Question about Siemens Washing Machines
Siemens avantgarde washing machin stopping at rinse stage
Siemens avantgarde washing machine stopping at rinse stage
  • 957 Answers
Does the washer pump out the water after the wash cycle? If not then check the drain lines coming from the pump to make sure that they are clear. Your pump not pumping will cause the machine to stop working as well
Posted on May 31, 2014
  • 183 Answers
SOURCE: washing machine not spiining
sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
Posted on Dec 25, 2007
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
Posted on Aug 07, 2008
aborcass
  • 2651 Answers
SOURCE: washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Posted on Feb 23, 2009
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
ghost4548
  • 776 Answers
SOURCE: nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Posted on Jun 30, 2009
Why doesn't it go past the "pre-rinse" stage?
I would say that there's a very high probability that the heater in the machine has failed. It does the cold pre-rinse but when it gos to the next stage and tries to engage the water heater it detects an open circuit and faults out. You will find replacement heaters on eBay and probably videos on how to replace on YouTube
Sep 15, 2015 | Hoover Washing Machines
MY WASHER IS BLEEPING AND GOT A E;18 ON IT AND WONT FINISH ITS CYCLE
where does it get too??
machine take in washing and lock the door
then add water in stages
and usually heat it as they go
once it comes up to temp
it washes
then it rinses
if it gets to rinse past a water in rotate and wash
then spits the dummy
its most often outlet waste pump or something inside the rubber
between the drum and the pump
if its a front loader and you have kids or dogs
check for rubbish like plastic stuff
inside the drum skin {outer}
ive found in the last week five machine
three had doggy do bags inside the skin melted over the heater
E18 is a timer error with drain
so check out all the drainage
bearing in mind what can get trapped in the pump
brazier wires coins screws nails small plastic bags etc etc
depower the machine at the mains
clean any blockage
then when you power back on
press first the power on or start stop
then mains it should give a long beeeeep and reset...
and not try to carry on the failed cycle
Aug 16, 2014 | Siemens WFXD8400UC Front Load Washer
Siemens E14-16 Washing machine is not taking the softener when rinsing and posibly not rinsing completely. the dispenser drawer is clean and flows correctly when filled with water. I have checked the...
Same problem with same Siemens E14-16
Cleaned soap drawer inside out (no more black gunge) but still full of conditioner after full cycle and rinse despite 2 internal valves completely cleared and connected
What could be wrong ?
Feb 13, 2012 | Siemens Washing Machines
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
My siemens WD1252 doesn't change from wash to rinse
Hallo,
I have the same problem since yesterday. I've seen that probably it doesn't warm up the water. If I change washing temperature to "cold" everything works normally. I think that heater is broken.
Have You resolved your problem? Have You called service?
Best regards.
Bartosz
May 01, 2010 | Siemens WDi1640 Front Load Washer / Dryer
FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Dec 26, 2008 | Whirlpool AWM8143 Front Load Washer
When the washer go s on rinse the prewash flashes Problem
Mine has been doing the same ... each time it goes to the next part of the cycle the red light flashes but the machine doesn't do anything ... so up till I have been able to get the machine moving to the next stage by pressing the "Start" button ... unfortunately the machine will pause on each stage - meaning I have to press "Start" at each stage!
Dec 15, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Washer doesn't stop
select a hot wash of some kind and check if the water heats. if not, problem could be heater or associated stat
Mar 30, 2007 | Hotpoint WF430 Front Load Washer
Washing Machines Logo
194 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
