Question about Uniden Lands Phones
Kept getting a P88E after 3 seconds when I turn on my scanner
After I plug my scanner in and turn it own...it scans for 3 seconds then I get aP88E symbol
4 Suggested Answers
  • 31 Answers
SOURCE: Windows Mobile Symbol Find WLAN error
Warm boot the MC55 if that doesn't help then cold boot it, if that doesn't help then reload the Operating system, if that doesn't fix it then send it back to Motorola for a warranty repair.
Posted on Jun 30, 2009
Yogger
  • 117 Answers
SOURCE: I have a barcode scanner Symbol S/N M1J82M51E.
1. Press and hold the trigger for an extended period of time (approximately 5 seconds). The scanner cycles through three settings (Low, Medium, High) emitting a 2-beep tone at each setting.
2. To select a particular setting, release the trigger after you hear the desired 2-beep tone.
Posted on Sep 21, 2010
Yogger
  • 117 Answers
SOURCE: Switching rules Symbol LS2208
Hello Jonathan,
you would need to assign the rules to a specific ruleset. Then you switch between the ruleset to specify which rules are active at the moment. Please see the ADF chapter in the Reference Guide for LS2208 for the barcodes http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Posted on Dec 07, 2010
How do youfind scan count
If the scan count of your fi-6130 scanner exceeded 2,00,000 scans, then you may have to replace the consumable parts. After replacement of the consumables, you need to rest the consumable counters. To check/reset the Pick/Brake Roller Counter, please follow the steps provided below:
1.Turn on the scanner, and confirm if it is connected correctly to your computer.
2.From the "start" menu, select "All Programs", then select "Scanner Utility for Microsoft Windows", then click on "Software Operation Panel"
3.In the dialog box displayed, from the list on the left of the panel, select "Device Setting"
4.Click the "Clear" button beside the replaced consumable under "Page Counter"
5.Click the "OK" button on the displayed confirmation message. The counter is reset to 0
6.Click the "OK" button to close the "Software Operation Panel" dialog box
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jun 04, 2014 | Fujitsu fi-6130 duplex scanner
How to program itouchless doorlocks
change master code
0 + * + default/old mastercode + new 8 didgit master code + #
when successful it will make a solid single beep if unsuccessful it will beep 3 times
enroll finger print at random no user ID
1 + # + master code + #
first scan place finger on the scanner and remove when the scanner light turns off
second scan replace same finger when the scanner lights back up you will hear a single beep if enrollment is successful
if scan fails you will hear 3 beeps
Jan 15, 2012 | Itouchless Bm003l Bio-matic Fingerprint...
How can i stop the squelch ive tryed turning the sqcuelch doesnt help
Plug the AC adapter into the back of the scanner and into a wall electrical outlet. Screw the antenna into the receptacle on the back of the scanner (extend the antenna to full length for best reception).
  • 2 Set the squelch level to allow signals to be heard by turning the squelch knob counterclockwise. Rotate the volume knob clockwise until you hear static. Slowly turn the squelch knob clockwise until the static noise disappears.
  • 3 Start programming frequencies into the scanner by pressing the "Manual" button.
  • 4 Press the up arrow or down arrow key until the channel you wish to program is visible on the display.
  • 5 Use the numbers on the keypad to enter the frequency for the local transmitter you wish to receive.
  • 6 Press the "E" key to complete the process of entering the frequency.
  • 7 Repeat steps 3 through 6 for each additional frequency you wish to monitor.
  • 8 Press the "Scan" key to start the scanning process. The scanner stops on a channel when it detects a signal strong enough to hear over the squelch setting. Two seconds after the signal stops, the scanning process resumes.
  • Dec 06, 2011 | Uniden BC248CLT Base Scanner
    I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
    PROGRAMMING YOUR SCANNER
    For a a comprehensive database of active frequencies in your area, visit:
    www.RadioReference.com
    1. Turn on your scanner by turning VOLUME clockwise.
    2. Press [MANUAL], enter the channel number you want to program, then
    press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
    you are programming the channel.
    3. Enter a frequency.
    4. Press [ENTER] to store the frequency. If you make a mistake in Step
    3, ERROR appears on the display. Proceed again from Step 3.
    5. If you want your scanner to pause after each transmission before
    scanning to the next channel, press [DELAY] so that DELAY appears in
    the display. See "Using the Delay Feature."
    6. To program more channels, repeat Steps 2-4. If you want to program
    the next channel in sequence, simply press [PROGRAM] and repeat Steps
    3 - 4.
    SETTING THE VOLUME AND SQUELCH CONTROLS
    Use the SQUELCH control to decrease your scanner's sensitivity to weak
    signals. This allows the scanner to receive only the strongest
    transmissions.
    1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
    2. Turn the VOLUME control clockwise until you hear a hissing sound.
    3. Slowly turn the SQUELCH control clockwise until the hissing sound
    stops.
    SCANNING THE CHANNELS
    To begin scanning the channels, press [SCAN]. Your scanner scans through
    all the channels except the ones you have locked out. Be sure to read the
    following sections to get the full benefit from your scanner's special
    features.
