Question about American Standard Water Heaters
Water wont heat up
The hot water is running cold.
    Sniper:
  • 61 Answers
You didn't indicate model, etc., but consider the following:
If an electric unit:
1-Check the circuit breakers,
2-Some units have a reset on the unit, check that,
3-If this is an older unit, the heating element may be gone and need to be replaced.
If a gas unit:
1-Ensure the gas is turned,
2-Ensure that pilot light is on, if not, relight UNLESS...,
3-If automatic lighting, does unit spark when attempting to come on.
If this unit is over 10 years old, I would recommend completely replacing it rather than repairing it if the above doesn't work. New units are much more efficient and the savings could outweigh the cost in the long run.
Posted on Mar 31, 2014
4 Suggested Answers
SOURCE: cold water ok, no water flow from hot water lines.
Bypass valve incorrectly set
obstruction or dirty tank
plugged line - lime or other! does cold flow into tank ok?
Tank is split water going somewhere you can't see - this should be obvious.
There is not really anything to obstruct the flow normally so there
would have to be an obstruction somewhere. Lime, junk, garbage etc build up .
On my coach I have lots of pressure on the cold side so hot would have to have the same unless there is an obstruction into or out of the tank. If in the bypass position you have sufficient flow than the lines are ok and the problem or obstruction is in the tank itself. Drain the tank, leave the bottom plug out, open up the pressure relief valve. Turn on the water and see if you get a lot of water draining from the drain hole on the tank. There should be a lot of water coming out of the drain hole. If so that tells you that your getting sufficient flow into the hot water tank. If so your problem is the water getting out of the tank. Like a clogged return line or an obstruction from the water tank to the faucet. A dirty scale lined tank can do a number on tank water flow. Also check to see if the water is going somewhere else, your tank could be split and you just can't see where the water is going!
Posted on Feb 07, 2010
SOURCE: reliance model 852krs wont heat the hot water is
Ordinary tank-type electric water heater can be repaired by homeowner using generic parts from hardware store.
Open pages below to access full water heater troubleshoot
1) If you have no hot water, then upper element is not getting power.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
http://waterheatertimer.org/How-it-works.html
2) Check circuit breaker.
3) Open top cover located on side of tank, and remove insulation and push in red reset button.
If reset is not tripped or will not reset, then replace upper thermostat with generic thermostat from hardware store.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 10, 2011
  • 5245 Answers
SOURCE: not hot water or heating
Good luck with the repair.
We always stand ready to support success.
Also post the brand and model number and type of product so expert can identify if you have electric or natural gas or propane energy, and identify if there is basic information online about your product.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Aug 30, 2012
Hot water runs but heating wont. Pump continously overunning.
What do you mean when you say that 'hot water runs but heating won't' ? Do you mean that water is coming out of the hot water faucet, but that it is cold? When you say pump continuously overrunning, what pump and what do you mean by overrunning? I would like to help you, but I'm not sure what you are asking. Also, is this a water heater, or a boiler?
May 26, 2016 | Water Water Heaters
The power button wont come on to heat
Troubleshooting a Tank-Type Water Heater That Won't Start ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
Whether your water heater runs on gas or electricity, it needs a controller to cycle theheat on and off, or the water in the tank would either be stone cold or ... If the buttongoes in and stays in, the thermostat should start working again. ... Screw in a new element, reconnect the wires, refill the tank and turn the power back on.
Troubleshooting Electric Water Heaters in MINUTES ~ Step ...
? 7:01
https://www.youtube.com/watch?v=SlyStHM9Nr0
Oct 4, 2013 - Uploaded by electronicsNmore
AFTER you establish that there is power being supplied to thewater heater .... When the water is cold in the tank the top element will come on first, heating the ... is overly hot and then notice no hot water check the reset button.
Tanklets: Electric water heater problems
Jan 25, 2016 | Water Heaters
Repair a cold water leak at the bottom of my water heater
Hi -
If your water heater is working (ie: making hot water) then most likely your heater isn't leaking. Rather, the leak is coming from the cold water supply and running down the tank where you see it at the bottom of the tank. A working tank that is leaking would produce a leak of hot water - not cold. You should carefully check the cold water piping for a leak, drip or stream of water and make the required repairs.
Dec 02, 2014 | Water Water Heaters
Tank full of hot water,faucets deliver only cold,water trickels into tank with rapid intermittend pump action
1) Copy following link:
http://waterheatertimer.org/Crossover.html
2) Add comment with clear description of water heater, fuel type, and pump?
Is this a pump problem or water heater problem?
Is this a water well pump?
Are you getting good stream of cold water at tap?
Which water heater do you have?
Is the heater new?
Or older heater that stopped working.
Dec 27, 2012 | Atwood 10 Gallon Gas/Electric Water Heater...
Hi there, I have a bosch aquastar 125b waterless tank. My problem is that i am not getting hot water at all. The water runs during the shower and it stays warm. HELP!!
This should run two showers at once with no problem. If you have a shut off valve on the cold side of the heater, try closing about halfway. This will slow the water flow and the water will have more time to heat up as it pases through the tank. If you dont have a shut off valve, just cut back the hot water valve on your shower and do not use any cold water. If it gets too hot then turn on a little cold water. The object is to slow the speed of the water going through the tank. Tankless heater take a little getting use to but they work great when you know how to treat them. On my shower I turn the hot all the way on until it gets hot and then add a little cold water to bring the temp down. You may have too much water going through too fast to be able to heat it up to what you need. Try this and see how it works.
Mar 26, 2011 | Bosch AquaStar 2400ES-NG
Also, the copper pipe that is supposed to carry cold water into tank is very hot, hard/if not impossible to tell cold pipe from hot water pipe. I was told my Rheem AC has an energy feture that release the...
That is normal, the heat just rises from the hot water, the pipe on the right should be cold and if you were to run hot water anywhere in the house it will immediately cool of the cold inlet pipe and you can feel it
Jun 26, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Parkray Cumbria efficiency problem
Some circulation pumps have a 3 phase mixing valve (cold,warm,hot) to regulate the water pressure in the building; no way to know unless you trace the plumbing. Basically, the hot water temperature could be lost because the circ-pump is cooling it with the cold water supplied to it. This is used to balance the pressure (aka Pressure Balancing Circ-Pump), so heater is really working overtime to heat the water. If the pump has two in and one out that's more than likely your problem; but you should consult a "old-school" plumber in your area.
Nov 25, 2008 | Water Heaters
Water Heaters Logo
114 people viewed this question
Top American Standard Water Heaters Experts
Steven House
Don Eagan
Gil Shultz
Are you an American Standard Water Heater Expert? Answer questions, earn points and help others
