Question about ATI RADEON 9800 PRO (256 MB) Graphic Card
Swap 9800 Pro for 9700 Pro
I have 2 computers with ATI Radeon AGP video cards, both work just fine. One card is a Radeon 9800 Pro on an ECS Intel motherboard with a 400W PSU and the other is a Radeon 9700 Pro on an Asus AMD motherboard with a 380W PSU both computers use the latest video drivers from ATI.
Now, I want to use the 9800 Pro in the computer that currently has the 9700 Pro, but when I exchange the 9800 card for the 9700 card there is NO video signal prior to post. I've checked the bios for the correct AGP VGA setting, that didn't help.
  • dlcampbe Oct 30, 2007
    Both cards require the same drivers. I did, however, remove the drivers before trying to install the 9800. When booting with the 9800 installed, there is no video signal prior to post, no beep, nothing.
    I have no onboard video on either computer and each has just one AGP slot. In "Device Manager" there are no conflicts, both video cards are shown correctly.
    OK, I switched PSUs, the 9800 still will not post. I also put the 9700
    in the other computer without changing the ATI drivers and it booted
    right in to Windows.
    Go figure?
  • 328 Answers
You must uninstall the current driver and reinstall the driver for the 9800 Pro first:
Power supply recommended is 300watt for each, so that is not a factor. It would have to be a driver conflict.
Posted on Oct 30, 2007
  • Lyle Siemens
    Lyle Siemens Oct 30, 2007
    You also may try to hook the video cable to the onboard video first so you can configure it first before connecting it back to your video card. Make sure it is also the default driver for your card, this can be changed under control panel under display settings then advanced button then adapter tap, Make sure the info is correct first. Failing that, try a different slot for the card. There is a solution for this problem but I am just trying to troubleshoot the basics first. Also check under device settings under system---and clicking the hardware tab. Look for a yellow exclamation mark under device manager, then chek the status of the card from there.
Video Card Not Working. Can I replace a Medion Radeon 9800XL Ver : 100 with a ATI Radeon 9800 Pro 128mb?
Both boards are AGP 8x type boards. So, assuming that you have the appropriate drivers for the replacement board, there is no reason to assume that you cannot perform the swap. You may not even have to change the drivers, since they are both 9800 Radeon family, but I would be sure I had the right ones available in case.
Oct 25, 2016 | Medion Cameras
How to covert to Mac edition (ATI Radeon 9800 Pro)
Even if you do this, I would not guarantee it will work. Before you destroy it and void the warranty, you could probably return it or sell it on eBay. It's still a decent card for a AGP variety.
Jan 02, 2012 | Gigabyte ATI RADEON 9800 Pro (128 MB) AGP...
Cannot install final cut pro.....the software says my macbook pro(macbook3,1) does not have minimum system requirements. my mac.... 2.2 ghz 800mhz core 2 duo 4gb ram 2x2gb @ 667mhz GeForce 5600m gt 128mb...
yes it seems that your laptop dose not meet the minimum requirements to install final cut pro will need to purchase a laptop with the correct requirements,sorry.
Apr 04, 2010 | Apple MacBook Pro Laptop Computer with...
How to install ATI Radeon 9800 Pro 256 MB AGP 8x 3D Video Graphic Card
Install drivers and software from ATI site turn off computer plug in card then turn back on....
Sep 19, 2009 | Connect3D Computers & Internet
Update video card
It will work fine. I looked up one for you here: http://search%20sapphire%20ati%20x1650%20pro%20512mb/
cost is $65.99 and it only requires a 350 watt psu so you are good. Hope this helps & please remember to rate my answer.
Dec 29, 2008 | ASUS K8V-SE Deluxe Motherboard
Ati radeon agp card
Hi Rafael83,
There may be afew things that may be wrong. One, the video card may be bad, two the motherboard may be bad, or three your power supply may not have enough wattage to power your video card. Or it coud be all of the above.
Agent Xiong
Apr 30, 2008 | Vga GeForce4 Ti4200 64MB DVIout AGP Card...
Comparable cards to the ATI All In Wonder 9700 Pro 128 MB
Hello there. The Radeon 9700 Pro was a high end graphics card in its time. Today the latest Radeon cards are 3870X2, 3870 and 3850 models. The 3850, while mid-high end range, would be a substantial upgrade from the Radeon 9700 Pro.
If you are planning to upgrade your system, make sure you choose the correct type of card (AGP/PCI-E) and that your current system has a good enough power supply to power a new upgrade.
Hope this helps.
Apr 13, 2008 | ATI All-in-Wonder 2006 PCI Express ,...
Intel P$ 1.8 mhz on a D845HV/D845WN board
Before removing your current card swap video outputs on the PC. If currently connected to the VGA output switch to the HDMI connector AT the video card. Use the HDMI to VGA adapter that came with the video card. Check & see if the display loads Pc starts. Taking the information directly from your motherboard manual pg. 25, your AGP video can only run at, AGP supporting 1.5 V 4X AGP cards. The 9600pro runs at 8x & it is not backwards compatible. (able to run at either 8x or 4x). You could run the Sappire ATI Radeon 256MB 9550 DDR AGP 4x/8x 1.5volt card.
Here is one site:
When you do get the video card be sure to set your bios AGP to the correct size as listed in your manual pg. 109 subsection 4.4.7
I hope this helped.
Feb 20, 2008 | Intel Motherboard
All AGP based cards are backwards compatible, so an 8x card should operate at 4x 2x and 1x
however what is important is the voltage of your slot, you can tell by looking at the slot itself,  the AGP slot may have a partition either 1/3 or 2/3rds down the slot, or may have no partition at all,
this slot partition is to prevent you from inserting a card of the wrong voltage.
If there is no partition in the AGP slot then the slot has a switchable voltage, and will automatically switch to the appropriate voltage, (on request from the graphics card AUTOMATIC)
so all you need to check is that the graphics card you buy has slots on the AGP interface that accomodate those on your board
according to the manual
This board has a 4x AGP slot
Oct 09, 2007 | Intel Motherboard
ATI RADEON 9800 PRO (256 MB) Graphic Card Logo
399 people viewed this question
Top ATI Computers & Internet Experts
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