    USING THE DELAY FEATURE
    Many agencies use a two-way radio system that might have a 2 second silence
    (or more) between a query and a reply. To keep from missing a reply,
    program a delay on the channels you identify as operating this way.
    To program a delay, select the channel and press [DELAY] so that DELAY
    appears on the display. Now when your scanner pauses at an active channel
    when scanning, it waits for 2 seconds after the completion of each
    transmission on that channel before it resumes scanning.
    If you do not want your scanner to pause, select the channel and be sure
    that DELAY is not on the display. If DELAY appears on the display, press
    [DELAY] to turn it off for that channel.
    LOCKING OUT CHANNELS
    You can make your scanner scan more efficiently by locking out channels
    that you have not programmed. Manually select the channel and press [LOCK
    OUT] so that LOCK OUT apperas on the display. This is also handy for
    locking out channels that have a continuous transmission. You can still
    manually select locked-out channels for listening.
    To unlock a channel you have locked, manually select the channel and press
    [LOCK OUT] so that LOCK OUT disappears from the display.
    NOTE: You cannot lock out Channel 1.
    USING THE PRIORITY FEATURE
    Channel 1 is designated as your scanner's priority channel. You can turn
    on the priority feature so that you do not miss transmissions on Channel 1,
    even if you are monitoring another channel.
    Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
    checks Channel 1 every 2 seconds, and stays on the channel if there is any
    activity.
    MANUALLY SELECTING A CHANNEL
    You can continuously monitor a specific channel without scanning. This is
    useful if you hear an emergency broadcast on a channel and do not want to
    miss any details-even though there might be periods of silence-or if you
    want to monitor a specific channel.
    Follow these steps to manually select a channel.
    1. Press MANUAL.
    2. Enter the channel number.
    3. Press MANUAL again.
    Or, if your scanner is scanning and stops at the desired channel, press
    MANUAL one time. (Pressing MANUAL additional times causes your scanner
    to step through the channels.)
    LISTENING TO THE WEATHER BAND
    The FCC (Federal Communications Commission) has allocated several channels
    for use by the National Oceanic and Atmospheric Administration (NOAA). We
    have preprogrammed your scanner with all of the frequencies available to
    NOAA. To hear your local forecast and regional weather information, simply
    press [WX]. Your scanner begins scanning through the weather band, and WX
    SEARCH appears on the display.
    Your scanner should stop within a few seconds, and you hear the local
    weather broadcast. If the broadcast is weak, you can press [WX] again
    to scan through the rest of the weather band.
    Bill B
    Feb 21, 2010 | Radio Communications
    I WANT TO KNOW THE MEAN OF ''ERROR 06'' IN HP SCANJET 8270 AND THE POSIBLE SOLUTIONS... THANKS
    If LCD displays Error 06 or Error 09 , the TMA might require service
    Press SCAN PICTUREc00068011.jpg button once (see Figure 3 above). The TMA lamp should turn on (see Figure 4 above). If pressed a second time, the TMA lamp turns off (if TMA is detected). NOTE: The scanner carriage lamp should be off when the TMA lamp is on and should be on when the TMA lamp is off. The only time the TMA could not be detected is if the accessory cable is not plugged into scanner
    Jul 02, 2009 | Office Equipment & Supplies
    My kodak esp3 will not scan it prints and copies.
    I had the same problem and I got it to work. I have Windows Vista and Microsoft Office 2007 on my computer. Here's what I did...
    Go to "Start" then "Control Panel".
    -Click on "Programs and Features".
    -Scroll down to Microsoft Office Home and Student 2007 - click on that and then click on the "Change" link above.
    -A box will pop up, click on "Add or Remove Features" and then click "Continue".
    -Click on the "+" next to "Office Tools"
    -Click on the "+" next to "Microsoft Office Document Imaging"
    -Click on the down arrow next to "Scanning, OCR and Indexing..."
    -Then, click on "Run from my Computer"
    -Next click on "Continue" at the bottom of the dialogue box and your configuration process should begin
    Once completed go to the start menu and type in "Scan" into the search box. Go to "Microsoft Office Document Scanning" Once there, plug your scanner into you computer, chose what color you want your scan to be in, and click on the picture of the scanner to the right. To make my scans clear, I had to click on "Scanner..." and chose KODAK ESP AiO as my scanner even though I have a KODAK ESP-3 printer/scanner.
    I hope these instructions weren't too confusing and I hope this helps some of you out! My scanner was causing me a lot of frustration for a while!
    May 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    HP PCS 2510 Scanner module keeps running
    Please follow my steps:
    1. Make a ring, which is 5mm high and 1/3 cut so that it can be mounted at the far right end of the rail bar where the scanner module sliding back and forth. This can help get the none-stopping scanner out of the trap!
    2. Do the Semi-Reset opreation. Then you can see the healing result!
    Dec 22, 2008 | HP PSC 2510 All-In-One InkJet Printer
    EPSON V700 Photo Scanner
    Unplug the power supply from the power port on the scanner then plug it back in after a few seconds and power-up if it isn't already on. This happens to me a lot and this works every time. Frustrating though.
    Jan 14, 2008 | Epson Perfection V700 PHOTO Flatbed...
    Lands Phones Logo
    20 people viewed this question
    Top Uniden Lands Phones Experts
    k24674
    Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
