Question about Car Audio & Video
Brutus elite hifonics BRE1600.1D. Not as powerfull now.
I have a Brutus elite hifonics BRE1600.1D The power cable leading directly to the amp loosened from the battery so the amp lost power. fixed that issue but now the amp doesn't kick as loud as it use to before the power lose. I tried a different amp and L7 sounds fine. Any possible fix for the Brutus? Thanks.
  • 637 Answers
Make sure of voltage going in to Brutus.
Posted on Jun 18, 2014
  • 524 Answers
SOURCE: i have a 2000 watt hifonics brutus amp ...it
there is a step up converter inside the amp that likes to come loose from the board. This may be your problem. Otherwise Check all the chips for burns or disconnect
Posted on Mar 22, 2010
  • 631 Answers
SOURCE: no sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Posted on Jan 02, 2008
fixyathing
  • 341 Answers
SOURCE: blown resistior in a hifonics brutus bxi 1606d
If you can point it to me in the schematic diagram I might be able to help you. But I suggest you bring it to a qualified audio electronic technician if you still value it. cheers!
Posted on Oct 17, 2008
  • 102 Answers
SOURCE: hifonics brutus 2000 watt help??!!??
If an RCA took a dive your amp has most likely seen a very nasty input spike and may never be the same as its circuitry has been damaged.....sorry
Posted on Mar 09, 2009
  • 13 Answers
SOURCE: hifonics brutus bxi 2008 amp. no power output
MAKE SURE SUBWOOFER OUTPUT ON YOUR RADIO IS ON IF NOT THAT COULD BE BAD INPUTS ON YOUR AMP
Posted on Aug 08, 2009
I have 2 Pioneer TS-W3002D4 12 In and a Hifonics Brutus BRZ1200.1D D-Class Mono Block what's the best wiring
you need to wire each sub down to 2ohms then wire them together like the one in this pic http://m.seimg.net/product/img/subwoofer_wiring/2_subs_DVC_4_ohm_mono_variation2.jpg witch will give you 1ohm so you will be getting every bit of power that amp has but you should get a bigger amp for thos speakers
Mar 24, 2013 | Car Audio & Video
Is the brutus amp blue led light suppose to stay on when the car is off?
No. The LED should be off when the radio is off (amp turns off as well)
It sounds like you have constant 12volts applied to your remote turn on lead. The amplifier will have 3 connections for power:
1. 12volt constant
2. chassis ground
3. 12volt switched power - this wire should come directly from your head unit. It only sends 12 volts when the radio is on allowing to amp to power up only when the radio is on.
Dec 22, 2010 | Hifonics Brutus BXi 1206D Car Audio...
I have a 2000 watt hifonics brutus amp ...it worked fine but 1 day it just stopped working..the power light doest light up but the hifonics led lights are still on...whats the problem?
Nov 13, 2009 | Hifonics Brutus BX 2005D Car Audio...
!!!red protect light is on!!!
Hello beaugarcia26,
Unless the amp itself is defective, there's a short or ground somewhere.
First disconnect the speaker wires and RCA (or high level) inputs, leaving just ground, remote turn-on and power leads connected. Then see if the amp powers up normally. If it doesn't check the ground with a multimeter and make sure it is good. If the amp powers up normally, check the speaker, speaker wires and inputs for shorts or grounds.
Hope this helps.
Sep 02, 2009 | Hifonics Brutus BX 1205D Car Audio...
I am ordering 2 pioneer TSW307D4 or D2 is a 2400 watts amp good?
ok theres a amp called slugger they came out about 7-10 years ago its small but very very powerfull i was picking up my 2 15 inch l7 kickers i drove from my house to vegas with no problem about 4 and a half hrs and didnt turn off ,on the other hand i had my fosgate wich i love t1000 wich turned off on me a couple times
Mar 15, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics brutus 2000 watt help??!!??
Mar 09, 2009 | Hifonics Brutus BXi 1206D Car Audio...
No sound in my Hifonics Brutus BXi 1206D amp
Jan 01, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Amp does not work
make sure your power and ground wires are 4 gauge thats a big power puller also make sure your wires to woofers are correct!and you want a short ground wire and a good spot for it no paint!!
if there out of phase that will shut it off BUT you might be needing a battery cap. MORE POWER!!!!they dont cost much
and save your battery and alt.hifonics is a good choice my favorite are the series 7 they dont make them like that anymore!
hope this helps one more thing your alt.how many amps is it?
my honda is only 60 amps your brutus pulls that all day !
(BATT.CAP.or HAVE ALT.WRAPED for more power.
Dec 01, 2007 | Hifonics Brutus BX 1505D Car Audio...
Car Audio & Video Logo
99 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
