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then reinsert the filter and close the door.
6
Turn the dryer off and allow at least 30 minutes for the dryer to cool, as excessive heat can cause a drying program malfunction.
7
Increase the ventilation of the room the dryer is located in, such as by opening a door or window. Excessive heat will cause the dryer to automatically turn off until it cools as a safety measure. Increasing the ventilation will help keep the dryer cool.
Clothing Not Fully Dry
8
Clean the moisture sensor. Open the dryer door to access the moisture sensor. The black-colored sensor consists of two bars, and is located at the front of the dryer's tumbler, to the left of the lint filter. The sensor should be cleaned with a clean cloth and white vinegar once per month.
9
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull out the lint filter. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then insert the filter back into the dryer and close the door.
10
Spin the laundry at a higher spin speed in the washing machine before placing the laundry into the dryer to reduce the moisture content.
11
Turn the dryer off and allow at least 30 minutes to pass for the dryer to cool, as excessive heat can cause a drying program malfunction.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
When drying clothes in my gas dryer, you can smell gas upon opening the door. If the dryer is not running, you do not smell a gas odor. Sometimes our clothes also have a gas smell.This just started a week...
Hi, from what you describe, it sounds like you may have incomplete combustion, which would leave a residual odor while burning. Check your vent, on the outside where the flap opens and the exhaust leaves the building. Anything blocking that vent may cause an air flow problem. If you have good air flow when the dryer is running, the problem is going to be at the gas valve/burner and may need a professional. In my town, the gas company will come out and check problems like this for no charge, they don't replace parts but are good at troubleshooting. Best of luck.
Jan 17, 2010 | Estate TGDS740JQ Gas Dryer
Gas smell inside maytag neptune gas dryer
gas has an oderant added to it and in your dryer in the cool down it allows most of the gas to be removed.if you smell gas when the dryer is off and empty, then you have a gas leak.thanks karl
Jan 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Clothes come our smelling bad
Run a load empty on the hottest setting with a cup of bleach.
Then, after finished using the machine each day, leave the door open for a few hours to allow the rubber seal to dry.
Jun 30, 2009 | Zanussi FLA1001W Front Load Washer
Bad smell inside dryer
that's because it's brand new. See if it goes away in a month. After a load has dried leave the door open for a bit. What does it smell like?
Feb 27, 2009 | Kenmore Dryers
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
GE GTDP180EDWW Logo
70 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
