Question about Canon MultiPASS MP360 All-In-One InkJet Printer
Scanned photos had some colored streaks
When I scanned few photos in this model, there appeared to be some vertical colored streaks in the scanned photo. How can I fix this? Hope to get a reply from you soon. Thanks in advance.
Pamela
  • Anonymous Apr 05, 2008
    i change both cartriged - colur and back but black want print at all
    Genius:
  • 2,985 Answers
1. Clean the Glass.
2. Re install the software.
Still in triuble>
Faulty CCD
If it is a failry new machine get it exchanged under warranty.
Manufacturers webs site for further info.
Posted on Nov 03, 2007
Images have a streak of color in the middle
The problem you describe sounds like moire.
Try scanning the image at different resolutions until the effect disappears.
Dec 12, 2013 | Kodak i1420 Pass-Through Scanner
My Canon MF4150 multifunction device started displaying streaks (or black vertical lines) on pages scanned via the ADF. These streaks appear when scanning from Windows 7 (64bit home premium) as well as...
Hello I just figuered out this problem. When the paper is feed thru the ADF ( Automatic Document Feeder ) there is a plastic piece with a plastic film. Check to see if #1 that plastic film is clean and #2 That the Film is not bent and created a crease which is the line that shows when try to print or scan using the ADF. Hope this helps
Dec 28, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
I was getting streaking across all photos that I was scanning. So bad that I researched getting a new scanner. Then one day it started working just fine. Now today I scanned some slides and when I tried to...
sounds like the scanner is skipping pixels. that is usually a sign of malfuncting. the best solution is get a new one. cost of getting new one is much cheaper to repair it.
Oct 17, 2009 | Canon CanoScan 4400f MultiFunction Color...
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Color distortion with HP 2300 scanner
Hp scanner 2300c
while scanning a blue or red line appears on scanned imajes
Mar 17, 2009 | HP ScanJet 2300C Flatbed Scanner
Yellow streak through color image scan
http://www.carlmcmillan.com/CanonScanner/Canon.htm
Feb 25, 2009 | Canon CanoScan 8400F Flatbed Scanner
Pictures scanned with Canon 4200f show streaks
when scanning photos and especially magazines, don't go to low on the dpi (at least 300) and select DESCREEN as well as grain correction: HIGH
Dec 31, 2008 | Canon CanoScan 4200F Flatbed Scanner
I620 scanner
Is the scanner scanning normally otherwise? Try scanning a printed matter with white background and if it is okay, then the streaking may be because of excess brightness chosen. Check if the paper movement is at constant speed. If it is smooth paper, it may slip and the same area may scanned again, appearing like a streak.
S. Moha, Chennai
Nov 07, 2008 | Kodak I620 SHTFEDSCAN Path-Through Scanner
My scanned color photos
  1. Check the automatic brightness and color settings by doing the following:
  2. Click Settings , click Scan Settings and Preferences , then click Preferences .
  3. Enable or disable (depending on their current state) the Automatically adjust exposure and/or Automatically adjust color settings.
  4. Click OK .
  5. Expand the scan preview by clicking the arrow on the right, and then adjust the Color settings prior to performing a final scan.
  6. Sometimes the scan will pick up reflected colors, try rotating the original 90 degrees and then scan again.
  7. All models except the PSC 1100 and 1200: If the scan still is not right, try resetting the all-in-one back to the factory default settings. Follow these steps to reset the defaults:
  8. Press Setup or Menu depending on your model.
  9. Press the Right Arrow or the Down Arrow until Maintenance or Tools appears in the Display, and then press Enter .
  10. Press the Right Arrow or the Down Arrow until Restore Factory Defaults appears in the Display, and then press Enter .
  11. Reset the all-in-one by unplugging the power cord and then plugging it back in. This will force the all-in-one to recalibrate
Good Luck
Aug 12, 2008 | HP Officejet 5510 All-In-One Thermal...
Canon MultiPASS MP360 All-In-One InkJet Printer Logo
67 people viewed this question
old marine
old marine
