Question about BenQ MX615 DLP Projector 3D Ready Projector Lamp
Out of focus
The projector is always out of focus. The screen display is off focus a bit . I have tried out all lens focal ring adjustments but can get to the right focus. No issue when the projector is new. Issue happened after 2 years of usage and it is now out of warranty.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
The glasses in the Lens are failing.the glasses were burned
you need the new Lens, USD80
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Posted on Mar 24, 2014
How can I adjust focus?
Turn the grey ring around the lens (where the light comes from) until the image is sharp.
Apr 11, 2016 | NEC VT595 Projector
I have an Infocus LP70. My question/problem is in regards to the lens. I dropped the projector from about a foot off the carpet and onto the lens. The focus/zoom became jammed together, AND the lens came...
What I would try to do is, loosen the screw so its not stiff to adjust, adjust the lens to the right position then tighten up the screw again. Hopefully this should work for you!!
Nov 03, 2013 | ASK Proxima InFocus LP70, LP70+ and...
Mitsubshi sl4su
THis is a very short throw even for a "short throw" lens. I would verify that this is the proper lens by its numbers and verify what you should be seeing by its tech specs (focal distance./image size to be expected)
Jan 09, 2013 | Mitsubishi SL4SU ColorView Multimedia...
How to focus my document camera
  1. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  2. If your Camera has Auto focus, Press the auto focus button on your document camera's control panel.
  3. Reset your camera to Default by Pressing MENU > Default > Yes > Enter. Then Power-Cycle your camera.
  4. Check your output device's focus adjustment.
  5. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  6. If Manual Focus adjustment is available on your camera's remote control, try adjusting back to focal point from the remote.
  7. If your camera has a Manual focus knob, manually adjust the focus by turning the focus knob located on the camera head.
  8. If adjusting the focus knob does not focus the image, please click here http://support.averusa.com/kb_article.php?ref=9869-UMJQ-1105 for instructions on how to fix the focus ring.
Feb 02, 2011 | Avermedia AVERVISION 300AF+ PORTABLE...
My Gigaware camera is out of focus and the settings screen did not give the ability to adjust focus. Is there something I can do?
the bezel on the cam might change the focal point(focus) try GENTLY ROTATING IN EITHER DIRECTION
BEZEL IS THE LITTLE RING JUST OUTSIDE THE LENS
Oct 09, 2010 | Radio Shack VGA PC Camera Webcam
Lens adjust is sticking. With the lense out you
since you have then lens out, get a wide blade flathead and insert it in the smallest part if **** that it will fit into behind the focus ring and turn the blade like you are trying to widen the **** all the way around until it pops out into it's normal position. Getting the entire lens back in properly is a bit tricky since the threads are easily stripped. First screw it all the way back on and then check the focus on the screen. You want to see a crisp image in 3 if not 4 of the outer corners of the screen. It is best to use something with text that fills the whole screen so you can see the 4 corners as you adjust the focus. If the focus is good in the corners, leave it alone. If not,hold the back of the projector in one hand and forcefully push the lens into where you screwed it on and see if it pops into place. It really is trial and error. Once you have a clear picture it is a good idea to remove the top cover and glue all around the base of the tube where it screws on so it doesn't come loose again.
Jul 30, 2010 | InFocus LP70+ Multimedia Projector
How do i change the focus without the remote?
There ia always a ring around the lens of all optical devices. If you power on the projector and rotate this ring clock or anti clock wise then you will find that you are able to focus the device to the best of display. Else try the settings manually if there is a provision.
Dec 19, 2009 | SIM2 Grand Cinema HT305E Projector
Screen not clear
first the obvious, clean the lens with a soft, cotton cloth. next, use the focus ring on the lens. if it's motor driven, use the buttons on the top.
Jul 24, 2009 | NEC VT37 Multimedia Projector
Focusing into slide transfer box
Yes, use a shorter projection lens. You didn't say what focal length your projection lens is, but Kodak and many of their OEM vendors made very short focal length lenses.
Aug 02, 2008 | Kodak Carousel 4400 Slide Projector
Out of focus...
http://www.projectorcentral.com/pdf/projector_manual_1798.pdf.
please read manual above.
Oct 25, 2007 | Toshiba TLP 261 Multimedia Projector
BenQ MX615 DLP Projector 3D Ready Projector Lamp Logo
152 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
