Question about Ryobi Chainsaw. 12 in. 40-Volt Lithium-ion Cordless Electric Chainsaw
How to get scabbard off 40 volt cordless chainsaw
I just bought chain saw and I can't figure out how to get off chain cover off. I turned chain cover lock knob and it seems like entire chain arm wants to come apart and cover still does not come off.
    Sergeant:
    Champion:
  • 257 Answers
Take it back to werever u bought it! let them figure it out?. lol.
Posted on May 21, 2014
I have a replacement chain for a electric 40cm Bosch chain saw but it can't get the new one on as the chain tensioner will not go back far enough does it ever get blocked and should I take the cover off...
Take the cover off, Take the bar off. Clean it out. Put the chain around the sprocket. Put the bar on. Put the chain around the bar. Tighten the chain a bit. Put the cover on. Tighten the chain.
Feb 22, 2015 | Bosch Saw Chain for AKE 40 / 40-17 / 40-18...
Use synthetic oil on the chain
If it's very cold than why not... but if it's warm then I wouldn't suggest it. But why would you want to ???
Dec 04, 2013 | Remington 8-Inch 18 Volt Cordless Chain...
How to tighten chain on black and decker cordless pole saw
A properly-tensioned chainsaw chain should still be just a little loose on the chainsaw guide bar, but the chain needs to be tight enough that you can't pull the drive links out of the bar nose.
More details how to tighten the chain on black and decker cordless pole saw go to the link Practical Black and Decker Pole Saw Review
Jul 21, 2013 | Black & Decker Black Decker NPP2018B 18...
I just bought a Ryobi 18v cordless chain saw. Filled the oil reservoir, pumped etc and used. Left it overnight and now the contents of the reservoir are all over my garage floor. Instructions said to...
Man, I know what you mean. If I am not going to use my saw, I empty my saw oil back into
the oil bottle using a large funnel to catch it all. Then I can put the saw in a large cardboard box
lined w/layers of newspaper in an upright position til next time. Works great! Get back to me if
you need help sharpening that puppie...............dansky66
Mar 26, 2011 | Ryobi Factory Reconditioned 10-Inch 18...
Bought a Homelite 14" electric chainsaw. After
I am not sure if you have figured out how to put the chain back on your saw or not, but it doesn't take long.
1. Remove the plastic yellow "T" shaped nut on the right side of the saw (towards the front of the motor housing)
2. Remove the black plastic housing that covers the rear section of the bar and chain
3. Place the chain back onto the bar making sure it is facing the correct direction.
4. Place the chain over the rear sprocket area
5. Turn the +/- yellow plastic knob (towards the back of the saw on the right side) in the - direction until the metal guide inside the plastic casing lines up with the hole in the chainsaw bar
6. Replace the black plastic housing and slightly tighten the yellow "T" shaped nut.
7. Now turn the +/- knob until the chain is tight. Once the chain is tight, turn the "T" nut until it is tight and you are ready to cut again.
Jan 30, 2011 | Homelite Consumer Products 9.0 Amp, 14 In....
Just received recondition Ryobi 18 volt chain saw. Motor runs backwards.
electrical motor was wired in reverse, If you you attempt repair assuming product was purchased from store ,your sure not to get a fund or in-store credit.
Dec 07, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
I bought a cordless lawnmower at auction but unsure how to get it to work
Does the blade turn by hand? If so, then the motor bearings are ok. The motor uses brushes as part of the electrical process--they can be worn out or stuck. Internal wiring breakage can result from vibration. Bad power switch? Open winding within the motor?
Jul 02, 2009 | Hyundai Electronics Hyundai 2-in-1 Cord/...
Ryobi battery chainsaw 10" - How do I tighten the chain?
loosen the two nuts that hold the chain cover on. Once they are just loose, then use a flat blade screw driver to turn the slot that you see right next to the base of the chain. Once the chain is tight, retighten the two nuts.
May 23, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Ryobi Chainsaw. 12 in. 40-Volt Lithium-ion Cordless Electric Chainsaw Logo
517 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
